Config Changelog 16.1 ???
    • 7661
    Hier mal der letzte Stand der sich vermutlich nur noch geringfügig verändert.
    New
    - General
        - Reworked UI of property Window
        - Call Generator function block
            - Calls and plays message on the rising edge
            - Key press as callback functionality
            - Phone Number and Message can be used with variables (<user.phone>, <sysvar.rain>, etc)
        - A3D9-T1866: Generators support <user.uuid>
        - A3D9-T1601: API command generator of touch pure flex allows usage of the leaveroom command
        - A3D9-T1753: Property Window: Added Filter
        - A3D9-T1625: Window block status message if closing fails
        - A3D9-T1794: Qt-Port: Radio Button Dialogs
        - A3D9-T1701: System message when meter detects an invalid value
            - Split the message by cause of invalidity
            - add new action "confirm meter replacement" to the message
        - BG-I34287: Hoermann Air - obstacle detection by light barrier (only HZP2)
        - SPD-T810: Update Air Device inputs/outputs when power supply mode switches (DC/battery)
        - BG-I38838: Multi Edit Dialog now identifies cabinet devices automatically when selected
        - A3D9-T1700: Mail Generator function block
            - Sends an email on the rising edge
            - Loxone Cloud Mailer or Custom SMTP Server
            - All properties can be used with variables (Recipient's address, Subject, SMTP Settings, etc)
        - BG-I38931: Virtual Output Command: add option to prevent sending analogue 0 / empty text values
        - A3D9-T1751: - Parameter Simplification for Function Blocks
            - Parameters are now categorized in "Parameters" and "Advanced Parameters" for better usability
        - Wallbox 22kW
        - New Door & Window Contact Air
        - New Water Sensor Air
        - A3D9-T1789: Expanded database connector to 16 custom inputs
        - Added Thai as new language
        - A3D9-T1899: Auto Config now only connects two actors to the same output of the light controller if they have the same name
    - Audio
        - A3D9-T1329: Password Protection for Audio network share
    - Devices
        - WA1-T584: Energy Meter Tree firmware adaptation for OVE R37
            - check grid conditions when regional regulation is configured in assigned wallbox
            - provide diagnosis inputs for Grid Voltage Error and Phase Symmetry
    - Energy
        - A3D9-T1661: Spot Price Optimizer: Dynamic Update of available Markets
        - A3D9-T1707: Energy Meter - Configure minimum send cycle for Api Actor
        - A3D9-T1708: Energy Meter - reduce allowed minimum send cycle for Api Actor
        - BG-I39848: Wallbox added parameter 'Meter reading offset'
        -  A3D9-T1880: Wallbox Add regional regulation to comply with OVE R37
            - Configure cut-off condition and delays
            - Ramp up charging power starting from minimum power in case of grid-voltage errors
            - Requires an Energy Meter 3 Phase to supervise cutoff / resume conditions
        - A3D9-T1567: PV Production Forecast
            - Based on given PV power and weather data predicts production in kWh
            - Calculates for: 1. Given hours as parameter from next full hour (0-72: h), 2. Today, 3. Next day
            - Requires Weather Service subscription
    - Security
        - A3D9-T1790: FTP Server Setting
            - Options: Disabled (default), Enabled, Enabled - TLS only
            - A3D9-T1775: FTP Server enforces TLS when Setting "Enabled - TLS only" is selected
        - A3D9-T1800: TLS Encryption Fallback
            - use factory certificate when custom or Loxone certificate not available
        - TLS port can't be disabled anymore and is always enabled
        - A3D9-T1773: Logging of security relevant Events to def.log
            - e.g. changes to user or network settings, invalid logins, ...
