Loxberry webpage not available
  • Kverb
    • 05.05.2022
    • 28
    Hi, when I go tho the loxberry webpage, I get the following:
    Software error:
    Could not read general.json. malformed JSON string, neither tag, array, object, number, string or atom, at character offset 0 (before "rver.d\nOWNCLOUD_MAX...") at /usr/share/perl5/JSON.pm line 190.
    at /opt/loxberry/webfrontend/htmlauth/system/index.cgi line 53.
    Can anyone tell me what I could try to resolve this?
    • 5457
    Your general.json in config/system is broken. The string he mentioned is „rver.d\nOWNCLOUD_MAX...", which is no config from the system at all.
    You can try to fix it via ssh and an Editor. But most likely your sdcard is broken.
    • Kverb
      Kverb kommentierte
      Thanks for your reply, indeed the only place where I have owncloud related things is in docker/portainer. The issue has happened twice in the last 4 days and a reboot has fixed it each time. Since it's hard to reproduce I won't know for sure whether any specific change has fixed it definitively. I'll try burning a loxberry backup image to a new SD card for when the issue comes back.
