LG WebOS TV and Loxone
  • J V
    • 384
    Hello,
    Has anyone tried to control a LG WebOS TV from Loxone?
    From what I can find, it can be controlled via json, after first getting a pairing key that is specific for the client. I have found information that seems helpful here:
    Python: http://harizanov.com/2013/12/control...-raspberry-pi/
    I assume it will be necessary to get this key first and store it for use in other commands.
    Thanks!
    Jörg
  • J V
    • 384
    Perhaps I linked the wrong document... Later TVs use Webos, and can be controlled via node.js.
    Control LG WebOS TV using node.js. Contribute to msloth/lgtv.js development by creating an account on GitHub.
    Is there a way of running node.js on the Miniserver? Or is it possible to mimic the behaviour by sending/receiving network packets?
    I suspect this part of the code is similar to sending a TCP packet:
    var send_command = function(prefix, msgtype, uri, payload, fn) {
      command_count++;
      var msg = '{"id":"' + prefix + command_count + '","type":"' + msgtype + '","uri":"' + uri + '"';
      if (typeof payload === 'string' && payload.length > 0) {
        msg += ',"payload":' + payload + "}";
      } else {
        msg += "}";
    console.log("---> Sending command:" + msg);
    I'll keep working on it...
    Zuletzt geändert von J V; 15.12.2017, 10:16.
      No and No.
      You have to use a more open device in between (like a Raspberry), as Loxone does not provide http session handling.
      Regards, Christian
      • J V
        • 384
        Thanks for the clear and to the point answer.
        Ok, so something to add via EventGhost (my amplifier communicates via this as it lacks network but has a serial connection to a computer). But a better option probably is adding it to a LoxBerry... I'll really have to experiment with it (squeezebox, tv, ....). I'd love to install it in Docker, but cannot as my current system does not support Hyper-V (old laptop), but I should manage in virtualbox just to play with it.