        - Show connection unencrypted dialog when insecure connection is detected to Miniserver (Miniserver Gen. 1 excluded)
        - A3D9-T1774: HTTP Setting
            - Options: Disabled, Enabled, Enabled with HTTPS Redirect, Enabled - HTTPS Preferred
            - Enabled - HTTPS Preferred
                - This redirects to HTTPS if there is a valid certificate but will allow HTTP traffic if there is no valid certificate for example in installations without internet
                - This will be the default
        - FTP Server - Setting to enable/disable FTP Server not working in German Config
        - Activated firewall
            - Disallowed ports are now blocked
    Fixed
    - General
        - BG-I38117: Gateway - Reference lines for global inputs not working (e.g. system variable & weather server)
        - BG-I38237: Property Window - Combobox editor pointing hand cursor was not cleared when not hovering above drop down arrow
        - BG-I38158: Property Window - Changes not committed before saving into Miniserver
        - BG-I38414: Property Window - Editing shared property via floating property window not possible
        - BG-I37715: Miniserver icon is sometimes not shown in Loxone Config - Projects list
        - BG-I37830: System scheme Text object could cause invalid LoxApp3.json output in some situations
        - BG-I37941: fixed memory leak in SD formatting dialog
        - BG-I37135: Adjusted the Note's drawing, no more empty spaces on the horizontal and vertical
        - BG-I37747: Updated the Garage / Gate function block's behaviour to send updates whenever inputs Ic and Io are triggered
        - BG-I36691: Energy Manager function block's next output doesn't display its value in kW anymore
        - BG-I38196: Miniserver Crash/Bootloop when adding "<vn>" to its state value fixed
        - BG-I38236: Planning tool now includes "Satellite Speaker IP64 Passive white"
        - BG-I38277: Switch function block now displays "+ADD" when dragging a Digital Output
        - BG-I38156: UDP Broadcasts to 255.255.255.255 now work as expected.
        - BG-I33502: Tracker: Multi-line entries in Tracker are displayed incorrectly
        - BG-I37800: Adding function block opens selection dialog when nothing can be selected
        - BG-I37914: Backup Webservice: Return proper error code
        - BG-I38083: Unassigned reference does not remove negation when assigned to analog
        - BG-I38367: Objects which should not be deletable can be deleted
        - Program not modified when creating switching time
        - BG-I34446: KNX actor sends zero on restart
        - BG-I38480: Automatic load from Miniserver when first connect fails
        - BG-I38457: Config requests app rights which are not needed for connection and the user may not have due to prohibition and therefore connection with config fails
        - Documentation info button in property window for some objects
        - BG-I36477: Alarm clock pre alarm doesn´t work when the corresponding alarm is on a different day
        - BG-I36660: Invalid meter reading is accepted into the meter block if miniserver is restarted or saved into
        - BG-I36556: When using more UDP inputs with the same port only one is shown in the monitor
        - BG-I37594: Property Window: Tree Intercommunication ID could not be renamed for internal Tree branch
        - BG-I38152: Config Crash after closing Schedule dialog
        - BG-I37888: API Command Generator: Switch to 'Not Assigned' should show 'Input/Output' and all I/Os
        - BG-I36143: Add option to remove assignment from presence control instead of deleting sensor
        - BG-I38238: Colour setting uses too much space
        - BG-I37867: LICO shows green line if output (SMA) is off
        - BG-I37666: Function block title text colour inconsistent with bright colours
        - BG-I37806: Increased clickable area of connector-inversion
        - BG-I37661: Periphery Tree: show help icon for hovered items which do not have properties
        - BG-I37728: Control Drawing: Setting room "do not use" shows category twice
        - BG-I37860: User ID containing local @host not recognized
        - Control Drawing - adapted spacing for liveview values
        - BG-I37736: Control Lock Event not sent to app
        - BG-I36524: Valve Tree still uses Gen.1 image in app search
        - BG-I37690: Manage Permissions Dialog not working out of Edit Settings Dialog
        - BG-I37960: Miniserver Healthcheck - execute ntp request, only search for server if no server is set
        - BG-I38074: Automatic Jalousie shown as destination object for relays when using api output
        - BG-I36978: Linked controls get lost when adding client project which was copied
        - SD card is shown as full in some cases
        - BG-I36984: Config crash when searching for AC in quicksearch
        - BG-I38204: TPos output of window not working anymore
        - Miniserver can't download webinterface auto update
        - BG-I37695: Presence control - set default timers by input "Off" after presence sensors
        - BG-I37934: Unconfigured Trust Members get hidden after rebuilding periphery tree
        - BG-I38105: value color for connection references in liveview
        - BG-I38082: Note blocks drag & drop automatic reference snapping
        - BG-I38055: Config is stuck at tile page after after saving into miniserver
        - BG-I37864: Misplaced text highlighting in PicoC editor
        - BG-I37523: Touch Pure Flex Liveview: '°' not correctly displayed
        - BG-I37528: Property Window: Checkbox settings with long text sometimes caused other editors to be cut off
        - BG-I37519: Property Window: Missing pointing hand cursor for multiselect editor
        - Property Window: Category expansion state not saved for certain categories
        - Property Window: Setting not selected after committing change
        - BG-I37671: Documentation didn't open when pressing F1 right after adding new control
        - Property Window: Floating property window didn't open for Audio Player
        - BG-I37758: Property Window: ampersand shown twice for not editable text settings (e.g. device type 'Touch & Grill')
        - BG-I37427: New Page dialog: combo box not updated after closing New Room dialog
        - BG-I38047: Property Window: clicking on setting title does not show tooltip in some cases
        - BG-I38015: Property Window: AltGr + S opens save dialog
        - BG-I37936: Property Window: Floating window closed after edit dialog was closed for certain settings
        - BG-I36281: App connection to Miniserver Gen.1 not possible due to invalid certificates being used
        - BG-I37886: SIA system message has action which doesnt do anything
        - Tree device changes type to a NFC when there is a bad connection in rare cases
        - Zoom Buttons in the wrong order
        - BG-I36218: Schueco device search opens old search window
        - BG-I36853: Full SD card not properly detected and causing startup problems
        - BG-I37619: Schedule block changes to analog when connecting output Rt
        - BG-I37525: Multiple pulses in a single Flex Command not handled properly
        - BG-I37639: Opening time cannot be set on Hoermann Air
        - BG-I37662: Property window shows unneeded info button, crash when clicking on it
        - BG-I37660: Property window shows no text for control without visible properties
        - BG-I37165: Formula Block not working by pressing enter
        - BG-I37684: Api Command Generator: "input/output" now shown in user interface when both could be selected
        - BG-I37720: Gardena v1.0.3: digital IOs (e.g. mower park) were also triggered on falling edge when saving into the Miniserver
        - Air Device default button behaviour changed to T5 which got renamed to automatic
        - AC Control has wrong min/max temperature when using °F
        - BG-I38023: fixed failing Config Login when certain special characters are contained in username/password
        - High CPU usage and network load directly after connecting to Miniserver when cover page is selected
        - HTTP Input: Request with Redirect not working
        - A07R-I1359: Dali is missing documentation of settings
        - Objects are shown in App-Structure json when being connected to a status monitor which is not shown in visualization
        - Object is shown as disinherited on a normal Miniserver project
        - Energy Manager can set flag for Multiplicator disinheritance on a normal project
        - Window Contact does not automatically connect to automatic shading and invert input
        - Missing system notification object does not get automatically readded
        - BG-I38331: Miniserver backup contains UpdateInfo.xml which tells the Miniserver when to update devices, this results in devices not updating when formatting a new SD with old backup
        - BG-I37508: Invalid value system message on meter object does not disappear in all cases
        - BG-I38329: Table width not selectable in manage members of user group
        - BG-I36967: Websocket reuses old http parameters resulting in logouts of the app
        - BG-I38360: Manual change stays after ending live view
        - BG-I37843: Exosphere Master password could only be changed in "My Miniserver Keychain" dialog when there are stored credentials in the list
        - BG-I36132: SD format dialog now shows devices from Exosphere in a more structured way
        - BG-I39312: Invalid IO Visibility after lerning in Door Window Contact Air
        - BG-I39393: Bacnet IO's cannot be configured in user management
        - BG-I39366: Radio Button with negation resets when saving into miniserver
        - BG-I39231: Schedule Dialog - Temperature dropdown not disabled after "select all"
        - BG-I39112: Off pulse from Switch does not turn off Lico if controlled via Flex
        - BG-I38991: Tree Filter - show children of visible devices
        - BG-I39329: Control drawing - fixed border for custom colored references, page background set to white again
        - BG-I39473: Category/Room not drawn properly on control when one of them is set to do not use
        - Monitors not properly shown
