Combining visualisations
  • Maarten.Provo
    • 16.11.2020
    • 16
    Hello
    I've a quite some virtual inputs and commands to do stuff that aren't exactly native to loxone. I was wondering if there is a way to combine visualisations for these virtual inputs in the app in to one tile? If you take loxone's own alarm-tile for example: It will show you the state of the alarm, but when you click on it, you can interect: activate/deactivate it, or see the history.
    I have a state building block to show which trash to take out today and a switch to tell loxone it's been done. Both are seperate tiles, which I would like to combine like the alarm. I want it to show the state and when I click on it I want the option to flip the switch that it's been done.
    I've a similar setup for my Roomba. I have a state to show what the Roomba is doing and a switch to activate it.
    Any ideas?
    Regards
  • J V
    • 370
    (this should probably in the English section...)
    I have a bit the same problem: trying to combine visualisation of multiple things with actions. I'm using status blocks to combine the visualisation. Such a block contains many statuses, as I like to use custom icons for a quick visualisation (the icon is a combination of indicators, which means I need to make images for all possible combinations of the visualised indicators).
    With those status blocks, I link the blocks that have switches or other things to activate things. It is not the most elegant, but it allows me a quick entry point that displays status and allows access to various controls.
    Jörg
    • Haidy
      • 01.06.2016
      • 413
      Maybe this is a solution: https://www.loxone.com/dede/kb/bausteine-verlinken/
      • Maarten.Provo
        • 16.11.2020
        • 16
        Great, exactly what I was looking for. Thank you!
