In Our project we are using Loxone Miniserver --> RS485 Extension --> OR-WE 514 Electricity counter (third party)
I connected to the counter directly from the computer to give it the address.
The question is how to define the command in Loxone config to get out the information. Like KWh.
And where in the RS485 sensor option do I insert the adres, so many ways to mistake there,
Have set In the RS485 parameters same as they are in the counter (Baud rate, parity etc.)
Do I need to insert the command in sensor "Command recognition" field with the counter address to reach it ?
Why there are no options in RS485 properties for serial protocol ?
A lot of questions.. first time doing this.
COUNTER DATASHEET
https://www.partner.orno.pl/manuals/..._manual_EN.pdf
COUNTER COMMANDS
file:///C:/Users/mkada/AppData/Local/Temp/OR-WE-516_MODBUS_Registers_List.pdf
Hope to get some help!
Thank you!
