Ich habe mir bereits einen Virtuellen Eingang erstellt und es geht darum was in der Befehlserkennung einzutragen ist:
Die Daten zum auslesen (API) findet man unter: IPeurerDTU/api/livedata/status
gesucht wird der wert "Power": { "v": 0 vom Inverter namens HMT_2250_OST (also die 0 wären die watt)
der zu durchsuchende Code ist (kleiner auszug):
"inverters": [
"serial": "114183084458",
"name": "HM-800",
"order": 0,
"data_age": 222,
"poll_enabled": true,
"reachable": false,
"producing": false,
"limit_relative": 100,
"limit_absolute": 800,
"AC": {
"0": {
"Power": {
"v": 0,
"u": "W",
"d": 1
"Voltage": {
"v": 235.3999939,
"u": "V",
"d": 1
"Current": {
"v": 0,
"u": "A",
"d": 2
"Power DC": {
"v": 0.600000024,
"u": "W",
"d": 1
"YieldDay": {
"v": 724,
"u": "Wh",
"d": 0
"YieldTotal": {
"v": 524.7000122,
"u": "kWh",
"d": 3
"Frequency": {
"v": 49.97999954,
"u": "Hz",
"d": 2
"PowerFactor": {
"v": 0,
"u": "",
"d": 3
"ReactivePower": {
"v": 0,
"u": "var",
"d": 1
"Efficiency": {
"v": 0,
"u": "%",
"d": 3
"DC": {
"0": {
"name": {
"u": ""
"Power": {
"v": 0.300000012,
"u": "W",
"d": 1
"Voltage": {
"v": 15.69999981,
"u": "V",
"d": 1
"Current": {
"v": 0.02,
"u": "A",
"d": 2
"YieldDay": {
"v": 375,
"u": "Wh",
"d": 0
"YieldTotal": {
"v": 236.1000061,
"u": "kWh",
"d": 3
"1": {
"name": {
"u": ""
"Power": {
"v": 0.300000012,
"u": "W",
"d": 1
"Voltage": {
"v": 15.69999981,
"u": "V",
"d": 1
"Current": {
"v": 0.02,
"u": "A",
"d": 2
"YieldDay": {
"v": 349,
"u": "Wh",
"d": 0
"YieldTotal": {
"v": 288.6000061,
"u": "kWh",
"d": 3
"INV": {
"0": {
"Temperature": {
"v": 6,
"u": "°C",
"d": 1
"events": 1
"serial": "138284596755",
"name": "HMT_2250_OST",
"order": 0,
"data_age": 218,
"reachable": false,
"producing": false,
"limit_absolute": 2250,
"AC": {
"0": {
"Power": {
"v": 0,
"u": "W",
"d": 1
"Voltage": {
"v": 411.7999878,
"u": "V",
"d": 1
"Current": {
"v": 0,
"u": "A",
"d": 2
"Power DC": {
"v": 1.000000119,
"u": "W",
"d": 1
"YieldDay": {
"v": 2719,
"u": "Wh",
"d": 0
"YieldTotal": {
"v": 585.164978,
"u": "kWh",
"d": 3
"Frequency": {
"v": 49.97999954,
"u": "Hz",
"d": 2
"PowerFactor": {
"v": 0,
"u": "",
"d": 3
"ReactivePower": {
"v": 0,
"u": "var",
"d": 1
"Efficiency": {
"v": 0,
"u": "%",
"d": 3
"DC": {
"0": {
"name": {
"u": ""
"Power": {
"v": 0.200000003,
"u": "W",
"d": 1
"Voltage": {
"v": 22.29999924,
"u": "V",
"d": 1
"Current": {
"v": 0.01,
"u": "A",
"d": 2
"YieldDay": {
"v": 554,
"u": "Wh",
"d": 0
"YieldTotal": {
"v": 104.0970001,
"u": "kWh",
"d": 3
"1": {
"name": {
"u": ""
"Power": {
"v": 0.200000003,
"u": "W",
"d": 1
"Voltage": {
"v": 22.29999924,
"u": "V",
"d": 1
"Current": {
"v": 0,
"u": "A",
"d": 2
"YieldDay": {
"v": 543,
"u": "Wh",
"d": 0
"YieldTotal": {
"v": 101.1399994,
"u": "kWh",
"d": 3
"2": {
"name": {
"u": ""
"Power": {
"v": 0.300000012,
"u": "W",
"d": 1
"Voltage": {
"v": 22.29999924,
"u": "V",
"d": 1
"Current": {
"v": 0.01,
"u": "A",
"d": 2
"YieldDay": {
"v": 539,
"u": "Wh",
"d": 0
"YieldTotal": {
"v": 99.77200317,
"u": "kWh",
"d": 3
"3": {
"name": {
"u": ""
"Power": {
"v": 0.100000001,
"u": "W",
"d": 1
"Voltage": {
"v": 22.29999924,
"u": "V",
"d": 1
"Current": {
"v": 0,
"u": "A",
"d": 2
"YieldDay": {
"v": 1,
"u": "Wh",
"d": 0
"YieldTotal": {
"v": 90.47200012,
"u": "kWh",
"d": 3
"4": {
"name": {
"u": ""
"Power": {
"v": 0.100000001,
"u": "W",
"d": 1
"Voltage": {
"v": 22.39999962,
"u": "V",
"d": 1
"Current": {
"v": 0,
"u": "A",
"d": 2
"YieldDay": {
"v": 536,
"u": "Wh",
"d": 0
"YieldTotal": {
"v": 95.09700012,
"u": "kWh",
"d": 3
"5": {
"name": {
"u": ""
"Power": {
"v": 0.100000001,
"u": "W",
"d": 1
"Voltage": {
"v": 22.39999962,
"u": "V",
"d": 1
"Current": {
"v": 0,
"u": "A",
"d": 2
"YieldDay": {
"v": 546,
"u": "Wh",
"d": 0
"YieldTotal": {
"v": 94.58699799,
"u": "kWh",
"d": 3
"INV": {
"0": {
"Temperature": {
"v": 6.800000191,
"u": "°C",
"d": 1
"events": 2
versucht habe ich z.b. "HMT_2250_OST" \i"v": \v bin damit aber nicht erfolgreich gewesen.
