Json auslesen
    Json auslesen
    Guten abend
    Ich habe eine frage zu virtuelle eingänge. Ich habe eine Enphase Envoy photovoltaik system. Mit json kann ich die daten auslesen:
     {"production":[{"type":"inverters","activeCount":18,"readingTime":1573326966,"wNow":0,"whLifetime":344182},{"type":"eim","activeCount":1,"measurementType":"production","readingTime":1573327022,"wNow":-2.871,"whLifetime":14561.397,"varhLeadLifetime":0.044,"varhLagLifetime":15788.111,"vahLifetime":26601.687, "rmsCurrent":0.351,"rmsVoltage":232.685,"reactPwr":81.758,"apprntPwr":81.758,"pwrFactor":0.0,"whToday":2970.397,"whLastSevenDays":13265.397,"vahToday":4237.687,"varhLeadToday":0.044,"varhLagToday":1821.111}], "consumption":[{"type":"eim","activeCount":1,"measurementType":"total-consumption","readingTime":1573327022,"wNow":232.995,"whLifetime":81891.633,"varhLeadLifetime":60313.993,"varhLagLifetime":15792.297, "vahLifetime":117078.799,"rmsCurrent":2.233,"rmsVoltage":232.683,"reactPwr":-409.985,"apprntPwr":519.507,"pwrFactor":0.45,"whToday":11655.633,"whLastSevenDays":78194.633,"vahToday":15597.799,"varhLeadToday":6922.993,"varhLagToday":1822.297}, {"type":"eim","activeCount":1,"measurementType":"net-consumption","readingTime":1573327022,"wNow":235.866,"whLifetime":74113.142,"varhLeadLifetime":60313.949,"varhLagLifetime":4.186,"vahLifetime":117078.799, "rmsCurrent":1.881,"rmsVoltage":232.681,"reactPwr":-328.227,"apprntPwr":437.672,"pwrFactor":0.53,"whToday":0,"whLastSevenDays":0,"vahToday":0,"varhLeadToday":0,"varhLagToday":0}],"storage": [{"type":"acb","activeCount":0,"readingTime":0,"wNow":0,"whNow":0,"state":"idle"}]}
    Wenn ich probiere das "wNow" zu lesen bekomme ich 0.
    Ich habe das alst folgt versucht:
    "wNow":\v
    oder
    \i[{"type":\i "wNow":\v
    Mit
    "wattHoursToday": \v
    bekomme ich 2970 von ein html seite
     {   "wattHoursToday": 2970,   "wattHoursSevenDays": 13265,   "wattHoursLifetime": 14561,   "wattsNow": -2 }
    gibt das dan ein problem mit json?
    Vielen dank für ihre hilfe!
    • 6326
    Dein Problem ist, dass wNow häufiger im JSON vorkommt. Du müsstest schon genau wissen welches Du haben willst und den Suchstring dementsprechend aufbauen.
    • Tico
      • 31.08.2016
      • 1035
      Ich bin mir nicht sicher, welches "wNow" du willst?
      Für den Ersten -
      "wNow":\v
      Für den Zweiten -
      \i"wNow"\i\i"wNow":\i\v
      Für den Dritten -
      \i"wNow"\i\i"wNow":\i\i"wNow":\i\v
      etc.
        Vielen dank, ich habe das geprobiert mit
        aber das funktioniert nicht.
        Für den Ersten -
        "wNow":\v
        Für den Zweiten -
        Für den Dritten -
        etc.
        Auch vielen dank, aber das funktioniert auch nicht.
        Ich werde es mit Wireshark suchen.
        • Tico
          • 31.08.2016
          • 1035
          Klicken Sie mit der rechten Maustaste auf die zurückgegebene JSON-Seite und sehen Sie die Seitenquelle.
          Veröffentliche einen Screenshot von diesem rohen JSON.
