Loxberry plugin installation error
  • kubastedru
    • 19.01.2017
    • 20
    es tut mir leid fur mein Deutsch, aber
    Ich kann nicht neue plugin installatierrn. Ich hatte 2.2 version, so I hab die 3.0.0 version installiert und ich habe die gleiche fehler
    Ich kann nicht die plugin-install error finden.
    bitte hilfe!
    Jakub
    Logfile does not exist. Possibly the application has not yet started to log, or failed to run. Please re-check the logfile folder: ~/log, ~/webfrontend/html/tmp or /tmp. The ~ usually stands for /opt/loxberry where the Windows share also points to.
    • 5359
    Do not use Version 3.0. It is not stable and there might be non-working things... Latest stable is 2.2.2.2
    Install fresh image and upgrade to Version 2.2.2.2 via LoxBerry Update.
    • kubastedru
      • 19.01.2017
      • 20
      thank you, but this is the reason I updated from 2.2.2.2 where I found the issue originally... I have not installed new plugin since months maybe a year
        Please run LoxBerry's Healthcheck in the My LoxBerry widget and Post the result.
        This sounds like a problem with tmpfs or SD card, possibly mounted read-only.
        • kubastedru
          kubastedru kommentierte
          Hello,
          sure, please find bellow. I dont see a major issue there, I have already checked yesterday. it runs in VM.
          thank you for your help!
          Jakub
          Zuletzt geändert von kubastedru; 20.02.2023, 14:35.
      • kubastedru
        • 19.01.2017
        • 20
          I don't See an error. What are you trying to install? How is the use-case that you perform?
          You might send some Screenshots of the failed Installation.
          • kubastedru
            any idea? any plugin is giving the same "error" as described
        • kubastedru
          • 19.01.2017
          • 20
          Hello, I am trying to install Tesla-Connect and the only error (blue text color) is the one in the original post.
          Jakub