        - Crash when loading from Miniserver with invalid custom changes
        - BG-I39229: Configured intercom shown as unconfigured in the search
        - BG-I39227: Multi-Editing of references and objects does not show proper settings
        - BG-I39129: Always show Miniserver Compact in network caption
        - BG-I39038: Miniserver reboot when learning device on full tree branch
        - BG-I38968: Client speakers not shown with automatic room filter
        - BG-I38993: US Timezone causes default user validity to be set to 2093
        - BG-I38963: User Management - user active from/until time fields change entered time
        - BG-I39228: User Management - webservice "addoredituser" creates duplicate users on clients if username contains invalid characters
        - Control outline now drawn in control color
        - BG-I39214: Can't change address of knx text actor
        - Security tab in Miniserver configuration dialog keeps disappearing
        - Touch Pure Flex controller does not output anything due to regression of parameter changes
        - Can't open Miniserver configuration for Miniserver Gen.1
        - Can't set averaging setting of Peak Load Manager in property window
        - Device type setting not prominent enough
        - AC Monitor does not show serial
        - App is locked out by Miniserver when working in functions where higher permissions are needed (regression introduced with 16.1)
        - BG-I39126: Remanence not working anymore on some controls
        - App events not sent properly on some controls
        - BG-I38486: Authorized users/groups right click context menu clickable when selecting multiple objects
        - BG-I38510: Property Window - Clicking on text of button editors did not open dialog or perform action
        - Fronius 0.7.17
        - BG-I38907: Property Window - Expansion state for categories collapsed by default not saved the first time
        - BG-I38907: Property Window - Numeric Editor text for 'defined by function block' did not expand
        - BG-I38907: Property Window - Floating Property Window opens without settings after changing page
        - BG-I38957: Device Status does not use default program to open text files
        - BG-I37707: User Management - some restrictions not applied when creating user via app
        - BG-I38912: Systemmessage if no NTP time adaptions were made reduced to 5 days
        - BG-I38387: Tg input on Asce incorrect when Dwc active
        - BG-I38093: Flow Temperature Controller deactivates pump while HVAC is still shutting down
        - BG-I36802: Flow Temperature Controller has not target temperature while HVAC is still shutting down
        - Textgenerator can't access systemvariable systemstatus (<sysvar.systemstatus>)
        - Trust switch not working anymore since command fails and app locks itself out
        - BG-I38171: Debug Monitor - Authorization credentials could be seen
        - Expiration of Loxone certificate not checked (use factory certificate as fallback)
        - BG-I38833: Config Connection not terminated when connected user changes via Config (e.g. user deleted, password change)
        - Config Connection: Dialog not shown when connection is terminated by Miniserver (logoff webservice or user modified)
        - Fan Control control via step selector not working (regression 16.1.6.25)
        - Http Get parameters are not forwarded to function blocks or plugins
        - BG-I39416: System messages with a TTL do not disappear automatically in some cases
        - Caller now uses https
        - BG-I39679: Monitors popup when you add an extension
        - BG-I39346: Property window didn't update when database table definition was imported from Exosphere or file
        - BG-I39364: Project Management view menu was cutoff/overlapped by scrollbar in some cases
        - BG-I39041: prevent unintended changing of selected value in ComboBox when scrolling via mousewheel in Exosphere database table dialog
        - File download via HTTP client results in invalid file sizes on some conditions
        - Modbus TCP device stops responding - faster reestablish of connection
        - Adapted page background colour
        - BG-I39558: HVAC Controller visualization not working
        - BG-I39561: Setting editor allow copy of passwords
        - BG-I39177: Can't read name of coloured reference when its selected
        - BG-I39825: Connection window does not show text of outputs
        - BG-I38566: Connection references don't show their value in LiveView/Simulation
        - Compact Audio update does not start
        - BG-I38783: Livelearning no icon for Link-Search shown in app
        - Livelearning only master speakers are replaceable in search
        - BG-I34756: Tree devices not working when last item of previous tree branch is a dummy Tree2Air bridge
        - BG-I40036: Device status shows TreeTurbo dummy device as offline
        - BG-I39984: Generators with inverted outputs don't get triggered at the start
        - Step size of numeric setting spin boxes was not set
