Direktes einbinden des Xiaomi Roborock in Loxone
  • LoxMunich
    antwortet
    Sorry but I don´t understand your hint:
    curl -X 'GET' \
    'https://192.168.178.36/api/v2/robot/capabilities/ConsumableMonitoringCapability' \
    -H 'accept: application/json'​
     [B]Response body[/B]
    Download[
    "__class": "ConsumableStateAttribute",
    "metaData": {},
    "type": "brush",
    "subType": "main",
    "remaining": {
    "value": 18000,
    "unit": "minutes"
    "metaData": {},
    "type": "brush",
    "subType": "side_right",
    "remaining": {
    "value": 12000,
    "unit": "minutes"
    "metaData": {},
    "type": "filter",
    "subType": "main",
    "remaining": {
    "value": 9000,
    "unit": "minutes"
    "metaData": {},
    "type": "sensor",
    "subType": "all",
    "remaining": {
    "value": 1800,
    "unit": "minutes"
    so what is the correct Loxone ´command recognition´ at ´virtual HTTP input command´ if I want to get the value of "type": "brush", "subType": "side_right",?
    Das müsste die Lösung sein:​
    \iConsumableStateAttribute\i\ibrush\i\iside_right\i\ivalue\i\i:\i\v
    UPDATE: Wow, seems to work. Great! Thank you!
    UPDATE 2
    What is the correct command recognition to get the ´time stamp´ (time of last cleaning)?
    [{"__class":"ValetudoDataPoint","metaData":{},"time stamp":"2024-01-02T20:39:17.301Z","type":"time","value":5},{"__cla ss":"ValetudoDataPoint","metaData":{},"timestamp": "2024-01-02T20:39:17.301Z","type":"area","value":0}]
    UPDATE 3
    And what is the correct command recognition to get the first character of ´idle´
    And what is the correct command recognition to get the second character of ´idle´
    And what is the correct command recognition to get the third character of ´idle´
    {"__class":"RobotState","metaData":{"version":1 }," attributes":[{"__class":"StatusStateAttribute","metaData":{} ,"v alue":"idle","flag":"none"},
    das müsste die Lösung sein:
    \iStatusStateAttribute\i\ivalue":"\i\1
    \iStatusStateAttribute\i\ivalue":"\i\s1\1
    \iStatusStateAttribute\i\ivalue":"\i\s2\1
    Zu der ursprünglichen Firmware: "Der Status (idle, cleaning, returning, ...) des Staubsaugerroboters wird nur als Text ausgegeben. Daher werden zur eindeutigen Erkennung die ersten 3 Buchstaben über die Statusbausteine "1.-3. Buchstabe Status" ermittelt und im Nachfolgenden Status-Baustein auf den aktuellen Status des Staubsaugerroboters gemappt. Dort fließen ebenfalls die Fehlercodes und eine Prüfung, ob der Staubsaugerroboter erreichbar ist (Ping-Baustein), mit ein."​
    UPDATE 4
    Und hat irgend jemand schon die aktuelle URL und die aktuelle zugehörige Kennung der früheren Befehlserkennung
    \iStatusStateAttribute\i\ierror_code:\i\v
    gefunden? Also überhaupt die Error Codes?
    Zuletzt geändert von LoxMunich; 02.01.2024, 23:09.
    Einen Kommentar schreiben:
  • Tico
    antwortet
    \iclass\i\itype\i\ivalue\i\i:\i\v
    Liegt das Problem darin, dass “ keine Anführungszeichen sind, sondern zwei senkrechte "?
  • LoxMunich
    antwortet
    Danke dir für die Antwort; die Virtuellen Ausgänge als HHTP habe ich schon mal unter
    https://loxwiki.atlassian.net/wiki/s...cotec+Prosecni c+Commodore+mit+Firmware+Valetudo
    angelegt gehabt; aber mit den virtuellen Eingängen habe ich noch mein Problem:
    Beim Batterieladestatus funktioniert augenscheinlich
    Batterieladestatus "__class": "BatteryStateAttribute"\i"level"\i:"\v" Haken 0 / 0 / 100 / 100 <v> % GET
    ​aber wie kann man den Status auslesen, wenn man auf "type" und "subtype" springen muss?
    "__class":"ConsumableStateAttribute","metaData ":{ },"type":"brush","subType":"main","remaining":{" value":14799,"unit":"minutes"}},
  • Deepflash
    antwortet
    Zitat von LoxMunich
    Könnte bitte jemand die Templates für die Virtuellen Eingänge und Ausgänge nach der neuen API/V2 bereitstellen? Die im LoxWiki unter https://loxwiki.atlassian.net/wiki/s...ges/1600454754 sind ja noch für die alte Firmware-Version
    bzw. was trägt man bei den Virtuellen Eingängen jeweils bei der Befehlserkennung ein?
    https://ip-des-staubsaugerroboters/api/v2/robot/capabilities/ConsumableMonitoringCapability​
    das sind die Ausgabewerte. Aber wie genau ist die Befehlserkennung dazu?
