Hallo, leider macht mein Loxberry auf dem RaspPi3 Keine Updates mehr. Kann jemand aus den Error Codes was erkennen?
lg
<LOGSTART> 21.10.2021 07:44:53 TASK STARTED
<LOGSTART> Update from v2.2.0.3 to v2.2.1.2
07:44:53.090 <INFO> LoxBerry Version 2.2.0.3 ( is_raspberry.cfg )
07:44:53.090 <INFO> Loglevel: 7
07:44:53.095 <INFO> Version : v2.2.1.2
07:44:53.095 <INFO> Name : V2.2.1.2 Stability Release
07:44:53.095 <INFO> Description :
07:44:53.095 <INFO> Published : 2021-08-29T08:16:26Z
07:44:53.096 <INFO> Releasetype : Release
07:44:53.096 <INFO> Checking if another update is running...
07:44:53.113 <OK> No other update running.
07:44:53.113 <OK> Update auf v2.2.1.2 gestartet. Im LoxBerry Update Verlauf findest du die Logdatei mit Details.
07:44:53.113 <INFO> Update auf v2.2.1.2 gestartet. Im LoxBerry Update Verlauf findest du die Logdatei mit Details.
07:44:53.113 <INFO> JSON: {"releasetype":"release","release_body":"","rel eas e_version":"v2.2.1.2","release_new":"1","min_versi on":"v1.0.0","keepinstallfiles":"0","keepupdatef il es":null,"max_version_next":"v3.99.99","dryrun": nu ll,"published_at":"2021-08-29T08:16:26Z","max_version":"v2.99.99","release_zi purl":"https://api.github.com/repos/mschlenstedt/Loxberry/zipball/2.2.1.2","release_name":"V2.2.1.2 Stability Release","logfile":"/opt/loxberry/log/system/loxberryupdate/20211021_074453_086_update.log","branch":null,"inf o":"Update auf v2.2.1.2 gestartet. Im LoxBerry Update Verlauf findest du die Logdatei mit Details."}
07:44:53.113 <INFO> Starting download procedure for /tmp/loxberry.v2.2.1.2.zip...
07:44:53.114 <INFO> Download preparing. URL: https://api.github.com/repos/mschlen...ipball/2.2.1.2 Filename: /tmp/loxberry.v2.2.1.2.zip
07:44:53.114 <INFO> Try 1: Download of release... (21.10.2021 07:44:53)
07:44:54.242 <OK> Download saved successfully in /tmp/loxberry.v2.2.1.2.zip
07:44:54.243 <OK> Download successfully stored in /tmp/loxberry.v2.2.1.2.zip.
07:44:54.244 <INFO> Starting unzip procedure for /tmp/loxberry.v2.2.1.2.zip...
07:44:54.244 <INFO> Running unzip
07:44:54.244 <INFO> Cleaning up destination folder /tmp/loxberryupdate...
07:44:54.455 <INFO> Extracting ZIP file /tmp/loxberry.v2.2.1.2.zip to folder /tmp/loxberryupdate...
07:44:54.977 <OK> Unzipping was successful.
07:44:54.977 <INFO> Deleting zipfile after unzip was successful
07:44:54.981 <INFO> Starting prepare update procedure...
07:44:54.981 <INFO> Seeking for unzipped sub-directory in /tmp/loxberryupdate...
07:44:54.981 <OK> Update directory is /tmp/loxberryupdate/mschlenstedt-Loxberry-d9db9fb
07:44:54.981 <INFO> LoxBerry Update programs are updated from the release to your LoxBerry...
07:44:54.983 <INFO> Copying new file exlude list from release to your LoxBerry
07:44:54.984 <OK> Update checked and prepared successfully.
07:44:54.985 <OK> Prepare update successful.
07:44:54.985 <INFO> Forking loxberryupdate...
07:44:54.989 <INFO> Executing LoxBerry Update forked...
<LOGEND> 21.10.2021 07:44:54 TASK FINISHED
07:44:55.651 <OK> Update handed over from LoxBerry Update Check to LoxBerry Update
07:44:55.651 <INFO> Executing user of loxberryupdate is root
07:44:55.651 <OK> This update was manually triggered.
