MQTT picoC JsonParser
  • Alex666
    • 11.12.2025
    • 3
    Hello to all, I have a project where Loxone comunicate via MQTT and I need to parse Json data. Logical way for me was write a picoC code and it does work. But it looks like picoC in loxone do have issues with memory alocation (memory leak?) as after around about 7 minutes is stops because of "out of memory" error.
    Have any of you had simmilar problem?
    That's the test code..
    // json keys names
    enum Keys {
    SUCCESS, PRICE, MAXSOC, MINSOC, STRICT, EVLIMIT, EXLIMIT, INLIMIT,
    OPERATE, USEGRID, EVUSEBAT, USELIMIT, EVUSEGRID, PRICETIME, TARGETSOC,
    CHTHRESHOLD, DISTOLIMIT, FORCEBATCH, INLIMITLOW, LIMITPRICE, FORCEBATDIS,
    METERCUTOFF, PRICEAREAID, PRICETYPEID, TARGETPOWER, CURRENTPRICE,
    TARGETSOCLOW, DISCTHRESHOLD, LOOP, NUM_KEYS
    // json keys
    char* keys[] = {
    "success","price","maxSoc","minSoc","strict"," evLi mit","exLimit","inLimit",
    "operate","useGrid","evusebat","useLimit","evu segr id","priceTime","targetSoc",
    "chtreshold","disToLimit","forceBatCh","inLimi tLow ","limitPrice","forceBatDis",
    "meterCutOff","priceareaid","pricetypeid","tar getP ower","currentPrice",
    "targetSocLow","dischtreshold","loop"
    while(TRUE)
    char buf[64];
    float values[29];
    char* json = getinputtext(0); // T1 = JSON SETTINGS input
    char* jsonReport getinputtext(1); //T2 JSON REPORT input
    if(getinput(0) == 1)
    setoutputtext(0, jsonReport); //only post report when input 1 ==1 (each 5s)
    if(json != NULL)
    // parser JSON-a
    for(int k=0; k<NUM_KEYS; k++)
    char search[32];
    sprintf(search, ""%s":", keys[k]);
    char* p = strstrskip(json, search);
    if(p != NULL)
    // skip spaces and other balasts "
    while(*p && (*p == ' ' || *p == '"')) p++;
    int i = 0;
    // search till , } or "
    while(*p && *p != ',' && *p != '}' && *p != '"' && i < sizeof(buf)-1)
    buf[i++] = *p++;
    buf[i] = 0;
    values[k] = batof(buf); // put result into values
    // drop some values to outputs
    setoutput(0, values[PRICE]); // O0 = price
    setoutput(1, values[MAXSOC]); // O1 = maxSoc
    setoutput(2, values[MINSOC]); // O2 = minSoc
    setoutput(3, values[STRICT]); // O3 = strict
    setoutput(4, values[EVLIMIT]); // O4 = evLimit
    setoutput(5, values[EXLIMIT]); // O5 = exLimit
    setoutput(6, values[INLIMIT]); // O6 = inLimit
    setoutput(7, values[OPERATE]); // O7 = operate
    setoutput(8, values[USEGRID]); // O8 = useGrid
    setoutput(9, values[EVUSEBAT]); // O9 = evusebat
    setoutput(10, values[PRICETIME]); // O10 = PRICETIME
    setoutput(11, values[LOOP]); // O11 = loop
    sleeps(1); //sleep 1s as no need to work faster...
    Best regards, Alex
  • Noschvie
    • 24.09.2018
    • 660
    It is certainly easier to leave the parsing of a JSON structure to a Loxberry.
    • Alex666
      • 11.12.2025
      • 3
      If that would be an option I would use it but it is not. I need working parser for a lot of existing projects that will be upgraded from rest api to MQTT and code do work just seems picoC in loxone do not handle memory well and there is no free() funcion supported for me to release memory after usage.
      • Alex666
        • 11.12.2025
        • 3
        Have to correct myself.. free() exists and that was the problem..
        so if some need here it is functional jsonParse program...adjust names, buffers as per your need.
        char buf[512];
        float values[29]; //
        char* json; // T1 JSON pointer to received MSG
        char search[32];
        char* p;
        // json keys names
        enum Keys {
        // json keys
        char* keys[] = {
        while(TRUE)
        if(json != NULL)
        // parser JSON-a
        if(p != NULL)
        int i = 0;
        buf[i++] = *p++;
        buf[i] = 0;
        free(p);
        free(json);
        • Jan W.
          • 30.08.2015
          • 1608
          I have some doubt that the two free statements are required. According to the documentation there is no need to have a free statement for that command. Maybe the documentation is missing that? There are explicit hints to other commands that a free statement is required later.
          "p" is just a pointer to an existing object and "strstrskip" does not allocate any memory, so there is no need to free any memory at the end.
          However I do agree, that the declaration of search and other variables should be moved to the top as Pico C is executed by an interpreter.
          Just my two cents regarding efficiency: the copy operation (sprintf(search, ""%s":", keys[k]) for each k does not look to be efficient in a loop to just to add the quotes and a colon each time. I would suggest to either move the operation away from the while-loop (of course you would need an array for "search", so a bit more of memory) or add the quotes and colon to the keys directly.
          Node-RED: IKEA Tradfri
