desktop environment on loxberry --> resolution issue
  • DaniG
    • 10.01.2021
    • 8
    hey guys,
    as this is my first post on the forum, I'd like to say "hallo" to everyone.
    cool to have such a loxone-friendly place
    Unfortunately I don't speach German good enough, thus I'm writing in english. Hopefuly it's not a big problem.
    so much for the introduction, let's get to the point.
    I've got a problem with desktop environment on loxberry.
    Have anyone already configured it successfully on raspberry pi 3b ?
    Basically it works, but I can't set proper resolution.
    I'm using 24" monitor connected to RPI by HDMI cable. The screen is vertically oriented.
    root@loxberry:~# tasksel[*] Debian desktop environment │[*] ... MATE
    (tried also gnome, cinamon, xfce,lxde etc. )
    I tried several display managers:
    gdm3
    lightdm
    sddm
    xdm
    few configs from /boot/config.txt:
    display_rotate=1
    hdmi_group=1
    hdmi_mode=16
    Once I log in GUI, settings --> display I see "unknown display" and I can't change display resolution.
    root@loxberry:/usr/share/xsessions# tvservice -s
    state 0xa [HDMI DMT (4) RGB full 4:3], 640x480 @ 60.00Hz, progressive
    root@loxberry:/usr/share/xsessions# tvservice -m CEA
    Group CEA has 9 modes:
    mode 1: 640x480 @ 60Hz 4:3, clock:25MHz progressive
    mode 2: 720x480 @ 60Hz 4:3, clock:27MHz progressive
    mode 3: 720x480 @ 60Hz 16:9, clock:27MHz progressive
    mode 4: 1280x720 @ 60Hz 16:9, clock:74MHz progressive
    (native) mode 16: 1920x1080 @ 60Hz 16:9, clock:148MHz progressive
    mode 17: 720x576 @ 50Hz 4:3, clock:27MHz progressive
    mode 18: 720x576 @ 50Hz 16:9, clock:27MHz progressive
    mode 19: 1280x720 @ 50Hz 16:9, clock:74MHz progressive
    mode 31: 1920x1080 @ 50Hz 16:9, clock:148MHz progressive
    root@loxberry:/usr/share/xsessions# tvservice -m DMT
    Group DMT has 18 modes:
    (prefer) mode 4: 640x480 @ 60Hz 4:3, clock:25MHz progressive
    mode 5: 640x480 @ 72Hz 4:3, clock:31MHz progressive
    mode 6: 640x480 @ 75Hz 4:3, clock:31MHz progressive
    mode 8: 800x600 @ 56Hz 4:3, clock:36MHz progressive
    mode 9: 800x600 @ 60Hz 4:3, clock:40MHz progressive
    mode 10: 800x600 @ 72Hz 4:3, clock:50MHz progressive
    mode 11: 800x600 @ 75Hz 4:3, clock:49MHz progressive
    mode 16: 1024x768 @ 60Hz 4:3, clock:65MHz progressive
    mode 17: 1024x768 @ 70Hz 4:3, clock:75MHz progressive
    mode 18: 1024x768 @ 75Hz 4:3, clock:78MHz progressive
    mode 21: 1152x864 @ 75Hz 4:3, clock:108MHz progressive
    mode 28: 1280x800 @ 60Hz 16:10, clock:83MHz progressive
    mode 35: 1280x1024 @ 60Hz 5:4, clock:108MHz progressive
    mode 36: 1280x1024 @ 75Hz 5:4, clock:135MHz progressive
    mode 47: 1440x900 @ 60Hz 16:10, clock:106MHz progressive
    mode 58: 1680x1050 @ 60Hz 16:10, clock:146MHz progressive
    mode 83: 1600x900 @ 60Hz 16:9, clock:108MHz progressive
    mode 85: 1280x720 @ 60Hz 16:9, clock:74MHz progressive
    I'm stuck in this place.
    If anyone could help, I will be much grateful
  • hme0354
    • 06.07.2019
    • 999
    the loxberry has no desktop environment. You can only geht to the GUI through the webbrowser simply with the IP of the loxberry.
    • DaniG
      • 10.01.2021
      • 8
      yes, there is a loxberry's GUI available on web browaser.
      However, It's also possible to enable desktop environment, which I have done. Basically it's working, and I do see loxberry GUI on my screen. There is just a problem with correct screen resolution in my case.
        • 7442
        Maybe it's possible, intended by the Loxberry Team.
        So don't use things that are not provided, it ends in issues with plugins etc.
        • hme0354
          hme0354 kommentierte
          it will maybe work till the next update
        LoxBerry is Raspberry OS based on Debian Buster.
        You may check the Raspberry forum for settings for the X environment.