            • 6326
            Gast da brauchst Du auch nicht Wireshark bemühen. Die Antwort ist ein JSON und genau wie „wNow“ mehrfach vorkommt, kommt auch type .... wNow mehrfach vor. Du musst Dir wie schon gesagt etwas einzigartiges vor dem gewünschten wNow suchen. Im Übrigen wäre Deine Suche
            sowieso falsch, da Du nach [{"type": "wNow": suchst und das kommt so nie vor. Die Suche mit exakt sein, mit allen Leerzeichen und Zeilenumbrüchen etc. Die Suche würde überhaupt erst funktionieren wenn Du
            [{"type":\i"wNow"\i:\v suchen würdest. Aber dazu müsste wie gesagt der Teil vor dem gewünschten wNow einzigartig sein
              Tico
              Click image for larger version  Name:	Knipsel.JPG Views:	0 Size:	117.4 KB ID:	219629
              Dan habe ich eine problem weil das "wNow" immer mit dem gleichen vor geht. Muss ich was mot einem raspberry pi machen?
              [EDIT]
              Nur noch ein mal geschaut, aber die wattHoursToday hat dies als seitenquelle:
Ansichten: 1554
Größe: 12,7 KB
ID: 219632 Das <html><body><pre> und </pre></body></html> kann ich nicht in der anderen sehen. Ist das das problem?
              Zuletzt geändert von Gast; 10.11.2019, 12:12.
                • 6326
                Die Frage ist ja, was soll der Raspi machen, wenn Du nicht weißt welchen der ganzen Werte Du haben willst?!
                  Ich will de vier ersten "wNow" lesen. Das die production, consumption. Wenn ich es habe, kann ich das gebrauchen für eine Energieessung.
                  • Tico
                    • 31.08.2016
                    • 1035
                    Was verwirrend ist, ist, dass die Befehlserkennung, die bereitgestellt wird, anhand der verfügbaren Informationen funktionieren sollte.
                    Vielleicht können Sie einen Screenshot der Eigenschaften Ihrer virtuellen Eingabe einschließlich des Polling-Intervalls zur Verfügung stellen. Etwas könnte sich zeigen.
                      • 6326
                      Ich denke die gewünschten Werte passen am Besten zum 2. wNow
                      Versuche also mal "measurementType":"production"\i"wNow"\:\v
                        • 11238
                        Das was Tico geschrieben hat, müsste eigentlich auch schon funktionieren.
                        Gast Du weißt, dass du bei jeder Änderung im Miniserver speichern musst?
                          • 6326
                          Was auch noch wichtig ist, dass mindestens eine Wiederholungszeit gewartet werden muss!
                            Zu ihrer information
                            Ich habe ein Python-script geschrieben, um alles zu lesen.
                            Dieses script sendet alles über virtuelle eingangen an den miniserver.
                            Danke für ihre hilfe und Loxberry to the rescue
                            • mr-manuel
                              • 20.03.2021
                              • 126
                              Falls noch jemand auf Google nach Enphase Envoy-S Gateway in Kombination mit Loxone sucht und hier landet, hier eine Vorlage für den Virtual HTTP Input:
                              <?xml version="1.0" encoding="utf-8"?>
                              <VirtualInHttp Title="Enphase Envoy-S Gateway" Comment="" Address="http://192.168.1.123/production.json" PollingTime="30">
                              <Info templateType="2" minVersion="12021201"/>
                              <VirtualInHttpCmd Title="cons_net_whLifetime" Comment="" Check="&quot;measurementType&quot;:&quot;net-consumption&quot;\i&quot;whLifetime&quot;\i:\v" Signed="true" Analog="true" SourceValLow="0" DestValLow="0" SourceValHigh="100" DestValHigh="100" DefVal="0" MinVal="-10000" MaxVal="10000"/>
