Es ist die Rede von Modbus High Performance mit dem man den Abruf wieder < 5 Sekunden stellen kann, es kann wieder 1 Sekunde gewählt werden.
Zwei Sensoren können sogar auf 0.1 Sekunden gestellt werden.
So kann Loxone die Begrenzung wieder aufheben und trotzdem Fremdhardware begrenzen, 1 Sekunde für Taster ist einfach zu langsam.
Ich habe es gerade getestet, die Sekunde geht mit TCP Verbindungen ohne Probleme, RTU kann ich aufgrund fehlender Ext. nicht testen, wird aber wohl auch gehen.
14.4.8.28
New:
A3D9-T1055 Modbus High Performance Input
- reduce common minimum polling-cycle to 1s (except Air-Devices)
- up to 2 Sensors per Modbus-Server or Extension allow a minumum time of 0.1s
- if multiple modbus-servers with same IP (TCP) or multiple devices with same Device-ID(TCP + RTU) exists,
performance sensors are disabled for these devices
BACnet:
- Invalid properties (time, date, utc offset)
- Adapted Model name
- Adapted vendor name
- Added support for device reinitialization command
- Added support for foreign device properties
- Removed unsupported IPv6 mode
- Ping: Added support for statistics
Fixed:
- BG-I20160 NFC Code Touch: NFC Credencials not random
- new valve tree binary: fixed valves increasing force slightly after saving into miniserver
- new Touch Pure Flex binary: improved wakeup handling for temperature/humidity measurement
- BG-I25595 Trust usergroup suddenly converted to normal user group
- Permitted Users dialog: Added Multiedit line
- BG-I25591 Multiplicator: Closing project also closes all child projects
- BG-I25489 Generic Table: Non editable cell is emptied
- BG-I23749 Systemstatus: Webservices in client/gateway systems return an error
- Plugin webservices not working anymore (causes HomeKit problems in the app)
- BG-I25652 Automatic file name stops at 99 ("Untitled 99.Loxone")
- BG-I25691 Runtime Counter: Maintenance Interval defined by logic not properly handled
- BG-I25627 User is immediately deleted when expiration action is set to delete and user is not yet in the enabled timespan
