retrofit MR16 GU5.3 LED spots 12VDC Constant Voltage for usage with PWM dimmer
    Just like dimming LED strips, I would like to use PWM dimmers to dim MR16 GU5.3 LED spots.
    As most of those retrofit spots now have built-in electronics to make them 'dimmable' via classic mains dimmers, they do not work for PWM dimmers.
    So what I would need is simple cheap 'non-dimmable' 12V LED spots, with no built-in electronics except for converting AC To DC, that work on a 600Hz PWM DC signal.
    Does anyone know which brands/types might work?
    • 11243
    To many China no name brands out there!
    Order the products you like and test them. Return them if they don't fit.
    Also, in a real store it is usually no problem to buy the LEDs for testing and return them if they don't fit.
    Regards, Christian
      Hi Philip,
      i tested a bunch of MR16 but only the Philips Master LED worked properly (no noise, dimming range OK)
      Osram Parathom Pro - dimmable: noise in dimmed state
      NoName - dimmable: Noise and bad dimming range
      NoName - only with PWM dimmable: little noise and bad dimming range
      I use the PROLED 3ch PWM Dimmer. PWM frequency is unknown.
      regards, Jens
