Loxforum kompromittiert?
    „Zufällig“ kommt keine Werbung 😂
    • TomekWaw
      • 25.07.2019
      • 450
      #32
      Ok, I got this again ~20 minutes ago.
      This time I made a screenshot, so this is a real URL/page popped up instead of forum page.
      Like before this popped up when entering loxforum from Google search results.
      First link led to https://www.loxforum.com/forum/hardw...tem-and-loxone
      I've also made a screenshot and copy of relevant search results html code:
      HTML-Code:
      <h1 class="bNg8Rb">Wyniki wyszukiwania</h1><div eid="n_nEXceoIsOtrgT92Ie4Cw" data-async-context="query:loxone%20sonos" id="rso"><div class="bkWMgd"><h2 class="bNg8Rb">Wyniki wyszukiwania w sieci</h2><div class="srg"><div class="g"><!--m--><div data-hveid="CAQQAA" data-ved="2ahUKEwiH9MvP7dnlAhXDlosKHX3sAbcQFSgAMAB6BAgEEAA"><div class="rc"><div class="r"><a href="https://www.loxforum.com/forum/hardware-miniserver-extensions/16956-sonos-system-and-loxone" ping="/url?sa=t&amp;source=web&amp;rct=j&amp;url=https://www.loxforum.com/forum/hardware-miniserver-extensions/16956-sonos-system-and-loxone&amp;ved=2ahUKEwiH9MvP7dnlAhXDlosKHX3sAbcQFjAAegQIBBAB"><h3 class="LC20lb">Sonos System and Loxone - loxforum.com</h3><br><div class="TbwUpd"><cite class="iUh30 bc">https://www.loxforum.com &rsaquo; forum &rsaquo; 16956-sonos-sys...</cite></div></a><span><div class="action-menu ab_ctl"><a class="GHDvEf ab_button" href="#" id="am-b0" aria-label="Opcje wyników" aria-expanded="false" aria-haspopup="true" role="button" jsaction="m.tdd;keydown:m.hbke;keypress:m.mskpe" data-ved="2ahUKEwiH9MvP7dnlAhXDlosKHX3sAbcQ7B0wAHoECAQQAw"><span class="mn-dwn-arw"></span></a><div class="action-menu-panel ab_dropdown" role="menu" tabindex="-1" jsaction="keydown:m.hdke;mouseover:m.hdhne;mouseout:m.hdhue" data-ved="2ahUKEwiH9MvP7dnlAhXDlosKHX3sAbcQqR8wAHoECAQQBA"><ol><li class="action-menu-item ab_dropdownitem" role="menuitem"><a class="fl" href="https://webcache.googleusercontent.com/search?q=cache:gjLgCqtxT38J:https://www.loxforum.com/forum/hardware-miniserver-extensions/16956-sonos-system-and-loxone+&amp;cd=1&amp;hl=pl&amp;ct=clnk&amp;gl=pl" ping="/url?sa=t&amp;source=web&amp;rct=j&amp;url=https://webcache.googleusercontent.com/search%3Fq%3Dcache:gjLgCqtxT38J:https://www.loxforum.com/forum/hardware-miniserver-extensions/16956-sonos-system-and-loxone%2B%26cd%3D1%26hl%3Dpl%26ct%3Dclnk%26gl%3Dpl&amp;ved=2ahUKEwiH9MvP7dnlAhXDlosKHX3sAbcQIDAAegQIBBAF">Kopia</a></li><li class="action-menu-item ab_dropdownitem" role="menuitem"><a class="fl" href="/search?rlz=1C1GCEU_plPL843PL843&amp;sxsrf=ACYBGNQQQVW6Vzl6vq-JzKCbjtMp9WZePw:1573190047568&amp;q=related:https://www.loxforum.com/forum/hardware-miniserver-extensions/16956-sonos-system-and-loxone+loxone+sonos&amp;tbo=1&amp;sa=X&amp;ved=2ahUKEwiH9MvP7dnlAhXDlosKHX3sAbcQHzAAegQIBBAG">Podobne</a></li></ol></div></div></span><a class="fl" href="https://translate.google.com/translate?hl=pl&amp;sl=en&amp;u=https://www.loxforum.com/forum/hardware-miniserver-extensions/16956-sonos-system-and-loxone&amp;prev=search" ping="/url?sa=t&amp;source=web&amp;rct=j&amp;url=https://translate.google.com/translate%3Fhl%3Dpl%26sl%3Den%26u%3Dhttps://www.loxforum.com/forum/hardware-miniserver-extensions/16956-sonos-system-and-loxone%26prev%3Dsearch&amp;ved=2ahUKEwiH9MvP7dnlAhXDlosKHX3sAbcQ7gEwAHoECAQQCA">Tłumaczenie strony</a></div><div class="s"><div><div class="slp f">22 gru 2015 - 15 wpisów - ‎8 autorów</div><span class="st">How well does <em>Loxone</em> play with <em>Sonos</em>? As in, can I integrate <em>Sonos</em> into the <em>Loxone</em> ecosystem in order to stop music playing when something&nbsp;...</span><div class="P1usbc" data-ved="2ahUKEwiH9MvP7dnlAhXDlosKHX3sAbcQqwIwAHoECAQQCg">
      I hope it helps to nail down the problem.
      I believe forum moderators/admin see my IP address and may also use it to grep morning logs to check my incoming request
      Zuletzt geändert von TomekWaw; 08.11.2019, 05:45.
        Hatte heute wieder nen redirect. Google Link => Loxforum .. erstes Aufrufen => Weiterleitung zu Spam-Page. Zweites Aufrufen kein Problem
