Use of memory flags
  • J V
    • 386
    Yes, I misinterpreted your previous post. I was doing the same, but got the impression there was some other way of distinguishing.
    Stupid idea: would it be possible to use the same memory flag as actuator and as sensor (e.g. for lights)? Or better not?
    • Automation
      • 23.08.2015
      • 675
      The memory flag works as Input, where you can store a value. From then on you link the memory flag to other pages, and then they work as an output.
      So I did not get you, what you would like to do..
      Gesendet von meiner Steintafel mit Tapas
      Da staunt der Laie und der Meister wundert sich
      Miniserver seit Jan. 2011
      • J V
        • 386
        Ok... for one light, how many memory flags do you have?
        I currently use 2 : one that shows the current status (taken from the sensor), and one that is used to set the current status (sends its value to the actuator).
        But I wonder if it has to be like this: perhaps one memory flag is enough... read it to get the status, set it to change the actuator. Would that work?
        • Automation
          • 23.08.2015
          • 675
          It depends, sometime I habe only once set to the actuatur, sometimes a dozend. For example, the scene " Good night". I set this with a push button on a page with a scene. Then i have linked the memory flag to more then a dozend actuators, in order to switch all lights of. That mean since I have per page one room, I also have a few links...
          • J V
            • 386
            Ok, but the minimum you would have is 2: one for the status and one for the actuator.
            • Automation
              • 23.08.2015
              • 675
              Yep right.
              • J V
                • 386
                Thanks!
                The config already looks much better and more structured, I might be able to finish it soon (I kept starting, restarting, putting it aside, starting again, ...)!