        - BG-I39987: Import template via file explorer could cause lockup
        - BG-I39645: VI visualization icons were incorrect
        - BG-I40064: Loading from Miniserver creates duplicate users & groups
        - Remanence save trigger not sent to plugins
        - BG-I37319/BG-I38064: Property window can't be found anywhere
        - BG-I38157: Monitors too small after starting them
        - BG-I39958: Motor lock duration not working for automatic shading
        - BG-I39979: Setup Files are not deleted after config update
        - BG-I40028: 1-line connectors render with half font size when editing title
        - BG-I38567: Filter resets after entry is edited in user management dialog
        - BG-I39015: Trust with all active admin users can be deleted, which will lock you out of config
        - Redirect from HTTP to HTTPS is missing a cors header
        - BG-I39854: Double-click on the Intercom block opens the wrong window
        - Exosphere and Homekit can't connect to Miniserver when HTTP redirects
        - BG-I39999: Touch & Grill room-caption could be added to non-owned Miniserver (Gateway-client setup)
        - BG-I39108: Trink counts also children from T2A
        - BG-I39584: Empty popup after Modbus Test Command
        - BG-I39665: Memory flag is red and unassigned in Configuration view
        - BG-I39993: fixed Mitsubishi Heavy address filter in Ac Control Monitor
        - BG-I39396: Cannot connect multiple outputs to LICO
        - BG-I39863: Touch Pure Flex Controller Don switching on the backlight when saving in Miniserver
        - Systemmessage when Loxone HTTPs certificate expires
        - Debug monitor output is included in UDP monitor
        - BG-I39610: SD Format: sorting of backups in SD format dialog by date didn't work correctly in all cases (depending on system date format)
        - BG-I39682: SD Format: some backups downloaded from Exosphere failed to format
        - BG-I39540: PropertyWindow: some dialogs were opened behind (floating) property window
        - BG-I38243: Checkbox in table view (e.g. Shading Central) was not toggleable with spacebar
        - BG-I39627: Strings in NFC dialog where not translatable
        - BG-I39539: Adapt error colour for footer
        - BG-I39458: App Learning Unpaired intercom shown as searchable device
        - BG-I39917: Energy Meter Tree Missing send cycle
        - BG-I39328: Intercom: Existing Bell connections not removed when trust intercom is connected
        - BG-I40050: Floating point parameter settings did not respect min/max ranges
        - BG-I39544: TTS reads backslash because of line break
        - BG-I40028: 1-line outputs, constants and memory flags are drawn with half font size when editing
        - BG-I39782: Configured audio player shown as unconfigured in the search
        - BG-I39539: Object count for status monitor in footer not working
        - A07R-I1206: Added new command descriptions for Text Generator
        - BG-I39660: Property Window Disabled settings could be opened via setting title
        - BG-I39467: Property Window Text tooltip shows password
        - BG-I39210: Property Window Logging settings not expanded by default for Logger/Mailer/Caller/Tracker
        - BG-I39149: Property Window Name setting not automatically selected when adding trust input/output
        - BG-I39147: Property Window Room Name of Dali device not shown when Dali group is selected
        - BG-I37758: Property Window Ampersand shown twice (e.g. device type 'Touch & Grill')
        - QuickSearch Ampersand shown twice for device variants
        - BG-I39747: Lighting groups not working properly in some cases
        - BG-I39148: Creating a Dali group doesn´t give it the category "Lighting"
        - BG-I39011: Pool Controller: Colour for Backwash+Rinse doesn´t match the legend
        - Added 'techreport.loxonecloud.com' to the healthcheck
        - BG-I39283: KNX Extension doesn't show number of used devices/addresses
        - BG-I39320: Dwc input of ac unit controller is inverted by default
        - BG-I39439: Documentation of Audioserver: line in id value range and default value are wrong/confusing
        - BG-I39411: Intercom and other network devices show room twice in document tree
        - BG-I39539: Integrated and intercommunication blocks change footer content based on visibility of api connector
        - Also reworked the function block footer text in general
        - BG-I39099: Config sometimes crashes when having an ac controller in the projet and searching for ac
        - BG-I39646: 2-line in-/ouputs are drawn with double size font when editing the title
        - BG-I39476: PSP without battery reports wrong system message upon power loss
        - BG-I39794: Light controller shows movement scene in app although no presence/move is connected
        -  BG-I39358: Plugin Output on another Miniserver triggers send to Plugin even when value does not change
    - Audio
        - BG-I38424: Changing "Presence" switch in app activates music even if DisP is active
        - added Diagnosis Commands in Loxone Config Device Manager for Audio devices.