07:44:55.651 <INFO> Locking lbupdate - return immediately if lock stat is not secure...
07:44:55.703 <OK> Lock successfully set.
07:44:55.726 <INFO> Version parameter 'v2.2.1.2' was given, destination version is v2.2.1.2.
07:44:55.727 <INFO> Current LoxBerry version is v2.2.0.3
07:44:55.727 <INFO> Changing the owner of the update files to loxberry:loxberry...
07:44:55.764 <OK> Changing owner was successful.
07:44:55.764 <INFO> Pre-Changing the owner of special files in updatedir to root:root...
07:44:55.773 <OK> Pre-Changing owner was successful.
07:44:55.773 <INFO> Updating apt-keys...
07:44:56.355 <OK> Keys updated
07:44:56.356 <INFO> Running rsync command...
2021/10/21 07:44:56 [3038] building file list
2021/10/21 07:44:56 [3038] .d....og... sbin/
2021/10/21 07:44:56 [3038] .d....og... sbin/loxberryupdate/
2021/10/21 07:44:56 [3038] .d....og... sbin/notifyproviders/
2021/10/21 07:44:56 [3038] .d...p..... webfrontend/html/XL/
2021/10/21 07:44:56 [3038] .d...p..... webfrontend/html/XL/examples/
2021/10/21 07:44:56 [3038] sent 35.59K bytes received 988 bytes 73.16K bytes/sec
2021/10/21 07:44:56 [3038] total size is 9.95M speedup is 272.02
07:44:56.589 <OK> rsync finished successful.
07:44:56.589 <INFO> Restoring permissions of /opt/loxberry of your LoxBerry...
LoxBerry home directory is /opt/loxberry
chmod loxberry:loxberry: 1736 files changed
changed ownership of '/opt/loxberry/system/dphys-swapfile/97-swappiness.conf' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/system/dphys-swapfile/dphys-swapfile.md5' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/system/dphys-swapfile/dphys-swapfile' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/system/dphys-swapfile/97-swappiness.conf.md5' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/system/dphys-swapfile' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/system/daemons/plugins/Text2SIP' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/system/daemons/plugins/.dummy' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/system/daemons/plugins' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/system/daemons' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/system/cron/cron.d/.dummy' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/system/cron/cron.d/lbdefaults' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/system/cron/cron.d/setloxberryid' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/system/cron/cron.d' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/changehostname.sh' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/pluginsupdate.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/resetpermissions.sh' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/installpackages.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/usb-mount.sh' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/serviceshelper' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/testbashenv.sh' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/testenvironment.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/setrootpasswd.exp' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/createtmpfsfoldersinit.sh' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/setdatetime.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/updaterebootwebserver.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/setloxberryid.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/setswap.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/setenvironment.sh' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/createskelfolders.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/clone_sd.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/credentialshandler.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/activate_i2c.sh' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/testram.sh' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/emergencywebserver.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/setserial' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/testenvironment.sh' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/setloxberrypasswdsmb.exp' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/log_maint.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/notifyproviders/email.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/notifyproviders' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/openvpn' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v2.0.0.2.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.2.2.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.0.1.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v2.0.2.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.2.2.2.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v0.3.3.3.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.4.1.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v2.0.0.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/updatereboot_v1.2.0.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.2.0.1.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.2.0.3.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v2.2.0.5.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v2.0.2.1.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v0.3.5.5.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v0.3.5.6.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v2.2.0.3.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/updatereboot_v2.0.0.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.0.3.1.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.4.2.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v0.3.3.5.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v0.9.9.1.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.2.0.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v2.2.1.1.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v2.2.1.2.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/updatereboot_v2.2.0.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.2.4.1.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.0.4.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v2.0.0.4.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/.dummy' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v2.0.1.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.0.3.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.4.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v0.3.3.4.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.2.4.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.0.2.