Pioneer operate withIP
    I cant connect to my Pioneer VSX-S510 throug loxone. By Hercules (small TCP client program), i can send operating commands. When I try the same with loxone the AMP recive nothing.
    Can someone help me?
    Thxs
  • pb318
    • 18.09.2015
    • 3
    I control Pioneer VSX-922 through LAN. Create virtual output for Pioneer and then you can use predefined commands for Pioneer AVR in Loxone config
      I renewed the IP address (for the 4th time), now it works.
      Thanks!
        Hi Jelle,
        I wonder if you could test/confirm two things for me?!
        I am thinking of getting the same receiver as you but I would like to know if it has the two features I need.
        1. Dose the S510 have absolute volume commands?
        Example send "Vol 50", to adjust the volume with a command with an absolute value (some Pioneers only have "Vol Up" - and "Vol Down")
        2. Do you know if S510 have the capability to actively push status changes (e.g. changes done directly on the receiver) without the need to call a poll command?
        I would appreciate if you can help me answer these two question!
        Joachim
        If you read German the author is asking for these two features.
        Da zu einem vollständigen Smart Home auch eine Multimediasteuerung gehört, steht heute einmal die Einbindung eines Pioneer AVR-Receivers auf dem Plan. Er
          Hi Joachim,
          The S510 has no absolute volume control.
          With the loxone server I can directly send a command. Turn on the amplifier and then start te internet radio is working properly. At the moment is this the only thing I use. Jelle
            Jelle, thanks for answering!
            Can anybody confirm if Pioneer VSX-1131 has absolute volume commands and push status changes (see my post above)?!