        - Support for Parameter Vm (Maximum Volume for Player) added to allow limiting the maximum volume by logic
        - added Network issue detection to healthcheck and Systemstatus to detect various common issues
        - DSP optimizations for Loxone Speakers and Amp Outputs (Audioserver, Extensions)
        - Check and Report DNS issues of Extensions in HealthCheck
        - BG-T3751: Techreport now needs Time occured, optional list of players and an input field to specify what source was playing
        - A3D9-T1780: Music Player - new input Vm to programmatically adjust maximum volume
        - A3D9-T1778: Device Status: enable device commands for audio-devices, show device command response in dialog
        - A3D9-T1784: Music Player - default value for Automatic Highpass Filter set to false
        - A3D9-T1785: Music Player - only subwoofers are allowed on output "sub". Unsupported devices are moved to output LR
        - A3D9-T1776: Audio Server - more detailed offline information for app and devicestatus
        - BG-I37902: Configure Audioserver Dialog: disable time zone setting (provided by miniserver)
        - BG-I38358: fixed Player presets default account settings not handled. Update the Player preset with the correct accounts via Loxone App in order to make it work.
        - BG-I37734: fix resolver URL errors not correctly handled
        - BG-I36140: fix URL encoding cause wrong display on Touch Flex
        - BG-I35529: fix command order for 'player lock' causing frequently locked Players
        - BG-I38086: fix transition from Bluetooth to Airplay
        - Player with multiple Outputs unusable in App if a single output was restarting/updating
        - If Player has presence on and was disrupted by a Stream Error, the presence was not re-evaluated again
        - BG-I37530: playing an unavailable NAS source caused a loop
        - BG-I38358 fixed Player presets default account settings not handled. Update the Player preset with the correct accounts via Loxone App in order to make it work.
        - adapted maximum volumes for separated stereo outputs
        - updated library (missing file checks) while installing
        - Extension search / getconfig does not show serial numbers of extensions
        - DSP Settings limiter adjusted
        - BG-I39168: Presence on Audioplayer fires 2 play commands
        - End of presence mode by Audioserver not properly shown in history
        - Client Speakers new Gain Factor fixed
        - BG-I38973: Buzzer not working via API command
        - ISP Clients EQ settings caused disturbance
        - Audio synchronization when using Airplay on multiple outputs via IOS picker
        - reset Speaker Master DSP settings after update
        - Error message that hostname could not be resolved shown during update of Audioserver
        - BG-I40086: do not show Spotify in search when no account is configured
        - fixed input validation for network scan
        - fixed crash in resettodefault and in events playback
        - BG-I40035: restart-event from Audioserver not properly handled
        - Samba protection only visible for Miniserver Compact
        - BG-I38358: when using Rtd with Spotify as the room favorite that should play next time, the default account was not correctly selected
        - BG-I38997: Spotify stuttering in rare cases due to buffer issues
        - BG-I39456: Airplay sync playback when selecting from Airplay Picker (without grouping on Loxone side)
        - add grace-period to reporting DNS errors, small outages should not be reported
        - A3D9-T1889: optimizations for App communication (recently played, favourites)
        - BG-I39957: fixed correct mime type for custom station cover art
        - enhanced watchdog for Speaker Master
        - [Audio] optimization for local Library playback and Soundsuit
        - BG-I38358: when using Rtd and Spotify
        - Audioserver Increased allowed update time before setting device as offline
    - Auto Configuration
        - BG-I37157: Outputs with different names are combined into a light group
        - BG-I38781: Unconnectable climate objects will create object, anyway, leaving the object without any connections
        - Overtemperature shutdown of devices always checked per default in fire alarm, despite normal default behaviour
        - BG-I40039: Storm and frost protection are coloured green, although being in shading category
