http post not working?
  • J V
    • 385
    TLDR; the field "command for on" needs an entry.
    Long version:
    Just struggled a bit getting an http post from Loxone, and discovered something: the field "command for on" has to be filled out. I wanted to send a simple post to a webserver, and assumed I do not need it, but nothing was triggered and no packet could be seen on the network. I entered a dummy command, followed by \r, and now the webserver receives the http post commands. Not sure if this is documented behaviour or expected behaviour, but I lost quite some time because of it. So hopefully this helps others. :-)
    Zuletzt geändert von J V; 22.07.2016, 13:57. Grund: small typo
    afaik in the address of the virtual output you have to enter only the host, like http://myserver (or http://hostort), and in the command for on the rest of the URL, like /dosomething.html
    Regards, Christian
    • J V
      • 385
      In "virtual output" yes. But if in "virtual output command" I just have values for the following
      http post command for on: something
      http method for on: post
      http method for off: get
      then my webserver does not receive anything and I thought there was no packet sent out.
      If I however add a value for the field (in "virtual output command")
      command for on: somethingelse\r
      then the webserver receives "something"
      I'm not sure why it behaves like this, but without "command for on" set, I do not receive anything...
        Ok, I understand. Might be a bug.
        • J V
          • 385
          It took me some time to figure out, so I thought I just post it here in case others have the issue.
          I am still using 7.4.4.14, the web server is the built-in webserver of EventGhost.
            Long version:
            I know this is a bit late to the party but have you reported this to loxone?
            • J V
              • 385
              No... I did not report it: I noticed it after the new version came out and have been unable to test it on the new version (incompatibility with some older phones, so for now I stick with the older version).