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/updatereboot_v1.4.0.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v0.3.1.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v2.0.0.1.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.2.1.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.2.3.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.2.5.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v0.3.5.7.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.2.4.2.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.2.5.3.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v2.2.0.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v0.3.5.4.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v2.0.2.2.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.2.1.2.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v0.3.3.1.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.4.0.3.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v1.0.4.1.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate/update_v0.3.5.3.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/ssdpd' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/sleeper.sh' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/createpluginfolders.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate_cron.sh' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryinit.sh' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/installcrontab.sh' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/setloxberrypasswd.exp' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/healthcheck.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/sethosts.sh' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/resize_rootfs' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/setmail' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdatecheck.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/plugininstall.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/migrate_generalcfg.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/loxberryupdate.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/openvpn-ip' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin/watchdog_cron.pl' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/sbin' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/system/logrotate/logrotate' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/system/logrotate' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/system/php/loxberry-cli.ini' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/system/php/loxberry-apache.ini' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/system/php' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/config/system/securepin.dat' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/data/system/plugindatabase.json-' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/system/profile/loxberry.sh' from loxberry:loxberry to root:root
changed ownership of '/opt/loxberry/system/vsftpd/vsftpd.conf' from loxberry:loxberry to root:root
mode of '/opt/loxberry/config/system/general.cfg.default' changed from 0644 (rw-r--r--) to 0600 (rw-------)
mode of '/opt/loxberry/config/system/general.json.default' changed from 0644 (rw-r--r--) to 0600 (rw-------)
mode of '/opt/loxberry/config/system/htusers.dat.default' changed from 0644 (rw-r--r--) to 0600 (rw-------)
mode of '/opt/loxberry/config/system/languages.default' changed from 0644 (rw-r--r--) to 0600 (rw-------)
mode of '/opt/loxberry/config/system/lockfiles.default' changed from 0644 (rw-r--r--) to 0600 (rw-------)
mode of '/opt/loxberry/config/system/mail.json.default' changed from 0644 (rw-r--r--) to 0600 (rw-------)
mode of '/opt/loxberry/config/system/securepin.dat' changed from 0644 (rw-r--r--) to 0600 (rw-------)
mode of '/opt/loxberry/config/system/securepin.dat.default' changed from 0644 (rw-r--r--) to 0600 (rw-------)
mode of '/opt/loxberry/config/system/update-exclude.system' changed from 0644 (rw-r--r--) to 0600 (rw-------)
mode of '/opt/loxberry/config/system/securepin.dat' changed from 0600 (rw-------) to 0644 (rw-r--r--)
mode of '/opt/loxberry/libs/bashlib/testing/testnotify.sh' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/bashlib/initlog.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/bashlib/iniparser.sh' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/bashlib/notify.sh' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/bashlib/initlog_obsolete.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/File/Samba.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/Unix/Lsof/Result.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/Unix/Lsof.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/Data/Dump.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/Net/MQTT/Simple/SSL.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/Net/MQTT/Simple.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/Hash/Flatten.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/System.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/mshttp_get.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/Lock.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/epoch2lox.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/json_param.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/json_lockexclusive.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testlog_loglevelchange.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/readlang.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/json_jsblock.cgi' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/test_plugindb_v2.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/json_flat.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/lbcountry.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testmqttcred.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/get_miniservers.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testnotify.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/json_param.tmpl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/teststorage.cgi' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/test_htmlmail.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/version.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/mshttp_call.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testlock3.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/xmlparse.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/test_general.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/test_get_ftpport.