RootFS free space 5%
  • krystianen
    • 11.12.2022
    • 12
    Hello
    Ihave problem with my loxberry. Healthcheck has reported error with
    RootFs and RAMDiscs "/ is below limit of 5% discspace (AVAL 23.5MB/SIZE 7.9GB). Please reboot your LoxBerry."
    i have rebooted, but nothing helps
Ansichten: 76
Größe: 107,3 KB
ID: 466616Klicke auf die Grafik für eine vergrößerte Ansicht
Ansichten: 41
Größe: 11,5 KB
    how to clean it up??​
    • 5457
    You are on a vm, so ramdisc is equal to roofs. Your filesystem is full. You have to find the root cause, Some hints can be found here (german only):
    https://wiki.loxberry.de/howtos_know...röße_prüfen
    • krystianen
      • 11.12.2022
      • 12
      Thanku for your replay, i have found that topic earier. But i cant see any big files..... espacially 7GB/7GB,
      here is what i checked
      Klicke auf die Grafik für eine vergrößerte Ansicht  Name: image.png Ansichten: 0 Größe: 47,2 KB ID: 466632
      • krystianen
        • 11.12.2022
        • 12
        i have found only on fiest screen /dev/sda1 but cant access this place.
          • 5457
          Repeat it as user root. Seems that it has nothing to do with LoxBerry but with the operating system. Your screenshot above shows that you do not have enough rights to execute all commands.