                              <VirtualInHttpCmd Title="cons_net_whToday" Comment="" Check="&quot;measurementType&quot;:&quot;net-consumption&quot;\i&quot;whToday&quot;\i:\v" Signed="true" Analog="true" SourceValLow="0" DestValLow="0" SourceValHigh="100" DestValHigh="100" DefVal="0" MinVal="-10000" MaxVal="10000"/>
                              <VirtualInHttpCmd Title="cons_net_wNow" Comment="" Check="&quot;measurementType&quot;:&quot;net-consumption&quot;\i&quot;wNow&quot;\i:\v" Signed="true" Analog="true" SourceValLow="0" DestValLow="0" SourceValHigh="100" DestValHigh="100" DefVal="0" MinVal="-10000" MaxVal="10000"/>
                              <VirtualInHttpCmd Title="cons_total_whLifetime" Comment="" Check="&quot;measurementType&quot;:&quot;total-consumption&quot;\i&quot;whLifetime&quot;\i:\v" Signed="true" Analog="true" SourceValLow="0" DestValLow="0" SourceValHigh="100" DestValHigh="100" DefVal="0" MinVal="-10000" MaxVal="10000"/>
                              <VirtualInHttpCmd Title="cons_total_whToday" Comment="" Check="&quot;measurementType&quot;:&quot;total-consumption&quot;\i&quot;whToday&quot;\i:\v" Signed="true" Analog="true" SourceValLow="0" DestValLow="0" SourceValHigh="100" DestValHigh="100" DefVal="0" MinVal="-10000" MaxVal="10000"/>
                              <VirtualInHttpCmd Title="cons_total_wNow" Comment="" Check="&quot;measurementType&quot;:&quot;total-consumption&quot;\i&quot;wNow&quot;\i:\v" Signed="true" Analog="true" SourceValLow="0" DestValLow="0" SourceValHigh="100" DestValHigh="100" DefVal="0" MinVal="-10000" MaxVal="10000"/>
                              <VirtualInHttpCmd Title="prod_rmsCurrent" Comment="" Check="&quot;measurementType&quot;:&quot;production&quot;\i&quot;rmsCurrent&quot;\i:\v" Signed="true" Analog="true" SourceValLow="0" DestValLow="0" SourceValHigh="100" DestValHigh="100" DefVal="0" MinVal="-10000" MaxVal="10000"/>
                              <VirtualInHttpCmd Title="prod_rmsVoltage" Comment="" Check="&quot;measurementType&quot;:&quot;production&quot;\i&quot;rmsVoltage&quot;\i:\v" Signed="true" Analog="true" SourceValLow="0" DestValLow="0" SourceValHigh="100" DestValHigh="100" DefVal="0" MinVal="-10000" MaxVal="10000"/>
                              <VirtualInHttpCmd Title="prod_whLifetime" Comment="" Check="&quot;measurementType&quot;:&quot;production&quot;\i&quot;whLifetime&quot;\i:\v" Signed="true" Analog="true" SourceValLow="0" DestValLow="0" SourceValHigh="100" DestValHigh="100" DefVal="0" MinVal="-10000" MaxVal="10000"/>
                              <VirtualInHttpCmd Title="prod_whToday" Comment="" Check="&quot;measurementType&quot;:&quot;production&quot;\i&quot;whToday&quot;\i:\v" Signed="true" Analog="true" SourceValLow="0" DestValLow="0" SourceValHigh="100" DestValHigh="100" DefVal="0" MinVal="-10000" MaxVal="10000"/>
                              <VirtualInHttpCmd Title="prod_wNow" Comment="" Check="&quot;measurementType&quot;:&quot;production&quot;\i&quot;wNow&quot;\i:\v" Signed="true" Analog="true" SourceValLow="0" DestValLow="0" SourceValHigh="100" DestValHigh="100" DefVal="0" MinVal="-10000" MaxVal="10000"/>
                              </VirtualInHttp>
                              Den Code als *.XML unter "Dokumente\Loxone\Loxone Config\Templates\VirtualIn" speichern und die Loxone Config neu öffnen.
                              Die IP Adresse muss natürlich noch angepasst werden.
                              Falls jemand selbst die HTTP Eingänge anlegen will hier ein Beispiel der verwendeten Befehlserkennung:
                              "measurementType":"production"\i"wNow"\i:\v
                              ACHTUNG: Die lokale API wurde mit der neusten Firmware vom Envoy-S geschlossen, man kann jedoch beim Support ein Downgrade auf Version D5 anfragen. Mehr Infos gibt es hier: https://support.enphase.com/s/questi...vity-to-envoys
