Ankündigung
Keine Ankündigung bisher.
Electric door lock compatible with Loxone
  • Filter
  • Electric door lock compatible with Loxone
    Could you recommend me an electric door lock for Loxone and let me know if this should work with the loxone nfc keypad/loxone application ?
    As a requirement I would like to be able to open remotely, to give temporary access (with nfc keys?) , but also to open manually (with a classical key?)
    Additionally . What kind of wiring I need to forsee at the door level ? One data or alarm cable
    As a mention I have two doors : one at the house entrence and the other one at the garden entrence
    Thank you for your advices
  • #2
    Hi, why don't you have a look at NUKI. I think they tick most of the boxes of what your looking for.
    Integration into Loxone is also possible, but implies a bit of work.
    https://www.loxwiki.eu/plugins/servl.../view/10911751
    You can probably Google Translate the content.
    I have a NUKI at my house and I am satisfied with it.
    • #3
      Thanks!
      How is this comparing with a "classical" 1-wire electrical lock ?
      https://www.loxone.com/enen/1-wire-access-control/
      • #4
        That is not actual lock, just ways of triggering the lock.
        • #5
          What about this kind of locks for the garden exterior door :
          And for the main door of the house
          What did you installed in your house ?
          Thanks for the recommendations
