Neue Multiverlängerung Luft immer zu lernen !!
Neue Multiverlängerung Luft immer lernen (LED: rot-grün-Orgel), Namen Air Base am Miniserver kann nicht zu suchen, um die Erweiterung zu bekommen, wie kann ich tun? Die Frequenz der Luft Verlängerung war es standardmäßig? irgendein Vorschlag ?Stichworte: - -
I think your native language is french and you wrote this thread with help by google translate?
Unfortunately this german text is nonsense - sorry.
"Multiextension Air" can't be translated
out of the context i know what you want to ask, but i can't answer. I have no multiextension air. -
You may better write in english, if possible but not with Google Translate. I did not get the story, sorry.
En Gruäss us de Schwiiz
KNX seit 2005
Miniserver seit Jan. 2011Kommentar
Dann versuch ich mal zu übersetzen: Die neue Multiextension Air befindet sich immer im Lernmodus (LED blinkt rot/grün). Am Miniserver kann die "Air-Base" nicht gefunden werden um die Erweiterung zu verbinden. Auf welcher Frequenz arbeitet die Air-Extension standardmäßig? Irgendein Vorschlag?
Maybe you understand some english: For an air extension to be working, you need an air base with your Miniserver or a Miniserver Go. Within the Loxone Config software you should first add your air base extension and then your Multi Extension.
However there is a problem with the french version of air base - due to nationally different frequency allocations, you may have to change the air base settings. This is mentioned in the french documentation - NOT in the german one. Most users here will not know about your somewhat special configuration.
Few things to be obeyed: Do NOT install the air base next to your miniserver. This will decrease link quality. Try to set up the system with your Multiextension Air next to the base so you can ensure the link quality.
For other questions you might want to have another look at the loxone documentation or contact the support - as German/Austrian users do not have to change any frequency settings.
Thanks , @hasloxone
Now I understood the document told about the air base not only the software (must have the hareware to support ) !!!
Zuletzt geändert von Automation; 18.01.2016, 19:13.Kommentar
