Apace2 Server startet jede Stunde neu
  • Special
    • 437
    Hallo liebe Gemeinde,
    ist es normal das der Apache2 Server jede Stunde ohne vorher auftretenden Fehler neu startet ?
    Ich würde das gerne beheben, wo würdet ihr anfangen zu suchen ?
    Log:
    [Tue May 04 20:13:11.301814 2021] [mpm_prefork:notice] [pid 920] AH00171: Graceful restart requested, doing restart
    [Tue May 04 20:13:11.741557 2021] [mpm_prefork:notice] [pid 920] AH00163: Apache/2.4.38 (Raspbian) configured -- resuming normal operations
    [Tue May 04 20:13:11.741645 2021] [core:notice] [pid 920] AH00094: Command line: '/usr/sbin/apache2'
    [Tue May 04 21:13:11.006515 2021] [mpm_prefork:notice] [pid 920] AH00171: Graceful restart requested, doing restart
    [Tue May 04 21:13:11.289069 2021] [mpm_prefork:notice] [pid 920] AH00163: Apache/2.4.38 (Raspbian) configured -- resuming normal operations
    [Tue May 04 21:13:11.289156 2021] [core:notice] [pid 920] AH00094: Command line: '/usr/sbin/apache2'
    [Tue May 04 22:13:11.018325 2021] [mpm_prefork:notice] [pid 920] AH00171: Graceful restart requested, doing restart
    [Tue May 04 22:13:11.396327 2021] [mpm_prefork:notice] [pid 920] AH00163: Apache/2.4.38 (Raspbian) configured -- resuming normal operations
    [Tue May 04 22:13:11.396407 2021] [core:notice] [pid 920] AH00094: Command line: '/usr/sbin/apache2'
    [Tue May 04 23:13:11.210517 2021] [mpm_prefork:notice] [pid 920] AH00171: Graceful restart requested, doing restart
    [Tue May 04 23:13:11.686851 2021] [mpm_prefork:notice] [pid 920] AH00163: Apache/2.4.38 (Raspbian) configured -- resuming normal operations
    [Tue May 04 23:13:11.686931 2021] [core:notice] [pid 920] AH00094: Command line: '/usr/sbin/apache2'
    [Wed May 05 00:13:10.449678 2021] [mpm_prefork:notice] [pid 920] AH00171: Graceful restart requested, doing restart
    [Wed May 05 00:13:10.759520 2021] [mpm_prefork:notice] [pid 920] AH00163: Apache/2.4.38 (Raspbian) configured -- resuming normal operations
    [Wed May 05 00:13:10.759607 2021] [core:notice] [pid 920] AH00094: Command line: '/usr/sbin/apache2'
    [Wed May 05 01:13:11.105894 2021] [mpm_prefork:notice] [pid 920] AH00171: Graceful restart requested, doing restart
    Graceful restart requested is normal in Apache -- part of crontab rotation.
    Das ist normal, du brauchst nichts zu tun.
    Übersetzungen für den Begriff 'graceful' im Englisch-Deutsch-Wörterbuch
    • Special
      • 437
      Hallo Christian,
      ich habe den Verdacht das der stündliche Neustart ca. alle 3-4 Wochen zu einen Absturz führt (siehe Anhang).
      Die Weboberfläche ist dann nicht mehr erreichbar, über SSH (Befehl: sudo /etc/init.d/apache2 restart) ) starte ich dann den Dienst wieder neu, dann läuft es wieder für die nächsten Wochen.
      Ich würde gerne die zyklischen Neustarts unterbinden um zu beobachten ob sich das Verhalten ändert.
      Kann man das über eine INI Datei unterbinden ?
        Wenn du logrotate abdrehst, schreibt Apache die Ramdisk voll, und dann stirbt Apache/LoxBerry auf jeden Fall.
        logrotate drehst du nach einschlägigen Anleitungen im Web ab.
          • 6362
          Der Apache hat einen Controll Process und entsprechend der Config Childs. Diese verwaltet der Apache auch selber und killt turnusmäßig auch seine Childs. Das schreibt der auch alles in sein Log. Der Apache/Loxberry, und nicht nur einer, von mir stirbt nicht. Auch nicht nach Monaten. Du hast da ein anderes Problem.
          • Special
            Special kommentierte
            Also dein Apace Server startet sich nicht stündlich neu ?
            Ich habe keinen Apace Server
          • Special
            Ist der nicht Standardmäßig beim Loxberry dabei ?
        • Special
          • 437
          Was würdet ihr denn tun um den Fehler zu lokalisieren ?
            • 5457
            Das ist kein Fehler. Vergiss es doch einfach. Ansonsten musst Du in die Tiefen des Systems, z. B. die Logrotate-Config anpassen, die beim Rotieren der Logfiles auch den Apache neu startet. Das wird Dir hier niemand in einem Satz erklären können.
            Lass es wie es ist, es ist kein Fehler.
            • Special
              • 437
              Wenn das kein Fehler von Apace ist, frag ich mich warum, ich etwa jeden Monat den Befehl: sudo /etc/init.d/apache2 restart eingeben muss, damit ich wieder auf die Weboberfläche komme bzw. der PI wieder richtig arbeitet.
              Kann ich irgendwie rausbekommen was dazu führt, dass dieser immer Abstürzt ?
              Ich habe für mich auch dokumentiert, wann ich dieses bemerkt und ihn mit den o.g. Befehl neu gestartet habe:
              22.02.21
              23.03.21
              05.05.21
              27.05.21
              17.06.21
              09.07.21
              31.07.21
              10.09.21
              29.10.21
              und heute am 23.11.21
                • 6362
                Was ist denn dieses Apace, von dem Du da ständig schreibst?
                • darkrain
                  darkrain kommentierte
                  Er meint den Apache Webserver auf dem Loxberry. Der frist sich nach endlicher Zeit fest, da müsste man aber auch die anderen Logfiles und Systemstati haben, um die Ursache eingrenzen zu können. Wie Prof.Mobilux schon schrieb, kann man nicht in einem Satz erklären.
