Steuerung Licht und Beschattung mit den Smarthome Tasten einer Logitech Harmony?
  • duncan
    • 364
    i got is sorted thanks to the advice (i used loxberry mqtt http updates to virtual inputs on the minserver rather than udp), that is until i reinstalled the ubiquiti controller on the loxberry, which totally killed the iobroker installation but left the loxberry function working still
    the combination failed a second time as well so there seems to be a compatability issue between iobroker or one of its plugins and ubiquiti
    ubiquiti coexists with the loxberry software fine
    ill have to start again with a new setup, but put ubiquiti on another pi
    • TomekWaw
      • 25.07.2019
      • 450
      Ubiquiti controler is Java.... heavy. Better to have it somewhere separate.
      And Unifi adapter in ioBroker is ok, but it's tricky.
      My advice: from insane amounts of data/object that it provides it's worth to select only one: Clients -> is_online. That's all you probably need. It makes the number of unifi objects minimal.
      • duncan
        • 364
        thanks for the advice:
        im going to put the ubiquiti controller on a separate pi
        i dont need any data elements from ubiquiti brought into iobroker/loxone so ill not install the iobroker unifi adapter
        • duncan
          • 364
          a further question:
          ive got this all working thanks to your help and decided to see if i can control the harmony hub using mqtt instead of the simple API
          in iobroker ive enabled mqtt on the harmony functions eg 'Sky' for subcribe and publish
          i can read the state of the harmony activity in the loxberry mqtt - i can see
          iobroker/harmony/0/bedroom1/activities/Sky is visible as harmony_0_bedroom1_activities_Sky with its number eg 0 for off, 2 when on
          now if i modify the mqtt from loxone using a virtual output to the loxberry using udp i can change
          harmony_0_bedroom1_activities_Sky 0 to harmony_0_bedroom1_activities_Sky 1 but the harmony iobroker entry doesnt change and the harmony doesnt turn on
          any ideas why loxone can change the mqtt broker but the mqtt broker doesnt modify the iobroker/harmony hub?
          my iobroker mqtt settings are:
Ansichten: 613
Größe: 155,5 KB
ID: 290187Klicke auf die Grafik für eine vergrößerte Ansicht
Ansichten: 623
Größe: 116,2 KB
          Zitat von TomekWaw
          duncan
          To execute Harmony commands from Loxone (both from Media Controller remote or wall button) you need to:
          1. Add Simple RestFul API adapter to ioBroker
          2. Configure it to a not used TCP port (I believe I'm using the default)
          3. Add Virtual Output and VO Commands as below:
          Virtual Output Adress: http://192.168.X.Y:8087 (X.Y - is your ioBroker IP address)
          Virtual Output Commands (few examples):
          activity Netflix
          Command for ON: /set/harmony.0.Harmony.activities.Netflix?value=1
          activity Spotify
          Command for ON: /set/harmony.0.Harmony.activities.Spotify?value=1
          activity Off
          Command for ON: /set/harmony.0.Harmony.activities.currentStatus?value=0
          command AVR VolumeUp
          Command for ON: /set/harmony.0.Harmony.AVR.VolumeUp?value=1
          command AVR VolumeDown
          Command for ON: /set/harmony.0.Harmony.AVR.VolumeDown?value=1
          command TV Info
          Command for ON: /set/harmony.0.Harmony.TV.Info?value=1
          command TV Select
          Command for ON: /set/harmony.0.Harmony.TV.Select?value=1
          command PVR Play
          Command for ON: /set/harmony.0.Harmony.PVR.Play?value=1
          command PVR Stop
          Command for ON: /set/harmony.0.Harmony.PVR.Stop?value=1
          command FR Play
          Command for ON: /set/harmony.0.Harmony.FR.Play?value=1
          command FR Pause
          Command for ON: /set/harmony.0.Harmony.FR.Pause?value=1
          You get the idea.
          Netflix, Spotify - those are examples of my Harmony activities.
          AVR, TV, PVR, FR - those are the names of my Harmony devices.
          The list of commands is pretty long and I recommend to create them as an XML virtual output template file and then just import.
          For the incoming data from ioBroker to Loxone (current activity - that's the only info Harmony provides) it's best to use MQTT-client adapter and publish to topic loxone/harmony/0/Harmony/activities/currentActivity
          Then you also need to add some MQTT Conversions. Mine are:
          PowerOff=0
          Television=1
          Netflix=2
          YouTube=3
          Spotify=4
          Music=5
          I'm sure you get it.
          I might make a tutorial out of this on LoxWiki some day.
          • TomekWaw
            • 25.07.2019
            • 450
            First you should always remember to uncheck "ack" flag on subscribe settings (this is based on my experience with ioBroker MQTT).
            Second: remember to reset this topic to 0 again (from Loxone) as this should be a pulse not a state.
            Haven't tried but should work fine.
            Zuletzt geändert von TomekWaw; 09.02.2021, 00:12.