        - BG-I38084: Connection is being placed on the wrong page (All Off operating mode)
        - BG-I38077: Repeated AutoConfig checks all the comfort functions as default
        - BG-I38076: Repeating AutoConfig for the "GoodNight" comfort function caused multiple "All Out" connections to the Pulse at block
        - BG-I38075: AutoConfig doesn't name lighting circuits correctly if a custom name is used
        - BG-I38079: AutoConfig deletes created mood if it has id 2
        - BG-I38697: AutoConfig labels the control object for the Wallbox with the name of the energy meter
        - BG-I39361: Alarm clock mood is created in the light controller although alarm clock is not selected
    - Access
        - BG-I38087: NFC Authentication not working after authenticating with preselection
        - BG-I34488: NFC Authentication: Two Factor Authentication not working for NFC Code Touch Air when code not confirmed with checkmark before providing NFC tag
        - BG-I35354: NFC Authentication: Output names not updated when connecting an output in certain conditions
    - Devices
        - Table Lamp:
            - BG-I37458: Buttons respond incorrectly when plugged (smaller touch area)
        - Presence Sensor Tree
            - BG-I37695, BG-I33987: MS Reboot triggers presence
        - Touch Pure Flex
            - BG-I34374, BG-I24386: Fixed touch field misalignment
            - BG-I34324: Updated time synchronization with miniserver
            - BG-I39150: Status LEDs not visible at 1% and 2% brightness
            - BG-I33723: Long time press not possible
            - BG-I36126: Battery Powered device unresponsiveness at low battery
        - Valve actuator Tree Gen 1
            - BG-I37746: Reduced amount of drives
        - Touch for Nano/Touch Tree US
            - R20-T586: Touch Orientation
        - Valve Actuator Air
            - BG-I37148: being permanently awake, when Learn Button is pressed continuously by the Housing.
        - NFC Code Touch
            - BG-I36455: NFC Tags can't be authorised or take several seconds for the NFCCT to react after 15.5.3.4 update
            - BG-I37432: Ghost Touches NFC Code Touch
        - AC Control Air
            - BG-I38168: & BG-I38051: add binary for AC Control Air to add fan speed Silent
        - Touch Pure (CO2) Tree
            - BG-I39801: sometimes does not show all sensor data
    - Climate
        - BG-I38045: AC unit controller block does not remember the last set temperature
        - BG-I37371: AC Unit Controller - communication to IRC not working after copy-paste
        - BG-I37859: IRC2-Dialog: Output group changes after deleting source
        - BG-I37709: AC Central Controller: locked input does not switch off AC Unit in Automode if no room temperature is connected
        - BG-I35635: Intelligent Room Controller: prepare phase not ended when calendar-temperaure was changed via config
        - BG-I37698: AC Central Controller: vlimC cannot be set higher than vlimH
        - BG-I37420: Intelligent Room Controller- Touch flex shows wrong inital temperature with ValueSelect after change via app
        - BG-I36417: Intelligent Room Controller- System message for Frost/Heatprotection says current temperature instead of triggering temperature
        - BG-I37948: Flow Temperature calculator did not calculate correctly in gateway when using single selected IRC's
        - BG-I38717: Intelligent Room controller - Eh/Ec on Heating and Cooling Controller overrides forced temperature mode
        - BG-I39022: Heating and Cooling Controller - input Mh only acts delayed
        - BG-I39035: AC Central Controller - Movement in Living Rooms not prioritized
        - Only adapt Min/Max Temperature of AC to Fahrenheit when it was not yet manually adapted
        - BG-I38168: & BG-I38051: Add Fanspeed Silent to AC Control Air Toshiba and fix AC Control Monitor
        - BG-I38721: AC Control History - invalid origin when edge of On and Off happen in the same cycle
        - BG-I38499: AC Central Controller - Mode Timer off not remanent
        - BG-I37039: AC Unit Controller with IRC stays active when a cheaper source is activated
        - BG-I39208: Double-click on the IRC block opens the schedule instead of configuring the heating sources
        - BG-I39852: IRC forwards wrong temperature to AC when using Fahrenheit
