Monitoring of Loxberry MQTT gateway keepalive
  • Giovani
    • 18.01.2016
    • 34
    I am trying to implement monitoring of Loxberry MQTT gateway via receiving keepaliveepoch messages. Do somebody have any good hint to implement this in Miniserver (detecting that message was received and that sent value is greater than previously received value).
    BR
    Simply use this logic:
    https://www.loxwiki.eu/pages/viewpag...pageId=6979793
    If you cannot understand the German block names, try the sample Config file.
    You don't need to check if it counts upwards. You only need to check that it changes after more then 60 seconds.
    Zuletzt geändert von Christian Fenzl; 08.02.2021, 10:12.
    • germany1989
      germany1989 kommentierte
      Servus Christian,
      irgendwie scheint der Link nicht mehr zu funktionieren und im Wiki selber find ich nichts...
      Könntest du ihn bitte nochmal aktualisieren? - Stehe vor dem gleichen Problem...
      Besten Dank im Voraus.
  • Giovani
    • 18.01.2016
    • 34
    Christian Fenzl , thanks for hint. My German is not good, but good enough to understand schematics and logic behind.
    • querex
      • 14.07.2020
      • 186
      Christian Fenzl +1 many thanks! Also useful for me
      Smart home: Miniserver Gen2, 2xRelay ext, 2xDimmer ext, 4xExtensions, Tree ext, Air base ext, RGBW dimmer tree, 13xTouch tree, 6xMotion sensor tree, 9xEsylux PD-C 360i 8UC, 15xValve actuator tree, 9xSmoke detector air, 4xSmart socket air, IR control air, Remote air, SDM630 modbus kWh
        Neuer Link:
