Ankündigung
Keine Ankündigung bisher.
block with adjustable timer?
I did something similar for our children's night light. To fall asleep, they can activate the light and it turns off again automatically. The lighting duration can be set in the visualization. I use "Ausschaltverzögerung" (don't know the english name, perhaps anyone can help?) and modify the "T"-parameter with a virtual input (analogue).
- Likes 1
Thanks!
Just wanted to be sure before starting a workaround. Thanks also for the suggestions on the workaround!
Jörg
Einen Kommentar schreiben:
Nothing that I know in one block.
For such use-cases I have used comfort switch or … don’t know „Treppenlichtschalter“ (stairway switch?) in combination with a virtual input (analogue) to adjust e.g. the timing of motion sensors.
With analogue selection blocks or status blocks I also can adjust the countdown of these switches.
Christian
- Likes 1
Hello,
Just double checking as I cannot seem to find it... Is there a function block with a timer that it adjustable in the user interface? A bit like you have in the IRC where you can set till when an override is active.
Thanks,
JörgStichworte: -
