Loxone und Russound über RS232 koppeln - Statusabfrage
  • sandra456de
    • 31.10.2015
    • 50
    ich habe meine Russound Multiroomanlage bisher nur rudimentär angebunden über RS232, das funktioniert auch sehr gut und zuverlässig, nun möchte ich gern erweitern.
    Ich hätte gern den Status in Loxone dargestellt. Russound beschreibt das mit seinem Protokoll so:
    7.12 Get All Zone info
    As stated previously, a message can be used to request all of a particular Zone's parameter values
    at once. This can be very useful for updating panel displays. The following is an example of
    how to request Zone information for a particular Zone and what the return message would look
    like.
    7.12.1 Get State
    This is the Request message for the parameter values of the selected Zone.
    Byte # 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17
    Value F0 cc 00 7F 00 00 70 01 04 02 00 zz 07 00 00 xx F7
    cc = controller number -1
    zz = zone number -1
    xx = checksum
    The return message would look like the following.
    Byte # 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
    Value F0 00 00 70 cc 00 7F 00 00 04 02 00 zz 07 00 00 01 00 0C 00 ## ## ##
    Byte # 24 25 26 27 28 29 30 31 32 33 34
    Value ## ## ## ## ## ## ## ## 00 xx F7
    zz = zone number -1
    xx = checksum
    The parameter values are depicted in bytes 21 – 31. These values will change depending on the
    state of the selected Zone. The above example shows the parameter values for a Zone
    configured and being used as follows:
    Byte #21 = Current Zone On/Off state (0x00 = OFF or 0x01 = ON)
    Byte #22 = Current Source selected -1
    Byte #23 = Current Volume level (0x00 - 0x32, 0x00 = 0 Displayed … 0x32 = 100 Displayed)
    Byte #24 = Current Bass level (0x00 = -10 … 0x0A = Flat … 0x14 = +10)
    Byte #25 = Current Treble level (0x00 = -10 … 0x0A = Flat … 0x14 = +10)
    Byte #26 = Current Loudness (0x00 = OFF, 0x01 = ON )
    Byte #27 = Current Balance level (0x00 = More Left … 0x0A = Center … 0x14 = More Right)
    Byte #28 = Current System On state (0x00 = All Zones Off, 0x01 = Any Zone is On)
    Byte #29 = Current Shared Source (0x00 = Not Shared 0x01 = Shared with another Zone)
    Wie verarbeite ich nun diese Informationen mit Loxone weiter? Wenn ich eine Statusabfrage starte, schickt mir die Anlage einen String zurück, aber wie kann ich die einzelnen Paramter auslesen und einzelnen Variablen zuweisen?
    Als nächstes möchte ich dann auch Informationen auf dem Display darstellen, Raumtemperatur und Aussentemperatur z.B., aber wie bekomme ich so einen komplexen String mit berechneter Prüfsumme und variablen Temperaturen dargestellt?
    Vielen Dank für eure Hilfe
  • Rar9
    • 221
    Ich habe zwar nur eine NUVO Grand Concerto, aber ich gehe davon aus das dieses fast vergleichbar sind über Ihre RS 232 Schnittstelle.
    Mein Tipp ist den RS232 Monitor mal anzumachen und die Befehle zur Russound aufzuzeichen.
    Für die RS232 must zuerst das richtige Protokoll einrichten. (Bei mir geht Bautrate 57600 / Bit 8 / Stopbits 1 )
    Die Sensoren erhalten die Rückmeldung vom Gerät Empfangen & Auswerten. (Beispiel "Zone1 - VOL" -> #Z1\iVOL\i\v)
    Die Aktoren schicken die Befehle an dein Gerät. ( Beispiel "Zones 1 Volume" -> *Z1VOL-\r\n)
    Das Thema mit Text habe ich nicht, da ich diesen direkt auf mein Ulux Taster schicke. :-)
    • sandra456de
      • 31.10.2015
      • 50
      Hallo Rar9,
      das Protokoll ansich ist nicht das Problem, wie gesagt, eingebunden sind teile der Anlage per RS232 schon, bisher steuere ich aber nur, nehme noch keine Befehle seitens Loxone entgegen und verarbeite diese als Variablen weiter, da hakt es bei mir im Moment...
      • Rar9
        • 221
        Sorry aber was willst den steuern?
        Z.B. Es klingelt an der Haustür und alle Zonen gehen auf MUTE für 10 sec ?
