Cron jobs not executed/ default crontab setup missing
    Since some days I've noticed that cron is not executing as the weather4lox plugin is not updating.
    It seems that somehow the default crontab configuration is overridden and the loxberry customized cron.01min, ... are not executed at all.
    Could someone please provide me with the default setup to make it working again?
    Thx in advance
    • 11238
    What's your LoxBerry version?
      I've set it to pre-releases and 2.2.1 is installed.
        • 11238
        Could you update to 2.2.1.1, as we‘ve changed the Crontab handling in there.
        If it still won’t work, we need to investigate further.
          Yeah, that did the trick. Due to the cronjobs not running, it didn't even update by itself, d'oh!
          Thanks a ton.
