Installation failed
Hi, I´ve got a new Pi 4 Model B 2GB rev.1.5 (b03115) bought a few days ago. Seems that Loxberry image 2.2.0c is not up to date to cover this revision. Pi does not boot from SD card. When I connect monitor it shows a message "This board requires new software". I tried to download image from different servers, and also tried to write image by Win32DiskImager as well as by Raspberry Pi Imager several times. Tried to change ARM frequency to a different value, as well as to add to config arm_boost=1. All without success. This PI works with the original OS (Bullseye) without any problems. Can anybody from Loxberry developers confirm?
You should try different values for "over_voltage" and "arm_freq" in "config.txt". Start with:
over_voltage=2
arm_freq=1800
or read this thread: https://www.loxforum.com/forum/proje...ich#post335504Zuletzt geändert von Gast; 29.01.2022, 18:50.Kommentar
#17.1Gast kommentierte29.01.2022, 19:51Kommentar bearbeitenHi Eisi2003, I tried several combinations of over_volatage and arm_freq. Does not work. I see on the boot screen, above "This board requires newer software" as well "start4.elf is not compatible" What messages did you get when your Pi did not boot?
Hey all,
the next image with LoxBerry 3.0 will take some more time I am afraid. But I did a quick'n'dirty hack to the existing image - maybe this is enough to get the new Pi4 boot with it. Unfortunately I cannot test here - please have a try and let me know if it works:
https://download.loxberry.de/testing..._pippin.img.7zZuletzt geändert von Prof.Mobilux; 05.02.2022, 11:41.LoxBerry: https://wiki.loxberry.de/startKommentar
Unfortunately it is not working for me.
It says loxberry login: but keyboard and network is not working.:-(
i am a network technic. so network settings should not be the problem.
Hi, I tried new image, but facing problem with "Failed to start - Raise network interfaces". LAN or Wifi via network.txt does not work. still same behaviour. Unfortunately keyboard does not work, I´m unable to open "systemctl". Any ideas?
Habe gesehen das die überarbeitetet Version auf einem anderem Mirror liegt.
Loxberry startet jetzt durch aber ich habe den gleichen Fehler wie hmates. Netzwerk konnte nicht gestartet werden und Tastatur geht auch nicht. Es sieht so aus, als hätten die USB Ports noch nicht mal Strom!
Das Standard Raspbian Image läuft ohne Probleme. USB Ports gehen auch.Kommentar
Hi, Thanks for your support in advance! Below see my network.txt content. Only doubt I have is wpa-psk in the file vs wpa2 security I have on my wifi. I´m running Unifi, there is no possibility to choose weaker security than wpa2. Standard Raspbian image is running without problem.
auto lo
iface lo inet loopback
allow-hotplug wlan0
iface wlan0 inet dhcp
wpa-ssid xwlan
wpa-psk 1234567890
Is it possible to make the setup process with the further image (c) on a pi 3, login as root and make a Distupgrade and plug the sd-card in a pi4???
With the (d) image I got the same error.
By the way, my pi is connect via LAN Kabel and I have the same problems like hmates.
Ok, seems that the "quick'n'dirty" hack I did to the existing image doens't work. Most properly because of missing firmware/drivers for the USB stack on that new Pi4. So I am afraid you all have to wait for the next "real" image.LoxBerry: https://wiki.loxberry.de/startKommentar
