Config 12.4 beta 6: Tunable White & HCL on RGBW Tree & Air Dimmers !
  • Pippo74
    • 13.01.2018
    • 227
    I've just looked at the last beta version of Loxone config... and after years of requests... in the middle of nowhere and without any Announcements nor Fireworks...
    and just before the 29th June big shouting:
    Here you go with a surprise not expected at all !
    Technical Changelog Config 12.4 Beta 6:
    New
    Tunable white feature is supported by the RGBW Air and Tree dimmer
    • use .CN Certificate-TLD for Miniservers located in China (based on Country-Code CN in Document)
    • New updated documentation for all controls
      • New input/parameter/output names & descriptions
      • New control documentations
    • Lightcontroller: HCL (Human Centric Lighting): daytime-based light temperature curve
    • Dimmer Air / Tree: Add Support for Tunable White
    What I can say more ?
    W O W !
    Johannes Bartnitzke
    Florian
    Thank you guys, you are now back on the rails of a real Smart home !
    Zuletzt geändert von Pippo74; 23.06.2022, 21:39.
  • Florian
    Loxonaut
    • 24.08.2015
    • 129
    Enjoy!
    • Klartext
      • 426
      I really hope the DMX Extension works also with it
      • Hintertupfing
        Hintertupfing kommentierte
        Am RGBW DMX Aktor kann man es zumindest schon aktivieren.
      • Klartext
        Klartext kommentierte
        Ja steht auch im Beta 3 Changelog, schön das uns hier Loxone nicht vergisst
        Generell scheint es eine sehr vielversprechende Release zu werden
    • Miep Miep
      • 18.01.2017
      • 536
      Endlich mal wieder ein Super Basisfeature. Bin auf das erste Feedback hier gespannt, da das bei mir auch noch ein Thema wird.
      • Pippo74
        Pippo74 kommentierte
        Trying it...
        1) If you've a full TW dimmer, Actuator type should be set to: "Smart Tunable White":
        TW1: Ch1 (WW) and Ch2 (CW)
        TW2: Ch3 (WW) and Ch4 (CW)
        2) If you're going to have just 1 TW, Actuator type should be set to: "Smart Tunable White + Single Channels":
        - Ch 1 (WW) and Ch2 (CW) are for TW
        - Ch 3, Ch 4 are for Single Smart channels.,
        Gast Bartnitzke
        @Florian
        Especially with case n.2, it's not really self-explaining; you need to respect RGBW dimmer wiring to have a correct handling of the TW channel.
    • Andre2
      • 21.06.2022
      • 58
      VERY INTERESING Pippo74.
      Where do I find what you explained above ?​
      I assume in the "RBG Lighting Controller"
Ansichten: 552
Größe: 52,7 KB
      but no such settings herein.
      My Loxone Config is 13.0.7.26​​
      I'm a total novice with LOXONE. This is the first time ever that I try to control LED lamps with an RGBW 24 Dimmer ​
      So my question potentially is stupid ...
      I screenshot would help (and be appreciated of couse) to copy / understand what you have programmed to control 2 tunable with LED Strips.
      • Pippo74
        Please use the Lighting controller.
    • Andre2
      • 21.06.2022
      • 58
      ... I found it
Ansichten: 452
Größe: 20,9 KB
Ansichten: 465
Größe: 28,8 KB
      Next step get the LEDs to light somehow .. which is challenging for a beginner. I will make it somehow .