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testlog_noobject.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testlock.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testio_http.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/currtime.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testlog.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/test_get_miniservers.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testssl.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/sqlite.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testio_udp.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/teststoragehtml.cgi' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/check_secpin.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/jsontestdata2.json' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/test_plugindb_shadow.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testexecute.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/json_encode.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testlogdb.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/mqtt_publish.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/sqlite.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/mqtt_rapidpublish.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/test_VIHTTP_template.cgi' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testlog_recreate.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testgetminiservers.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/notif.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testlock2.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/json_testing.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/mqtt_get.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testsystem.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/testing/testrebootrequired.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/Log.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/examples/mqtt_publish_via_udp.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/examples/mqtt_publish_direct.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/LoxoneTemplateBuilder.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/Update.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/JSON.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/TimeMes.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/System/PluginDB.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/System/General.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/System_v1.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/LoxBerry/Web.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/perllib/Embed/Persistent.pm' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/testing/token.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/testing/testlog.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/testing/testnotify.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/testing/currtime.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/testing/xl/test_xlmqtt.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/testing/xl/test_xl_suncalc.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/testing/xl/test_xl2.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/testing/xl/test_xl_constants.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/testing/xl/test_xl.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/testing/testsystem_plugins.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/testing/test_log_changeloglevel.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/testing/testgetminiservers.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/testing/testrebootrequired.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/testing/testlog_noobject.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/testing/testlog_recreate.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/testing/epoch2lox.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/testing/msudp_send.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/testing/mqtt_connectiondetails.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/testing/test_loxberryjson.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/testing/jsonrpc-client-test.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/testing/test_loxonetemplatebuilder.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/testing/testnotify_ext.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/testing/token2.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/testing/testlang.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/testing/mshttp.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/testing/mqtt_publish.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/testing/testlbweb.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/testing/testlog_renew_session.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/testing/test_get_miniservers.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/testing/testscript_loxberry_system.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/testing/lbcountry.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/testing/mqtt_connect.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/testing/xmlparse.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/loxberry_io.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/Datto/JsonRpc/Exceptions/ImplementationException.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/Datto/JsonRpc/Exceptions/ApplicationException.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/Datto/JsonRpc/Exceptions/Exception.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/Datto/JsonRpc/Exceptions/MethodException.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/Datto/JsonRpc/Exceptions/ArgumentException.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/Datto/JsonRpc/Client.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/Datto/JsonRpc/Error.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/Datto/JsonRpc/Evaluator.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/Datto/JsonRpc/Server.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/Datto/JsonRpc/Response.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/XL/waze.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/loxberry_storage.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/suncalc/README.md' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/suncalc/composer.json' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/suncalc/LICENSE' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/suncalc/suncalc.