Loxone and HikVision ColorVu
  • Grzesiek Gik
    • 29.10.2021
    • 16
    Hello,
    i have a problem with connetcing Loxone with HikVision ColorVu version of camera.
    With normal there is no problem - working good, Not best because sometimes picture is not load and need 5 times to be right,
    Someone solved problem with another adress for camera ColorVu?
    http://xxx:65001/ISAPI/streaming/cha...02/httppreview by NVR
    or
    working only with normal type of camera.
  • 13az13
    • 29.07.2020
    • 34
    have you seen my post here and the attached PDF? https://www.loxforum.com/forum/germa...ras#post311473
    admittadley I’ve not tried with a colourvu but I have one at the office and can test/try and triage the issue with you if the attached doc in the above link doesn’t solve the issue for you. Im on my phone and just replying as I spotted this post but not reminded myself of the detail or checked the url strings vs yours but will look fully when in the office tomorrow morning
    cheers,
    Aaron
    • Grzesiek Gik
      • 29.10.2021
      • 16
      Hello, thanks for reply.
      yes, i saw these informations. That why all other cameras working. But this one... won't. Even on http doesn't work. So simply it must be wrong adress. ID channels doesnt change anything.
