Nano IO Air - Wiring
    So you'll be able to tell by this question, I am not an electrician....Not by any stretch.
    I am looking at the wiring diagrams here: https://www.loxone.com/enen/kb/nano-io-air/ and trying to figure out how to wire door/window contacts. Under the section "Wiring Digital Inputs" it shows sensors wired to the DIs and to the 24V "Out". In this situation how is the Nano device powered? In the section above, "Alternative Operation with 24V" it shows power being wired to 24V out and G, but this is for powering the relays. Do I wire it for 24V operation by connecting 24V out and G to a power supply and wire the inputs to the 24V Out terminal and the DIs?
    • 3301
    That's a really interessting question - i don't know.
    This issue (24V supply) isn't mentioned in the documentation. https://www.loxone.com/wp-content/up...Air_100153.pdf
    => I will ask Loxone to a) to update the documentation and b) how this should work, and what the relais are switching in this case "2 digital outputs (switching supply voltage)"
    Zuletzt geändert von Thomas M.; 24.06.2022, 11:02.
      Thomas M. kommentierte
      update ... the 24V out is the 24V "in" in the case of 24V supply
    • 3301
    "In this situation how is the Nano device powered?"
    The nano is powered with 230V, then the 24V out = 24V out.
    DIs are connected as mentioned in "Wiring the digital inputs"
    • rosco-007
      • 14.11.2016
      • 10
      Maybe this attachment will help you. It's easy. Doc1.docx
        That makes sense. I was hoping to stay away from adding a box to house the Nano with 120v power (I'm in Canada) and just use a 24v supply plugged into a wall outlet. Any options to stay away from 230v (120v) wiring?
        Alternatively, I'm hoping that wiring for 24V power for the Nano (ie in the DI side of the device) and then terminating both door contact leads into 1 DI for each contact would work. Since the door contacts don't require power. Would this work?
        Zuletzt geändert von Gast; 24.06.2022, 20:35.
        • rosco-007
          • 14.11.2016
          • 10
          Sure, why not. The doorcontact's don't need power. It is just a contact, like a switch. Normaly open (NO) or Normaly closed is not important. You can change that in the config software.
          Bye the way, there are small powersupply's that will fit into a wall box, behind a switch or socket. Just in case you need a small powersupply.
          Something like this:
