Cannot upload new config
  • J V
    • 386
    Hello,
    I have a problem... Whenever I connect to the miniserver, it downloads the current config into the editor, overwriting whatever I have open.
    As such, I cannot edit my config offline, as any changes I make are overwritten - without warning - as soon as I connect to the miniserver. I do all my work offline, so now I have a brand new config with a lot of changes, and I cannot upload it to the miniserver.
    I could connect to the miniserver and - while online - make the changes to the config, but I have 50-something KNX actuators, 50-something KNX sensors, and a large number of custom images in multiple status blocks... so I would have to redo all of these in a single session to get back to a situation where I have an operation system on which I can work.
    Is there anyway to change this behaviour, or to upload a new config file?
    Thanks,
    Jörg
    Zuletzt geändert von J V; 11.11.2025, 18:16.
  • BlackSoll
    • 16.09.2022
    • 34
    Config 16 automatically loads program from Miniserver when connecting if it is newer. Change the date or save as.....your old config to sort it out ! Or just drag and move one block. So you «change config» then its newer and wont load automatically.
    • J V
      • 386
      The file was newer....
      I managed to get it by changing the project properties.
      Upon connection, Loxone Config apparently checks the project properties and even a small difference in e.g. the street name triggers the behaviour... In the previous version, it was just the project name that caused this.