    {"__class":"ConsumableStateAttribute","metaData ":{ },"type":"brush","subType":"main","remaining":{" va lue":14799,"unit":"minutes"}},
    {"__class":"ConsumableStateAttribute","metaData ":{ },"type":"brush","subType":"side_right","remaini ng ":{"value":8799,"unit":"minutes"}},
    {"__class":"ConsumableStateAttribute","metaData ":{ },"type":"filter","subType":"main","remaining":{ "v alue":5799,"unit":"minutes"}},
    {"__class":"ConsumableStateAttribute","metaData ":{ },"type":"sensor","subType":"all","remaining":{" va lue":0,"unit":"minutes"}}
    ich hab meine Robis per MQTT eingebunden, hier Beispielbefehle jeweils als Digitalausgang:
    Pause = Sauger/S5OG/BasicControlCapability/operation/set PAUSE
    Start = Sauger/S5EG/BasicControlCapability/operation/set START
    Stop = Sauger/S5EG/BasicControlCapability/operation/set STOP
    Zum Dock = Sauger/S5EG/BasicControlCapability/operation/set HOME
  • LoxMunich
    antwortet
    Zuletzt geändert von LoxMunich; 29.12.2023, 15:39.
  • Deepflash
    antwortet
    ist vlt. eher ein MQTT-spezifisches Thema aber von all meinen Eingängen die ich mittlerweile von MQTT hab sind folgende aus welchem Grund auch immer "access denied":
    Sauger_S5EG_$state
    Hat das was mit dem Dollarzeichen zu tun? Der in Loxone eingetragene Nutzer hat Vollzugriff und somit gehen auch alle anderen Eingänge, nur aber eben der nicht.
  • Chrissi
    antwortet
    Vielen lieben Dank für eure Hilfe, jetzt hab ich wieder was gelernt. Das mit dem Statusbaustein ist ja mal eine coole Lösung!
  • loxforum
    antwortet
    Zitat von Deepflash
    hat schon jemand versucht bzw. es geschafft (oder ist das gar nicht möglich?), die Map-Visualisierung in Loxone einzubinden?
    Meines Wissens hat Loxone ja keinen Support für Karten in der App. Aber mit dem "Webpage" Baustein kann man die Valetudo Web-App aufrufen.
  • Deepflash
    antwortet
  • loxforum
    kommentierte 's Antwort
    Wiki Eintrag klingt sinnvoll, eventuell sollte ich das ganze auch als einzelne Config extrahieren, sind immerhin 2 Ganze Seiten voll mit Bausteinen.
  • loxforum
    antwortet
    Habe das bei mir ebenfalls über den Status Baustein realisiert, aber auf Basis der einzelnen Segmente/Räume:
Ansichten: 3990
Größe: 11,6 KB
Ansichten: 3803
Größe: 6,8 KB
    Die IDs entweder direkt per API auslesen oder als HTTP Eingang, z.B. über den Namen Klicke auf die Grafik für eine vergrößerte Ansicht
Ansichten: 3912
Größe: 2,2 KB
    Damit kann man dann den z.B. den "Küche saugen" Taster implementieren, oder Küche alle x Tage saugen usw.​​
  • heilmoa
    Für kleine Teile nehmen die meisten wohl Screenshots. Ansonsten wohl das komplette Projekt als .Loxone. Da musst du aber entweder alles rauslöschen was privat bleiben soll, oder in ein neues Projekt migrieren, da müssen dann aber die Ein- und Ausgänge neu angelegt werden.
    Du könntest auch einen eigenen Wiki Eintrag anlegen, oder einen bestehenden überarbeiten?
  • heilmoa
    antwortet
    Zitat von Chrissi
    ich habe es endlich geschafft auf meinen S50 Valetudo aufzuspielen.
    Es gibt aber eine neue API V2 von Valetudo, die Request aus dem Loxwiki funktionieren nicht mehr mit der aktuellen Version.
    Der neue Request zum starten, stoppen usw. sieht dann so aus:
    https://192.168.1.239/api/v2/robot/ca...trolCapability ( hier muss noch start/stop/pause rein?)
    Ich scheitere aber beim Zusammenbauen des Befehls für die Loxone. Ich habe mal zwei Screenshots der API angehängt.
    Vielleicht hat ja jemand eine Idee wie der Befehl aussehen muss?
    Danke und Viele Grüße
    Christian
    Du musst die gleichen Daten wie in deinem Screenshot beim Curl Befehl "mitgeben".
    In der Loxone-Config bedeutet das:
    Befehl bei ein /api/v2/robot/capabilities/BasicControlCapability
    HTTP Header bei ein Content-Type: application/json
    HTTP Body bei ein { "action": "stop" }
    HTTP Methode bei EIN PUT
    Am Einfachsten ist, du machst dir je action einen virtuellen Befehl und änderst jeweils den Body (Start, Stop, Pause,...)
    Alternativ:
    Kannst du den Http Body auch innerhalb der Config über einen Status Baustein machen.
    So sieht das bei mir aus (ist aber ValetudoRE):
Ansichten: 4127
Größe: 25,0 KB
    In LoadMap ist der HTTP Body dann: <v> (damit wird der Wert aus dem Status Baustein übergeben und für den API Aufruf verwendet)​
  • loxforum
    antwortet
    Wie shared man hier am besten Teile einer LoxConfig? Ich habe mittlerweile eine recht umfangreiche Implementierung, basieren auf diversen Posts hier im Forum, Loxwiki und meiner eigenen Logik, welche dem ein oder anderen helfen könnte.
  • Chrissi
    antwortet
    Christian
