First time installation problem - Failed to start raised network interfaces
  • Joe_M
    • 09.03.2022
    • 5
    Hello - excuse me for writing in English, I don't speak German.
    I am trying to install Loxberry for the first time and am getting the error message "Failed to start raised network interfaces" when viewing the boot on screen. The attached is the screen I am seeing after booting. I have tried several times with different SD cards and a different Rasberry Pi and get the same error. The Pi is attached to the LAN but does not show up in my firewall device list. I have tried adding the WLAN network.txt file but no difference.
    Please if anyone can assist I will be grateful. It's ok to reply in German - the Google translate works very well.
    I am using Rasberry Pi 4 8GB
    Thanks
    Joe
    Zuletzt geändert von Joe_M; 04.11.2022, 17:02.
    • 6344
    Your screen shows a target network online and no fail. What would you like to see there?
    • Joe_M
      • 09.03.2022
      • 5
      Hi - I've attached another image showing the fail. The LoxBerry is not visible on my network and has not picked up an IP address via DHCP. Thanks
        • 5051
        Do you try to use LAN? There are two different images - depending on your hardware only one of them may work. Please try both!
        Image Version e: https://download.loxberry.de/stable/..._pippin.img.7z
        Image Version d: https://download.loxberry.de/stable/..._pippin.img.7z
        • Joe_M
          • 09.03.2022
          • 5
          Thank you! The e version has worked and I'm logged in.