        - BG-I38614: Changed default category for "Mixing Valve Controller, IRC V1, Room Controller" to Climate
    - Energy
        - BG-I26228: SPO Absolute mode: incorrect values at 00:00
        - BG-I37689: EFM doesn't delete the "Rest" value in the statistics if so programmed
        - BG-I37410: SPO: Wrong naming for Slovak market
        - BG-I38366: Meter tree can change its default block type to any block
        - BG-I30316: Energy Flow Monitor rest of a distribution board is calculated incorrectly when it contains a storage
        - BG-I39005: User OCPP Tag ID not transfered via Trust
        - BG-I38739: SPO Active Output runtime would not meet demand in some cases
        - Fronius plugin 0.8.21
    - Gateway
        - BG-I38422: Can't load project from Miniserver when it got converted during startup
    - Lighting
        - BG-I31870: Daylight responsive lighting block does not update the output correctly
        - BG-I37336: RGBW Dimmer - missing perception settings when using standard single channels
        - BG-I37268: Light Controller not a destination object when dragging presence brightness sensor
        - BG-I38339: Constant brightness controller does not automatically connect smart actuators
        - BG-I38988: Add automatic designer support for RGB Lighting Controller
    - Multiplicator
        - Fail to restart Multiplicator Miniserver after saving
        - BG-I37185: NFC access codes can't be reset
        - BG-I36980: Resetting object removes connection line from memory reference
        - BG-I37829: Config crash while resetting objects to default
        - BG-I37101: Dali device groups get mixed up
        - BG-I37809: Reintegrating changes back to Multiplicator file now always suggested
        - BG-I37809: Not all modified/deleted objects are shown in deviation dialog directly after opening a file
    - Project Planning
        - BG-I37930: Name of Master Speaker is not adapted to the name given in Project Planning
        - BG-I37760: Nano Dimmer US 100499 Missing in Project Planning
        - Tree to Air Bridge is not put on a seperate channel when being created from planning
        - Speaker install boxes missing
        - BG-I39971: Fan control and Wallbox 22kW missing in project planning
    - Shading
        - BG-I38096: Roof window shading not reactivated when Sps ins ON and Sunshine is OFF
        - BG-I39375: Toggle input from Central Shading stuck when using Nano2Relay
        - BG-I35593: - revert DisPc blocking central shade commands. DisPc only affects the control where it is active
        - BG-I38240: Nano IO Air not compatible with Roof Window Shading using API Connector
        - BG-I40127: Automatic Shading Integrated no History Origin for Input T5
        - BG-I40196: Automatic shading not ended with manual intervention by synchronized central command
    - Security
        - BG-I35706: Main administrator should not inherit config-access-prohibition from user groups
    - Stability
        - BG-I38194: Config crash when changing setting which deletes IO
        - BG-I37477: Property Window: Crash when editing in periphery tree and clicking into any editor of property window before pressing Enter
        - BG-I37742: Property Window: Crash when double clicking Wallbox which is linked to Wallbox Manager without fixed property window visible
        - BG-I37491: Multiedit Dialog: Crash after confirming warning dialog when using arrow keys to edit next object
        - Property Window: Crash when pressing info button without any open project
        - BG-I37341: Config crash when closing project
        - BG-I38735: Config crash when loading from Miniserver due to broken custom change of Touch Pure Flex
        - BG-I38556: Config crash when adding water sensor air
        - Config crash when opening context menu
        - Miniserver reboot when loading program file which was modified by creating new rooms
        - Config crash when deleting trust
        - BG-I40092: Config crash when starting Dali search
    - Trust
        - BG-I37429: Not possible to change data type from Trust Input
        - Timeout when testing reachability while joining to low
        - BG-I39097: Trust User settings which are managed by Trust Manager are not disabled
        - BG-I39844: User data may not get fully received by Trust member when user gets edited in quick succession
    - Usermanagement
        - BG-I32295: Add userid to webservices getuserlist + getuserlist2
