Virtueller HTTP Eingang Befehl Ahoy DTU auslesen Ohne MQTT
  • newsted
    • 30.05.2021
    • 58
    Ich lese die Werte meiner AhoyDTU (und auch die der OpenDTU) von deren API Schnittstelle aus
    Bei Ahoy DTU Hier zu finden: ahoy-dtu/api/record/live
    Bei Open DTU Hier zu finden: 192.x.x.x/api/livedata/status
    Bei der Ahoy DTU gibt es mit diesem Weg allerdings folgendes Problem:
    Hier ein Auszug aus der API:
    PHP-Code:
    {"inverter":[[{"fld":"U_DC","unit":"V","val":"37.40"},{"fld":"I_DC","unit":"A","val":"1.26"},{"fld":"P_DC","unit":"W","val":"47.00"},{"fld":"YieldDay","unit":"Wh","val":"715.00"},{"fld":"YieldTotal","unit":"kWh","val":"108.90"},{"fld":"Irradiation","unit":"%","val":"12.37"},{"fld":"U_DC","unit":"V","val":"37.00"},{"fld":"I_DC","unit":"A","val":"1.47"},{"fld":"P_DC","unit":"W","val":"54.60"},{"fld":"YieldDay","unit":"Wh","val":"845.00"},{"fld":"YieldTotal","unit":"kWh","val":"143.99"},{"fld":"Irradiation","unit":"%","val":"14.37"},{"fld":"U_AC","unit":"V","val":"236.80"},{"fld":"I_AC","unit":"A","val":"0.41"},{"fld":"P_AC","unit":"W","val":"96.70"},{"fld":"Q_AC","unit":"var","val":"0.10"},{"fld":"F_AC","unit":"Hz","val":"50.03"},{"fld":"PF_AC","unit":"","val":"1.00"},{"fld":"Temp","unit":"°C","val":"25.40"},{"fld":"ALARM_MES_ID","unit":"","val":"232.00"},{"fld":"YieldDay","unit":"Wh","val":"1560.00"},{"fld":"YieldTotal","unit":"kWh","val":"252.89"},{"fld":"P_DC","unit":"W","val":"101.60"},{"fld":"Efficiency","unit":"%","val":"95.18"}]]}
    es geht jetzt um Folgenden Teil: {"fld":"YieldTotal","unit":"kWh","val":"252.89" }
    den würde ich so auslesen: {"fld":"YieldTotal","unit":"kWh","val":"\v
    Das Problem an der Sache ist aber das
    {"fld":"YieldTotal","unit":"kWh","val":"​ mehrmals im Text vorkommt. Er nimmt natürlich dann den Textbaustein der als erstes vorkommt. In diesem Fall also den wert 108.90 (das ist eine der Zwei PV-Module)
    gibt es hier eine möglichkeit Zeilen zu überspringen?
    • 4456
    \i"kWh","val":"\i\i"kWh","val":"\i\i"kWh","val": "\ i\v
    du musst 3mal über den xxx springen und dann mit v den Wert lesen
    /ixxx/i
    Zuletzt geändert von AlexAn; 03.07.2023, 18:51.
      • 5169
      \iText\i
      springt hinterText
      Beispiel:
      Sofern "ALARM_MES_ID" nur einmal vorkommt könnte wie folgt gesucht werden:
      ALARM_MES_ID\i"kWh","val":"\i\v
      • newsted
        • 30.05.2021
        • 58
        Wenn ich das eingebe gibt er mir auch 108,9 aus
        verstehe ich das richtig \i heist das was danach kommt überspringen \i\i bedeutet wenn es das zweite mal vorkommt wieder überspringen? müsste es dann nicht \i\i\i beim dritten mal sein?
        das letzte \i könnte man sich dann ja sparen und gleich mit \v auslesen oder?
          • 4456
          sorry da hat sich ein Leerzeichen eingeschlichen
          \ikWh","val":"\i\ikWh","val":"\i\ikWh","val":"\i\v
          ergibt:
          Klicke auf die Grafik für eine vergrößerte Ansicht  Name: image.png Ansichten: 0 Größe: 85,1 KB ID: 396062
          • newsted
            • 30.05.2021
            • 58
            Das war perfekt (: Dankeschön
            Ich würd Dich aber noch bitten das etwas zu erklären wenns nicht zu viel umstände macht. Ich denke ich (und sicher auch andere) werden diese Funktion des öfteren brauchen und ich will ja nicht jedesmal fragen
            also wir haben die Befehle in folgender Reichenfolge:
            \i \i\i \i\i \i\v
            das erste \i müsste ja bedeuten überspringe kWh das zweite \i\i\ überpsringe kWh wieder aber beim dritten mal müsste doch dann \i\i\i stehen? und das letzte \i versteh ich garnicht.
            Danke für die Hilfe
              • 4456
              \iText\i
              1. \i suche folgenden Text
              2. \i beendet die Suche
              das ganze wiederholt sich 3mal und mit \v wird der Wert übernommen
              Zuletzt geändert von AlexAn; 03.07.2023, 20:43.
              • technik-fan-ol
                • 05.09.2015
                • 41
                Hallo, ich bin zu blöd für die Erkennung :-(
                Kann mir jemand das Gerät exportieren ?
                Werte kommen an, aber ich bekomme das mit der Befehlserkennung nicht hin.
                Ahoy DTU
                mfg. Frank
                Der Groschen ist gefallen und ich habe es kapiert, aber leider bekomme ich die Werte in der Visu nicht angezeigt.
                Im Befehlserkennungs Fenster sehe ich die Werte
                Zuletzt geändert von technik-fan-ol; 24.07.2023, 17:23.
                • technik-fan-ol
                  • 05.09.2015
                  • 41
                  Ahoy DTU
                  mfg. Frank
                  Nutze jetzt OPEN DTU per API.
                  Bin sehr zufrieden , jetzthabe ich die Befehlserkennung begriffen :-)
                  • SUGO
                    • 19.06.2020
                    • 26
                    technik-fan-ol Benutzt du auch die WEB Api um Daten zu schreiben ?
                    Also z.B. das Limit am Wechselrichter zu ändern in Abhängigkeit vom tatsächlichen Verbrauch des Hauses? (quasi 0 Einspeißung)
                    Ich bekomme bei mir den Virtuellen HTTP Befehl einfach nicht hin.
                    Lg
