Shelly dimmer
  • frankyglobal
    • 08.01.2017
    • 12
    Shelly dimmer
    Hi. Connecting a shelly dimmer 2 to loxone using virtual output with template found in this forum . Can switch off shelly but can’t dimming with parameter <v>
    don’t know what I am doing wrong
    any help pls
    thanks in advance
  • Benjamin Jobst
    • 1213
    Hi, as I can't see how you connected the outputs it's just guessing until you post a screenshot...
    you imported the template with the http VOs? Then you should have 2 commands - switch and dim.
    Switch just has the parameters command for on/off while dim uses the command "/light/0?brightness=<v>"
    the easiest way to test this is if you just place the VO dim command on a sheet and send brightness values via the LiveView. In case that works you can connect it to a light controller etc.
    For switching off by sending 0% I connected the switch VO via a EIB Dimmer control that's working perfect.
    MfG Benny
    • frankyglobal
      • 08.01.2017
      • 12
      I’m able to switch off the shelly device sending virtual output command but can’t dimming using another vo command with Shelly Ip and light/0?brightness=<v>
      • Benjamin Jobst
        • 1213
        As I said before it is just guessing without knowing what you have done so far. So maybe you can post some screenshots of your connections and the settings of the VOs then I'm sure we find a way to get this going.
        MfG Benny
        • frankyglobal
          • 08.01.2017
          • 12
          Hola, funcionó con % de entrada directa
          /light/0?brightness=30
          pero no funciona pasando valores de input a <v> variable
          • frankyglobal
            • 08.01.2017
            • 12
            This is log I get from the http monitor:
            4 19:41:39.587 Sin título 2 Response 192.168.2.205 /light/0?brightness=nan HTTP/1.1 400 Bad Request\r\nServer: Mongoose/6.18\r\nContent-Type: text/plain\r\nConnection: close\r\nContent-Length: 21
            Shelly reply Bad Request and <v> is converted to nan
              You don't send a number in your request.
              Show a full Screenshot. Do not crop everything away.
              Use LiveView.
              Zuletzt geändert von Christian Fenzl; 26.11.2022, 23:11.
              • frankyglobal
                • 08.01.2017
                • 12
Ansichten: 1362
Größe: 101,9 KB
ID: 368618Klicke auf die Grafik für eine vergrößerte Ansicht
Ansichten: 1370
Größe: 101,9 KB
                • frankyglobal
                  • 08.01.2017
                  • 12
                  I already send <v> with virtual input
                  • MountMeru
                    • 30.01.2023
                    • 18
                    Ich habe das gleiche Problem, dass ich im Monitor NaN anstelle des Dimmwertes sehe. Bin leider noch nicht drauf gekommen wo das Problem der Zuweisung zu <v> ist. Wenn ich einen Konstanten Zahlenwert sende funktioniert dies. die Variable wird offensichtlich falsch interpretiert
                    • MountMeru
                      • 30.01.2023
                      • 18
                      Ok, hab nochmal probiert und die Lösung gefunden. Wichtig ist, dass bei den Parametern Korrektur nicht alles auf 0 steht, sondern Eingangswert 2 = 100 und Zielwert 2 = 100.
