Help! homebridge-loxone-ws-adv v1.0.7 läuft nicht (loop)
  • Flymaik
    • 13.01.2018
    • 2
    habe leider Probleme mit der Anbindung von Loxone mit der Homebridge an Apple Homiekit /Siri.
    Homebridge läuft einwandfrei. Bei Installation des Plugins "homebridge-loxone-ws-adv v1.0.7" scheint sich die Homebridge auch mit Loxone zu verbinden, startet dann aber die Homebridge immer wieder neu.-
    Hier das log:
    Started Node.js HomeKit Server.
    [4/28/2020, 13:08:46] Loaded config.json with 0 accessories and 2 platforms.
    [4/28/2020, 13:08:46] ---
    [4/28/2020, 13:08:47] Loaded plugin: homebridge-config-ui-x
    [4/28/2020, 13:08:47] Registering platform 'homebridge-config-ui-x.config'
    [4/28/2020, 13:08:47] ---
    [4/28/2020, 13:08:47] Loaded plugin: homebridge-loxone
    [4/28/2020, 13:08:47] Registering platform 'homebridge-loxone.Loxone'
    [4/28/2020, 13:08:48] Loaded plugin: homebridge-loxone-ws-adv
    homebridge API version: 2.5
    [4/28/2020, 13:08:48] Registering platform 'homebridge-loxone-ws-adv.LoxoneWs'
    [4/28/2020, 13:08:48] ---
    [4/28/2020, 13:08:48] Loading 2 platforms...
    [4/28/2020, 13:08:48] [Config] Initializing config platform...
    [4/28/2020, 13:08:48] [Config] Spawning homebridge-config-ui-x with PID 721
    [4/28/2020, 13:08:48] [Loxone] Initializing LoxoneWs platform...
    [4/28/2020, 13:08:48] [Loxone] Info: rooms array not configured. Adding every room.
    [4/28/2020, 13:08:48] [Loxone] object
    New WS: 10.0.10.55:80
    [4/28/2020, 13:08:48] [Loxone] Platform - Waiting 8 seconds until initial state is retrieved via WebSocket.
    [4/28/2020, 13:08:48] [Loxone] LOXONE WS: connect
    [4/28/2020, 13:08:53] [Config] Homebridge Config UI X v4.16.0 is listening on :: port 8080
    [4/28/2020, 13:08:56] [Loxone] Platform - Retrieving initial config from http://Homebridge:extrude-nostrum-re...a/LoxApp3.json
    [4/28/2020, 13:08:56] [Loxone] Platform - The widget 'Lichtsteuerung' of type LightControllerV2 is an item not handled.
    [4/28/2020, 13:08:56] TypeError: Class constructor PlatformAccessory cannot be invoked without 'new'
    at LightbulbItem.AbstractItem (/usr/local/lib/node_modules/homebridge-loxone-ws-adv/items/AbstractItem.js:22:25)
    at LightbulbItem.SwitchItem (/usr/local/lib/node_modules/homebridge-loxone-ws-adv/items/SwitchItem.js:12:23)
    at new LightbulbItem (/usr/local/lib/node_modules/homebridge-loxone-ws-adv/items/LightbulbItem.js:6:26)
    at exports.Factory.parseSitemap (/usr/local/lib/node_modules/homebridge-loxone-ws-adv/libs/ItemFactory.js:66:29)
    at Request._callback (/usr/local/lib/node_modules/homebridge-loxone-ws-adv/index.js:88:38)
    at Request.self.callback (/usr/local/lib/node_modules/homebridge-loxone-ws-adv/node_modules/request/request.js:185:22)
    at Request.emit (events.js:310:20)
    at Request.<anonymous> (/usr/local/lib/node_modules/homebridge-loxone-ws-adv/node_modules/request/request.js:1154:10)
    at IncomingMessage.<anonymous> (/usr/local/lib/node_modules/homebridge-loxone-ws-adv/node_modules/request/request.js:1076:12)
    [4/28/2020, 13:08:56] Got SIGTERM, shutting down Homebridge...
    [4/28/2020, 13:08:57] [Config] Changes to config.json saved.
    homebridge.service: Main process exited, code=exited, status=143/n/a
    homebridge.service: Failed with result 'exit-code'.
    homebridge.service: Service RestartSec=10s expired, scheduling restart.
    homebridge.service: Scheduled restart job, restart counter is at 2.
    Stopped Node.js HomeKit Server.
    und hier meine config.json:
    "bridge": {
    "name": "Homebridge",
    "username": "CC:22:3D:E3:CE:30",
    "manufacturer": "homebridge.io",
    "model": "homebridge",
    "port": 51826,
    "pin": "031-45-154"
    "description": "Home Smart Home",
    "platforms": [
    "platform": "config",
    "name": "Config",
    "port": 8080,
    "auth": "form",
    "theme": "green",
    "restart": "sudo -n systemctl restart homebridge",
    "temp": "/sys/class/thermal/thermal_zone0/temp",
    "sudo": true,
    "log": {
    "method": "custom",
    "command": "journalctl -o cat -n 500 -f -u homebridge"
    "platform": "LoxoneWs",
    "name": "Loxone",
    "host": "10.0.10.55",
    "port": "80",
    "username": "zzzzzzz",
    "password": "xxxxxxxx"
    "accessories": []
    Da hier ja einige die Homebridge auch nutzen wäre es super, wenn mir jemand helfen könnte oder ein Tipp hat.
    Danke vielmals :-)
    Flymaik
  • she
    • 21.03.2017
    • 7
    Ich habe nach dem Update von Homebridge auf Version 1.0.0 genau das selbe Problem! Bräuchte auch ein Lösung?
    • Automatisierer
      • 04.10.2018
      • 63
      Bei mir das gleiche.
      Bin noch nicht weiter gekommen.
      Miniserver; KNX; Loxberry; Home Assistant; Nuki; Roborock; Siemens S7/TIA; DoorBird; 3D-Druck
      • IFLUR
        • 392
        Es wurde wieder Änderungen an der LoxApp3.json seitens Loxone vorgenommen.
        Der Fehler liegt wahrscheinlich an Änderung des Type "LightControllerV2"
        und am Type "undefined"
        Konnte den Fehler noch nicht weiter eingrenzen.
        Wie sieht es denn bei den Nutzer von https://www.1home.io/ da sollten doch ähnliche Fehler auftreten ?
        Aktuell läuft die Homebridge-WS leider nicht mehr !!
        • madito
          • 03.07.2017
          • 132
          Hi!!
          My instalation of homebridge (version 0.4.50) is working with the last version of Loxone.
          Try:
          If you encounter any issues in v1.0.0 you can rollback to v0.4.53 using this command:
          sudo npm install -g --unsafe-perm homebridge@0.4.53
          Zuletzt geändert von madito; 02.05.2020, 22:31.
          • IFLUR
            • 392
            [Loxone] LOXONE WS: connect3.5.2020,
            00:53:55 [Loxone] Platform - Retrieving initial config from http://user:password@192.168.2.1:/da...3.json3.5.2020,
            00:53:55 [Loxone] Platform - The widget 'Licht' of type LightControllerV2 is an item not handled.3.5.2020, 00:53:55 [Loxone] Platform - The widget 'Master-Helligkeit of Licht' of type Dimmer was skipped.3.5.2020,
            00:53:55 TypeError: Class constructor Platform cannot be invoked without 'new' at DimmerItem.AbstractItem (/home/hoobs/.hoobs/node_modules/homebridge-loxone-ws-adv/items/AbstractItem.js:22:25) at new DimmerItem (/home/hoobs/.hoobs/node_modules/homebridge-loxone-ws-adv/items/DimmerItem.js:12:23) at exports.Factory.parseSitemap (/home/hoobs/.hoobs/node_modules/homebridge-loxone-ws-adv/libs/ItemFactory.js:66:29) at Request._callback (/home/hoobs/.hoobs/node_modules/homebridge-loxone-ws-adv/index.js:88:38) at Request.self.callback (/home/hoobs/.hoobs/node_modules/request/request.js:185:22) at Request.emit (events.js:210:5) at Request.<anonymous> (/home/hoobs/.hoobs/node_modules/request/request.js:1154:10) at Request.emit (events.js:210:5) at IncomingMessage.<anonymous> (/home/hoobs/.hoobs/node_modules/request/request.js:1076:12) at Object.onceWrapper (events.js:299:28)3.5.2020,
            00:53:55 Got SIGTERM, shutting down Bridge...
            Der Fehler liegt in der LOXONE WS :-(
            • Automatisierer
              • 04.10.2018
              • 63
              Bin auch zurück auf Version 0.4.53. Da funktioniert wieder alles.
              Hatte die Homebridge über das UI x Plugin upgedated. Danach lief das Loxone WS Plugin nicht mehr.
              • Lumoc
                • 11.05.2019
                • 7
                Servus zusammen,
                ich bin selbst noch auf der alten Version habe aber eine neue vom Loxone Plugin erstellt und hochgeladen. Vermutlich hängt das mit Änderungen an der notwendigen Syntax und ES6 zusammen. Kann das jemand mal testen? Version 1.0.8 https://www.npmjs.com/package/homebridge-loxone-ws-adv
                • Automatisierer
                  • 04.10.2018
                  • 63
                  Habs gerade getestet, jedoch wird das Plugin offensichtlich nichtmal gestartet .
Ansichten: 1286
Größe: 255,4 KB
                  • Automatisierer
                    • 04.10.2018
                    • 63
                    Bin zurück auf Homebridge 0.4.53 und Loxone WS 1.0.5
                    Hatte vor einigen Wochen dein Plugin 1.0.7 ausprobiert, jedoch kam da viel mist raus. Viele Geräte hießen nur noch Lightbulb und waren in der Home App nur umständlich zu zuordnen.
