ich bekomme, wenn ich die IP meines Loxberry im Browser eingebe nur "cannot GET/" angezeigt.
Portainer auf Port 9000 ist aber erreichbar und auch node-red funktioniert.
Der live healthcheck mit dem emergency webserver liefert folgendes:
Sub: check_lbversion Title: LoxBerry Version Status: OK (code 5) Desc: Checks the LoxBerry Version Result: Current Version: 2.2.1.2 / No newer Release available. Logfile: URL: https://www.loxwiki.eu/x/b4WdAQ Sub: check_kernel Title: Linux Kernel Status: Info (code 6) Desc: Checks the current installed Linux Kernel Result: Linux loxberry 4.19.118-v7+ #1311 SMP Mon Apr 27 14:21:24 BST 2020 armv7l GNU/Linux Logfile: URL: Sub: check_arch Title: System Architecture Status: Info (code 6) Desc: Checks the system architecture Result: ARM / Raspberry Pi 3 Model B Plus Rev 1.3^@ Logfile: URL: Sub: check_cputemp Title: CPU Temperature Status: OK (code 5) Desc: Checks maximum CPU Temperature Result: Current CPU Temperature is 50.5°C. Since last reboot the cpu never reached Raspberry's soft or critical temperature limit. This is fine. Logfile: URL: Sub: check_voltage Title: Voltage Status: OK (code 5) Desc: Checks the voltage of the power supply Result: No under-voltage nor system throttling nor capped ARM frequency detected. This is fine. Logfile: URL: https://www.loxwiki.eu/display/LOXBERRY/Hardware#Hardware-Netzteil Sub: check_readonlyrootfs Title: RootFS Status: OK (code 5) Desc: Checks if the RootFS is mounted correctly Result: RootFS is mounted ReadWrite. This is fine. Logfile: URL: Sub: check_rootfssize Title: RootFS free space Status: OK (code 5) Desc: Checks the rootfs for available space Result: LoxBerry's RootFS has more than 10% free discspace (AVAL 21.7GB/SIZE 29.2GB). Logfile: URL: Sub: check_tmpfssize Title: RAMDiscs free space Status: OK (code 5) Desc: Checks the ramdiscs for available space Result: All ramdiscs have more than 25% free discspace. Logfile: URL: https://www.loxwiki.eu/x/QINYAg Sub: check_systemload Title: System Load Status: OK (code 5) Desc: Checks the system load Result: The system load is: 0.00 0.04 0.07 1/200 1740. Your system has 4 CPUs installed. The load is fine - maybe LoxBerry is even bored :-) Logfile: URL: http://www.brendangregg.com/blog/2017-08-08/linux-load-averages.html Sub: check_logdb Title: Log Database Status: OK (code 5) Desc: Checks the consistence of the Logfile Database Result: Init logfile database is ok. 153 log sessions with 2240 attributes stored. 55 logfiles are managed. Database size is 156.0KB. Logfile: URL: https://www.loxwiki.eu/x/oIMKAw Sub: check_notifydb Title: Notification Database Status: OK (code 5) Desc: Checks the consistence of the Notification Database Result: Init notification database is ok. 9 notifications with 20 attributes stored. It contains 7 info and 1 error notifications.Database size is 24.0KB. Logfile: URL: Sub: check_miniservers Title: Miniserver Access Status: WARNING (code 4) Desc: Checks access to your Miniservers Result: No Miniservers configured, or Miniserver configuration not complete. Logfile: URL: https://www.loxwiki.eu/x/QYgKAw Sub: check_reboot_required Title: Reboot required Status: OK (code 5) Desc: Checks if LoxBerry or a plugin requests a reboot Result: LoxBerry and plugins do not require a reboot of your LoxBerry. Logfile: URL: https://www.loxwiki.eu/x/fogKAw Sub: check_loglevels Title: Plugin Loglevels Status: OK (code 5) Desc: Checks for debug loglevel Result: No plugin is configured for loglevel DEBUG. (Some plugins may have it's own setting) Logfile: URL:
Schöne Grüße,
Marco
So hätte es also auch geklappt. Danke euch!
