Ich muss einen http-Befehl senden:
Dies ist die Kette:
https://www.mundosms.es/APIv2/sendcall.php?username=XXX&password=XXX&destination=34666666666&xmlplan=%3C?xml%20version=%221.0%22%20encoding=%22UTF-8%22?%3E%3Cdialplan%20only_human=%221%22%3E%20%20%3Csleep%20seg=%220%22%20ms=%22500%22/%3E%20%20%3Civr%20text=%22Alarma%20de%20Fuego,%20pulse%209%20para%20validar.%22%20force_create=%221%22%20n_digits=%221%22%20init_timeout=%226%22%20text_error=%22Ha%20pulsado%20una%20opci%C3%B3n%20no%20v%C3%A1lida%22%20max_repeat=%225%22%3E%20%20%20%20%3Ckey%20value=%229%22/%3E%20%20%20%20%3Ckey%20value=%22NO_MATCH%22%20repeat=%222%22/%3E%20%20%3C/ivr%3E%20%20%3Chttp-request%20method=%22post%22%3E%3C!%5BCDATA%5Bhttp://user:pass@miniserver:7000/dev/sps/io/Text2SIP_1/%5BLAST_KEY%5D%5D%5D%3E%3C/http-request%3E%20%20%3Cemail%20destination=%22name.surname@gmail.com%22%20sender=%22pbx@mundosms.es%22%20subject=%22Llamada%20de%20%5BPHONE%5D%22%3E%3C!%5BCDATA%5BAlarma%20de%20fuego%20enviada%20al%20tel%C3%A9fono%20%20%5BPHONE%5D%20a%20las%20%5BDATETIME%5D.El%20usuario%20puls%C3%B3%20%5BLAST_KEY%5D%5D%5D%3E%3C/email%3E%3C/dialplan%3E&sender=34938978068&name=Alerta%20de%20Fuego&description=Alerta%20de%20Fuego&n_max_concurrent=2&delay_calls=30&d_start=2020-04-16&d_end=2050-12-31&h_start=00:00&h_end=23:59&days_span=1%7C1%7C1%7C1%7C1%7C1%7C1&delay_nextcall=60&n_max_donotanswer=10&n_max_busy=10&n_max_off=10&n_max_answeringmachine=10&n_max_fax=1&n_max_totalretries=10
Irgendwelche Ideen?
Entschuldigung für mein Deutsch.
danke
