Alternative Power Meter
  • toagne
    • 17.12.2017
    • 14
    Hello,
    I'm searching an alternative to the loxone power meter... I think it's overly expensive to buy modbus+powermeter for this solution.
    Do you have some alternatives?
    Thanks,
    Andrea
    • 3300
    current converter with 0-10V output connected to an analogue input of miniserver/extension
    Stromwandler, Spannungswandler, Stromsensor, Spannungssensor, AC Stromsensor, AC Spannungssensor, DC Stromsensor, DC Spannungssensor
    With use of the formular-block the power is calculated.
    Don't know what you are looking for.
    • toagne
      • 17.12.2017
      • 14
      Good point!
      I've not thinked about this.
      I want to measure the power I absorb from the network to understand if I can turn something on and have a better power utilization.
      The inverter will be a Fronius so I think I already have the power I produce.
      Thanks a lot!
      Andrea
      • Tico
        • 31.08.2016
        • 1035
        Have you considered the Fronius Smart Meter? Given that the inverter will be a Fronius, it makes it a very easy decision.
        The integration of the Fronius inverter/Smartmeter with Loxone is well documented in this forum.
        • simjoc
          • 11.05.2017
          • 32
          Maybe you can look for a second hand schneider iem series? Sometimes you can find these for 50 dollar on ebay. Uses the rs485 connection. There is a xml file on this forum.
