Web interface after installation Loxberry
    Hello,
    Unfortunately, I do not speak German, so my post is in English.
    I am complete new to Loxberry and I am trying to set it up. I managed to start the system from the image, however, I cannot open the user interface. After booting I only get the command prompt (loxberry@loxberry) and cannot find the way how to open web interface. The LAN connection works, the IP address was assigned.
    What are the steps I should do to load the GUI?
    Thanks a lot for any help.
  • punctuele
    • 23.10.2019
    • 18
    Hello,
    in a webbrowser: type in the IP of the loxberry.
    After that you will be prompted to log in with username (loxberry) and password.
    regards.
    Smarthome: 2x Mini server Gen1, 2xDimmer extensions, 7xExtensions, 1x Relay Extension, Tree extension, Air base extension, RGBW air dimmer, NFC Keypad Tree
    Multimedia: MS4H on PI3B with 4 zones + Russound D850 + B&W M1 speakers
    Peripherals: Loxberry on PI3B, Youless
      Hello,
      Thank you for your response. The problem is that I am not able to open the web browser. After booting and entering the login details the command prompt comes up and I do not know how to continue. Is there any command to open the web browser?
      Thanks a lot.
        • 5081
        You have to open the web browser on your computer NOT on the Rapsberry.
          I see , thank you very much. I will test tonight and will report back.
            I managed to get the web browser interface to work . Thanks a lot for your help.
