Dimmer with timer function
    I’m kind of new to loxone and having several questions on how to configure my loxone.
    In this case I have configured a timer function on my lights in the hallway. Meaning that when you click ones a timer is set for 5 min before the lights go out automatically. When you hold for 3 seconds they remain on and click again the lights go out.
    In one hallway the lights can be dimmed because the ligths are to bright so I want them dimmed till 60%.
    How is it possible to have the same functionality: having a timer for 5 min, lights dimmed to 60%. With overrides?
    thank you very much.
    br,
    Stefaan
    Hi Stefaan,
    you can use the “Analogwahlschalter” (in English called somewhat like Analogue Selection Switch)
    Online-Dokumentation LoxoneConfig Programmbaustein Analogwahlschalter: Erfahren Sie wie Sie über einen Eingang zwischen 2 Analogwerten auswählen können.
    You have a selector input and two analogue inputs.
    The first analogue input stays unconnected (=0), the second with value 60 or 6 (depending to your dimmer).
    The selector input is connected to your switch.
    So the switch toggles between 0 and 60.
      Hi Christian,
      Thank you for your prompt response!
      2 questions:
      1. How do I enter the value 60 into the selection switch (I never used that)?
      2. Where do I connect the multifunction switch to have a timer functionality? Ex. Switch button > Tr (multifunction) & Q > S of analogue?
      Thx again.
        1. You can use e.g. a Constant or a slider.
        2. Currently I don’t understand. Possibly you better add us a screenshot.
          1. ok I added it
          2. see picture in attach (hope it is clear )