                    Ein Problem aller Versionen scheint zu sein, für die Lichtsteuerung V2 nur die Stimmungen zu bekommen. Trotz des Parameters "only" werden auch die einzelnen Ausgänge der Lichtsteuerung als Gerät angelegt.
                    • Lumoc
                      Lumoc kommentierte
                      Der Hauptgrund für den Fork und die Anpassungen sind die Namen. Ich habe die Verschachtelung mit dem Raum ausgebaut und das der Name im Loxone dem Punkt im Homekit entspricht. Aktuell wegen Umstellungen im Pluginsystem keine Aussicht auf schnelle Lösung.
                  • bluemevo
                    • 27.01.2019
                    • 67
                    Auch mit Version 1.0.9 schlägt das Update auf HB 1.0.4 fehl:
                    [5.5.2020, 22:32:27] [Loxone] Platform - Retrieving initial config from http://***/data/LoxApp3.json
                    [5.5.2020, 22:32:27] [Loxone] Platform - The widget 'Abstell unten' of type LightControllerV2 is an item not handled.
                    [5.5.2020, 22:32:27] TypeError: Class constructor PlatformAccessory cannot be invoked without 'new'
                    at LightbulbItem.AbstractItem (/usr/lib/node_modules/homebridge-loxone-ws-adv/items/AbstractItem.js:22:25)
                    at LightbulbItem.SwitchItem (/usr/lib/node_modules/homebridge-loxone-ws-adv/items/SwitchItem.js:12:23)
                    at new LightbulbItem (/usr/lib/node_modules/homebridge-loxone-ws-adv/items/LightbulbItem.js:6:26)
                    at exports.Factory.parseSitemap (/usr/lib/node_modules/homebridge-loxone-ws-adv/libs/ItemFactory.js:66:29)
                    at Request._callback (/usr/lib/node_modules/homebridge-loxone-ws-adv/index.js:88:38)
                    at Request.self.callback (/usr/lib/node_modules/homebridge-loxone-ws-adv/node_modules/request/request.js:185:22)
                    at Request.emit (events.js:315:20)
                    at Request.<anonymous> (/usr/lib/node_modules/homebridge-loxone-ws-adv/node_modules/request/request.js:1154:10)
                    at IncomingMessage.<anonymous> (/usr/lib/node_modules/homebridge-loxone-ws-adv/node_modules/request/request.js:1076:12)
                    [5.5.2020, 22:32:27] Got SIGTERM, shutting down Homebridge...
                    • Lumoc
                      • 11.05.2019
                      • 7
                      Die aktuelle Version des Plugin funktioniert nicht mehr, Grund sind anscheinend Änderungen am Pluginsystem bzw. Typescript und ES6. Sollte es eine Lösung geben melde ich mich.
                      • hstohl
                        hstohl kommentierte
                        Vorab: vielen Dank, dass du das als scheinbar 1-man-show am Leben hälst. Ich kämpfe auch mit demselben Problem (wie vermutlich jeder ders verwendet) und ich hab erst jetzt gemerkt wie sehr ich das ganze in Verwendung habe.
                        Schade, dass es dafür keinen offiziellen Support von Loxone selbst gibt. Die Loxone App ist gut, in manchen Bereichen aber "zuviel" dafür an anderen Stellen einfach zu kompliziert.
                        Auf der anderen Seite "kann" Apple Home wieder massiv zu wenig ist aber mit einfachen Dingen wie Verlassen und vorallem Siri (Watch, ATV) suuuuper genial zu bedienen.
                        Btw. wenn ich schon den richtigen Mann hier habe: mir werden Steckdosen als Schalter angezeigt. Ist natürlich nur kosmetisch aber gibts da für DAUs eine Möglichkeit da das Steckdosen Symbol anzeigen zu lassen?
                    • Automatisierer
                      • 04.10.2018
                      • 63
                      Vielen Dank für deinen Einsatz.
                      Bin froh das überhaupt jemand das Plugin am Leben erhält.
                      • hstohl
                        • 09.02.2016
                        • 337
                        Lumoc gibts vielleicht schon einen Status bzw. progress?
                        • Lumoc
                          • 11.05.2019
                          • 7
                          Leider nein, bin im Moment mit Planung für den Hausbau und Arbeit total ausgelastet. Wer aber eine kommerzielle Alternative sucht kann ich 1HOME empfehlen. Wenn ihr euch hier vorregistriert bekommt ihr zum Launch ein spezielles diskontiertes Angebot was ich mitbekommen habe. Bin Tester und bis jetzt ziemlich begeistert. Der Vollständigkeit halber sei gesagt, wenn ihr meinen Link verwendet bekomme ich einen Freunde werben Freunde Bonus. https://my.1home.io/referral/e27dc07be7fe0e1e
