My message to Loxone regarding the bug of 1/1/2016. Would they consider ope-sourcing the software I we keep asking long enough ??
Dear Loxone,
The bug that affected many miniservers on the 1th of january is regrettable, but as a miniserver is a complex piece of engineering it probably won't be the last one. The fact that your engineers found the problem and proposed a workaround in 24h is very good, but I am convinced there is a way to tackle this kind of support in a quicker way.
If you would open-source the software of the mini-server and the extensions for example as github projects, I am sure the community would have found a solution within hours from when the bug surfaced. Then the community would be able to help each other and you as a company could benefit from the wisdom of the crowd.
I can understand if you are reluctant to open source your software, but there are many examples of companies that succesfully open sourced their software, and still be a profitable business. After all, you are selling the hardware. Some people would choose to use the official Loxone software because there is support. Other people will choose to use a community adapted version of the software. As a gatekeeper of the gihub project you are in full control of the official branch of the software, you are the one that chooses if pull requests from the community make it to through to the official branch, and which not.
I'm not sure if my message makes a difference, but I am hoping that you seriously consider the option to open source the software, so people can improve it, fix bugs, helping each other, and helping Loxone to become an even beter platform for home automation.
My best regards,
Jeroen
Open hardware, open firmware, open everything.
