Air Extension 'connected' but offline
  • Jaip
    • 08.12.2020
    • 6
    I just installed a new Air extension. Got it connected after my Tree extension, and thus putting my 120 Ohm resistor at the end (at my Air extension).
    My miniserver noticed something new in the chain, extension search, added the extension.
    But it remains offline.
    Checking the resistor value at the Loxone Link (blue connector) [when devices are powered on, just read an article in English and not in Dutch, yes there is a big difference in information between them..., they you should be power off for that checking the resistance], and got 64 Ohm's. So within spec. (https://www.loxone.com/enen/kb/extension-diagnostics/).
    What else could it be?
    => other cabling of miniserver and etc where done by an electrician, hired by the company we used for our house... Not that satisfied of that electrician...
    Thanks!
  • Jaip
    • 08.12.2020
    • 6
    Solved!
    Just watched a video from 'Die Allroundbastler​' and the light bulb went on (pun intended): after you add the air base, you need to save the config in the miniserver ... Derp!
    Apologies for the lame post! (also I can't seem to remove it?)
