the pwm signal could come from the loxone dimmer in theory, but it needs 5v pwm signal and i dont think the loxone pwm dimmer will work at 5v supply
Using RGBW extension to control 4 canals WW spots
Ein Gast antwortetehello Chistian,
this driver accept dimming with PWM so do you think we could control it with RGBW dimmer ?
Einen Kommentar schreiben:
Please read the specs.
The stripe is 24V CV, that's OK. But the dimmer only supports 2.1A per channel, the stripe has 22W/m, meaning only 2 meter per dimmer channel. -
Ein Gast antworteteok thanks for your answer Chirstian ;-) it's too bad because the RGBW dimmer was the fair price solution to control 4 diferents channels :-(Einen Kommentar schreiben:
This is a CC spot, therefore you require a 700mA CC driver. You cannot dim this with Loxones RGBW Dimmer.
You may find a CC dimmer for the DMX bus, or a CC driver that is dimmable via 0-10V. Or, if not bought yet, select another spot with constant voltage.Einen Kommentar schreiben:
Ein Gast antworteteNobody can help me ?Einen Kommentar schreiben:
Ein Gast antwortetehere the spotlight datasheet, didn't choose the drivers for the moment so i can choose CC or voltage drivers. but i need an advice to choose them ;-)
Zuletzt geändert von Gast; 29.12.2020, 08:30.Einen Kommentar schreiben:
What exactly does this mean:
6 3v 2w 700ma
If you have constant current (CC) spots, the Loxone RGBW Dimmer will not work.Einen Kommentar schreiben:
Hello, i need to control 4 differents canal with 6 mini spotlights 3v 2w 700ma per canal. So i think i need to put a dimmer bettween the extension and the lights.
Do you already make this kind of install ? if yes which kind of driver did you used ? thanks
Zuletzt geändert von Gast; 26.12.2020, 19:30.Stichworte: -
