Ankündigung
Keine Ankündigung bisher.
Zigbee2mqtt - Nedis ZBRC10WT
  • Filter
  • Zigbee2mqtt - Nedis ZBRC10WT
    I can't seem to add the Nedis ZBRC10WT, although it is provided in the zigbee-herdsman-converters.
    I got the following message:
    debug 2021-03-22 21:31:55: Received Zigbee message from '0xbc33acfffe619db3', type 'commandArm', cluster 'ssIasAce', data '{"armmode":3,"code":"","zoneid":23}' from endpoint 1 with groupID 0
    warn 2021-03-22 21:31:55: Received message from unsupported device with Zigbee model 'TS0215A' and manufacturer name '_TZ3000_fsiepnrh'
    warn 2021-03-22 21:31:55: Please see: https://www.zigbee2mqtt.io/how_tos/h...w_devices.html.
    This is listed in tab "devices":
    '0xbc33acfffe619db3':
    friendly_name: '0xbc33acfffe619db3'
    What can I do to solve it? Thank you in advance!
  • #2
    have you already followed this link ?
    There you could read:
    Before starting, first check if you devices is not already supported in the Zigbee2MQTT dev branch! This can done by checking devices.js. Search for example on the Zigbee model from step 1 below.
    within 5 seconds i was able to check "devices.js" in the dev branch and YES in the dev branch your device ('TS0215A') is supported.
    So you simply have to follow the instruction (2. Adding your device #) to get support for your device.