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/loxberry_json.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/loxberry_XL.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/loxberry_system.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/Config/Lite.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/Config/Lite/Exception/Runtime.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/Config/Lite/Exception/UnexpectedValue.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/Config/Lite/Exception/InvalidArgument.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/loxberry_loxonetemplatebuilder.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/loxberry_web.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/LoxBerry/JsonRpcApi.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/phpMQTT/examples/publish.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/phpMQTT/examples/README.md' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/phpMQTT/examples/subscribe.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/phpMQTT/composer.json' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/phpMQTT/phpMQTT.php' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/phpMQTT/LICENSE' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/libs/phplib/phpMQTT/README' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/sbin/notifyproviders/email.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/sbin/loxberryupdate/.dummy' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/bin/dirtree_md5.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/bin/files_analyzer debian libs.txt' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/bin/files_analyzer.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/webfrontend/htmlauth/system/services_timeserver.cgi' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/webfrontend/htmlauth/system/testing/teststorage.cgi' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/webfrontend/htmlauth/system/testing/teststorage2.cgi' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/webfrontend/htmlauth/system/tools/ajax-download-handler.cgi' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/webfrontend/htmlauth/system/tools/ajax-notification-handler.cgi' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/webfrontend/htmlauth/system/tools/ajax-storage-handler.cgi' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/webfrontend/htmlauth/system/tools/get_notifications.cgi' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/webfrontend/htmlauth/system/tools/showalllogs_old.cgi' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/webfrontend/htmlauth/system/tools/showrawlogs.cgi' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/webfrontend/htmlauth/system/tools/showrawnotifications.cgi' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/webfrontend/htmlauth/system/testing/test-interfaces.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/webfrontend/htmlauth/system/tools/languagecheck.pl' changed from 0644 (rw-r--r--) to 0755 (rwxr-xr-x)
mode of '/opt/loxberry/webfrontend/html/XL' changed from 0755 (rwxr-xr-x) to 0500 (r-x------)
mode of '/opt/loxberry/webfrontend/html/XL/examples' changed from 0755 (rwxr-xr-x) to 0500 (r-x------)
mode of '/opt/loxberry/webfrontend/html/XL/important_info.txt' changed from 0644 (rw-r--r--) to 0500 (r-x------)
mode of '/opt/loxberry/webfrontend/html/XL/user' changed from 0700 (rwx------) to 0500 (r-x------)
mode of '/opt/loxberry/webfrontend/html/XL/user' changed from 0500 (r-x------) to 0700 (rwx------)
mode of '/opt/loxberry/webfrontend/html/XL/examples/austria_covid_bezirk.php' changed from 0644 (rw-r--r--) to 0700 (rwx------)
mode of '/opt/loxberry/webfrontend/html/XL/examples/austria_ooe_wasserpegel.php' changed from 0644 (rw-r--r--) to 0700 (rwx------)
mode of '/opt/loxberry/webfrontend/html/XL/examples/de_bundesliga.php' changed from 0644 (rw-r--r--) to 0700 (rwx------)
mode of '/opt/loxberry/webfrontend/html/XL/examples/empty_template.php' changed from 0644 (rw-r--r--) to 0700 (rwx------)
mode of '/opt/loxberry/webfrontend/html/XL/examples/gruenland.php' changed from 0644 (rw-r--r--) to 0700 (rwx------)
mode of '/opt/loxberry/webfrontend/html/XL/examples/waze_routing.php' changed from 0644 (rw-r--r--) to 0700 (rwx------)
07:44:56.950 <OK> Restoring permissions was successful.
07:44:56.950 <INFO> Searching and preparing update scripts...
07:44:56.965 <INFO> Reading current update script fail state from general configuration...
07:44:56.978 <OK> All previously executed update scripts were successful.
07:44:56.979 <INFO> Running update scripts...
07:44:56.979 <INFO> Script version: v0.3.1
07:44:56.980 <INFO> Skipping. v0.3.1 too old version.
07:44:56.980 <INFO> Script version: v0.3.3.1
07:44:56.980 <INFO> Skipping. v0.3.3.1 too old version.
07:44:56.980 <INFO> Script version: v0.3.3.3
07:44:56.981 <INFO> Skipping. v0.3.3.3 too old version.
07:44:56.981 <INFO> Script version: v0.3.3.4
07:44:56.981 <INFO> Skipping. v0.3.3.4 too old version.
07:44:56.982 <INFO> Script version: v0.3.3.5
07:44:56.982 <INFO> Skipping. v0.3.3.5 too old version.
07:44:56.982 <INFO> Script version: v0.3.5.3
07:44:56.982 <INFO> Skipping. v0.3.5.3 too old version.
07:44:56.983 <INFO> Script version: v0.3.5.4
07:44:56.983 <INFO> Skipping. v0.3.5.4 too old version.
07:44:56.983 <INFO> Script version: v0.3.5.5
07:44:56.984 <INFO> Skipping. v0.3.5.5 too old version.
07:44:56.984 <INFO> Script version: v0.3.5.6
07:44:56.984 <INFO> Skipping. v0.3.5.6 too old version.
07:44:56.984 <INFO> Script version: v0.3.5.7
07:44:56.985 <INFO> Skipping. v0.3.5.7 too old version.
07:44:56.985 <INFO> Script version: v0.9.9.1
07:44:56.985 <INFO> Skipping. v0.9.9.1 too old version.
07:44:56.986 <INFO> Script version: v1.0.1
07:44:56.986 <INFO> Skipping. v1.0.1 too old version.
07:44:56.986 <INFO> Script version: v1.0.2
07:44:56.986 <INFO> Skipping. v1.0.2 too old version.
07:44:56.987 <INFO> Script version: v1.0.3
07:44:56.987 <INFO> Skipping. v1.0.3 too old version.
07:44:56.987 <INFO> Script version: v1.0.3.1
07:44:56.988 <INFO> Skipping. v1.0.3.1 too old version.
07:44:56.988 <INFO> Script version: v1.0.4
07:44:56.988 <INFO> Skipping. v1.0.4 too old version.
07:44:56.988 <INFO> Script version: v1.0.4.1
07:44:56.989 <INFO> Skipping. v1.0.4.1 too old version.
07:44:56.989 <INFO> Script version: v1.2.0
07:44:56.989 <INFO> Skipping. v1.2.0 too old version.
