IR control to/from network
drift hunters There are a few things you need to know in order to control your IR to/from your network. First, make sure your IR is enabled on your router. -
Thanks! I'll check it out.
(yes, fun to learn something new, but I have too little time as it is...)
Einen Kommentar schreiben:
There is a DIY Hardware based on Wemos (ESP again) .
Can Transmit and receiver IR as well as
or this here
Infrared remote library for ESP8266/ESP32: send and receive infrared signals with multiple protocols. Based on: https://github.com/shirriff/Arduino-IRremote/ - crankyoldgit/IRremoteESP8266
Yes i know, this is not a ready to use product, but a lot of fun learning somthing new.
Maybe a Solution for you, you can Flash the ir Bridge with tasmota with tuya , the commands you can send with http or mqtt , received commands you can see in the console
Daten zur Gosund P1: Leistung: 3450Watt 15Ampere USB 5V/3,1A laut Hersteller - in der Praxis jedoch bricht die Spannung schon ab 1A ein auf unter 5V Preis ca. 25Euro Klicke auf die Grafik für eine vergrößerte Ansicht Name: Gosund.png Ansichten: 0 Größe: 2,21 MB ID: 273427 (filedata/fetch?id=273427&d=1604505761)
post #2Einen Kommentar schreiben:
Interesting... though a bit outside of my capabilities.
I realize that I'm more looking for an ir receiver solution, as I prefer a button-remote over an app.. and a flirc may actually suffice (there is a pc that is on when I would want to use the remote)...
Hello,
I would like to have ir control to/from a miniserver. I suspect the GlobalCache devices would work, but they are expensive ( https://www.globalcache.com/products/itach/models2/ ).
Does anyone have experience with Broadlink devices? Particularly the IR bridges: https://www.ibroadlink.com/products/ir-control
They are quite cheap, but I wonder if they work well... My main purpose would be to use an IR remote to send instructions to the miniserver and to have the miniserver trigger IR commands to control different devices.
According to Broadlink, they support IFTTT, so I'm guessing that in combination with a Loxberry there are some options?
Any comments? Or other alternatives?
Thanks!
JörgStichworte: -
