habe jetzt schon bestimmt 10 x auf 2.99 zurückgesetzt und das Update ausgeführt.
Es kommt immer dieser Fehler: WARNING: In a previous run of LoxBerry Update this update script failed: v3.0.0. LoxBerry Update will continue. Please check the logfiles of previous updates for errors.
Das wäre der Fehlercode aus dem Log:
E: Could not get lock /var/lib/dpkg/lock-frontend. It is held by process 1425 (apt-get)
E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), is another process using it?
CRITICAL: Error removing dhcpcd5 - Error 100
OK: Done.
ERROR: Update script /opt/loxberry/sbin/loxberryupdate/update_v3.0.0.2.pl finished with errors.
15:29:15.965 INFO: exec_perl_script /opt/loxberry/sbin/loxberryupdate/update_v3.0.0.2.pl release=v3.0.1.3 logfilename=/opt/loxberry/log/system/loxberryupdate/20260510_152759_576_update.log cron= updatedir=/tmp/loxberryupdate/mschlenstedt-Loxberry-5848777 with user - errcode 1
15:29:15.966 ERROR: Update-Script update_v3.0.0.2 returned errorcode 1. Despite errors loxberryupdate.pl will continue.
15:29:15.967 INFO: Script version: v3.0.0.3
15:29:15.967 INFO: Running update script for v3.0.0.3...
15:29:16.020 INFO: Executing /opt/loxberry/sbin/loxberryupdate/update_v3.0.0.3.pl release=v3.0.1.3 logfilename=/opt/loxberry/log/system/loxberryupdate/20260510_152759_576_update.log cron= updatedir=/tmp/loxberryupdate/mschlenstedt-Loxberry-5848777
OK: Update script /opt/loxberry/sbin/loxberryupdate/update_v3.0.0.3.pl started.
INFO: Repairing broken Mosquitto Installation
INFO: Executing command 'APT_LISTCHANGES_FRONTEND=none DEBIAN_FRONTEND=noninteractive apt-get --no-install-recommends -y --allow-unauthenticated --fix-broken --reinstall --allow-downgrades --allow-remove-essential --allow-change-held-packages -o Dpkg::Options::='--force-confask,confnew,confmiss' install mosquitto'...
OK: Command executed successfully. - Exitcode 100
Leider gehen die Plugins seitdem auch nicht sauber.
Hat jemand eine Idee?
Danke!