07:44:56.990 <INFO> Script version: v1.2.0.1
07:44:56.990 <INFO> Skipping. v1.2.0.1 too old version.
07:44:56.990 <INFO> Script version: v1.2.0.3
07:44:56.990 <INFO> Skipping. v1.2.0.3 too old version.
07:44:56.991 <INFO> Script version: v1.2.1
07:44:56.991 <INFO> Skipping. v1.2.1 too old version.
07:44:56.991 <INFO> Script version: v1.2.1.2
07:44:56.992 <INFO> Skipping. v1.2.1.2 too old version.
07:44:56.992 <INFO> Script version: v1.2.2
07:44:56.992 <INFO> Skipping. v1.2.2 too old version.
07:44:56.992 <INFO> Script version: v1.2.2.2
07:44:56.993 <INFO> Skipping. v1.2.2.2 too old version.
07:44:56.993 <INFO> Script version: v1.2.3
07:44:56.993 <INFO> Skipping. v1.2.3 too old version.
07:44:56.994 <INFO> Script version: v1.2.4
07:44:56.994 <INFO> Skipping. v1.2.4 too old version.
07:44:56.994 <INFO> Script version: v1.2.4.1
07:44:56.995 <INFO> Skipping. v1.2.4.1 too old version.
07:44:56.995 <INFO> Script version: v1.2.4.2
07:44:56.995 <INFO> Skipping. v1.2.4.2 too old version.
07:44:56.995 <INFO> Script version: v1.2.5
07:44:56.996 <INFO> Skipping. v1.2.5 too old version.
07:44:56.996 <INFO> Script version: v1.2.5.3
07:44:56.996 <INFO> Skipping. v1.2.5.3 too old version.
07:44:56.996 <INFO> Script version: v1.4
07:44:56.997 <INFO> Skipping. v1.4 too old version.
07:44:56.997 <INFO> Script version: v1.4.0.3
07:44:56.997 <INFO> Skipping. v1.4.0.3 too old version.
07:44:56.998 <INFO> Script version: v1.4.1
07:44:56.998 <INFO> Skipping. v1.4.1 too old version.
07:44:56.998 <INFO> Script version: v1.4.2
07:44:56.998 <INFO> Skipping. v1.4.2 too old version.
07:44:56.999 <INFO> Script version: v2.0.0
07:44:56.999 <INFO> Skipping. v2.0.0 too old version.
07:44:56.999 <INFO> Script version: v2.0.0.1
07:44:57.000 <INFO> Skipping. v2.0.0.1 too old version.
07:44:57.000 <INFO> Script version: v2.0.0.2
07:44:57.000 <INFO> Skipping. v2.0.0.2 too old version.
07:44:57.000 <INFO> Script version: v2.0.0.4
07:44:57.001 <INFO> Skipping. v2.0.0.4 too old version.
07:44:57.001 <INFO> Script version: v2.0.1
07:44:57.001 <INFO> Skipping. v2.0.1 too old version.
07:44:57.002 <INFO> Script version: v2.0.2
07:44:57.002 <INFO> Skipping. v2.0.2 too old version.
07:44:57.002 <INFO> Script version: v2.0.2.1
07:44:57.003 <INFO> Skipping. v2.0.2.1 too old version.
07:44:57.003 <INFO> Script version: v2.0.2.2
07:44:57.003 <INFO> Skipping. v2.0.2.2 too old version.
07:44:57.003 <INFO> Script version: v2.2.0
07:44:57.004 <INFO> Skipping. v2.2.0 too old version.
07:44:57.004 <INFO> Script version: v2.2.0.3
07:44:57.004 <INFO> Skipping. v2.2.0.3 too old version.
07:44:57.005 <INFO> Script version: v2.2.0.5
07:44:57.005 <INFO> Running update script for v2.2.0.5...
07:44:57.036 <INFO> Executing /opt/loxberry/sbin/loxberryupdate/update_v2.2.0.5.pl release=v2.2.1.2 logfilename=/opt/loxberry/log/system/loxberryupdate/20211021_074453_086_update.log cron= updatedir=/tmp/loxberryupdate/mschlenstedt-Loxberry-d9db9fb
<OK> Update script /opt/loxberry/sbin/loxberryupdate/update_v2.2.0.5.pl started.
<INFO> Checking for /boot/cmdline.txt and /boot/config.txt...
<INFO> Files exist. Fine. Nothing to do.
<OK> Update script /opt/loxberry/sbin/loxberryupdate/update_v2.2.0.5.pl finished.
07:44:57.357 <INFO> exec_perl_script /opt/loxberry/sbin/loxberryupdate/update_v2.2.0.5.pl release=v2.2.1.2 logfilename=/opt/loxberry/log/system/loxberryupdate/20211021_074453_086_update.log cron= updatedir=/tmp/loxberryupdate/mschlenstedt-Loxberry-d9db9fb with user - errcode 0
07:44:57.357 <INFO> Script version: v2.2.1.1
07:44:57.358 <INFO> Running update script for v2.2.1.1...
07:44:57.381 <INFO> Executing /opt/loxberry/sbin/loxberryupdate/update_v2.2.1.1.pl release=v2.2.1.2 logfilename=/opt/loxberry/log/system/loxberryupdate/20211021_074453_086_update.log cron= updatedir=/tmp/loxberryupdate/mschlenstedt-Loxberry-d9db9fb
<OK> Update script /opt/loxberry/sbin/loxberryupdate/update_v2.2.1.1.pl started.
<INFO> Repairing apt sources - one of the rasbian mirrors are not active anymore...
<OK> /system/apt/loxberry.list installed.
<OK> /opt/loxberry/system/apt/loxberry.list owner changed to root.
<OK> Configuring dpkg successfully.
<INFO> Clean up apt-databases and update
<OK> Apt packages autoremoved successfully.
<ERROR> Error updating apt database - Error 100
Get:1 http://debian.fhem.de/nightly InRelease [1912 B]
Hit:2 http://ftp.agdsn.de/pub/mirrors/raspbian/raspbian buster InRelease
Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:4 https://dl.yarnpkg.com/debian stable InRelease
Hit:5 https://deb.nodesource.com/node_12.x buster InRelease
Reading package lists...
<OK> Apt cache cleaned successfully.
<INFO> Updating f*cking changed YARN key. What the f*ck they are doing?!...
<INFO> Enabling Emergency Webserver...
<OK> /system/daemons/system/05-emergencywebserver installed.
<OK> /opt/loxberry/system/daemons/system/05-emergencywebserver owner changed to root.
<OK> /system/cron/cron.hourly installed.
<OK> /opt/loxberry/system/cron/cron.hourly owner changed to root.
<INFO> Updating LoxBerry cron folders execution behaviour...
<OK> /system/cron/cron.d/lbdefaults installed.
<OK> /opt/loxberry/system/cron/cron.d/lbdefaults owner changed to root.
<INFO> Installing pre-requisites for LoxBerry RAMDISK File Analyzer...
<OK> Packages libsys-filesystem-perl libipc-run3-perl libhash-merge-perl successfully installed
<ERROR> Update script /opt/loxberry/sbin/loxberryupdate/update_v2.2.1.1.pl finished with errors.
07:45:27.871 <INFO> exec_perl_script /opt/loxberry/sbin/loxberryupdate/update_v2.2.1.1.pl release=v2.2.1.2 logfilename=/opt/loxberry/log/system/loxberryupdate/20211021_074453_086_update.log cron= updatedir=/tmp/loxberryupdate/mschlenstedt-Loxberry-d9db9fb with user - errcode 1
07:45:27.871 <ERROR> Update-Script update_v2.2.1.1 returned errorcode 1. Despite errors loxberryupdate.pl will continue.
07:45:27.871 <INFO> Setting update script update_v2.2.1.1 as failed in general configuration.
07:45:27.871 <INFO> Updating update script fail state in general configuration...
07:45:27.873 <WARNING> LoxBerry Update was SUCCESSFULL, but skipped at least 1 warnings or errors. Check the log.
07:45:27.874 <CRITICAL> LoxBerry Update exited or terminated with an error. Errorcode: 1
<LOGEND> LoxBerry Update processing finished.
<LOGEND> 21.10.2021 07:45:27 TASK FINISHED
