Update von DietPi schlägt fehl
  • Hrogota
    • 22.07.2026
    • 23
    ich versuche DietPi, auf dem mein Loxberry 4 läuft, upzudaten.
    Aktuell läuft bei mir noch DietPi 9.9.0, was schon sehr alt ist.
    Beim Update kommt folgender Fehler:
    Details:
    • Date | 2026-09-08 06:33:26
    • Program name | DietPi-Update
    • Command | apt-get -y -eany update
    • Exit code | 100
    • DietPi version | v9.9.0 (MichaIng/master)
    • Distro version | bookworm (ID=7,RASPBIAN=0)
    • Kernel version | Linux loxberry 6.6.62+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.6.62-1+rpt1 (2024-11-25) aarch64 GNU/Linux
    • Architecture | arm64
    • Hardware model | RPi 5 Model B (aarch64) (ID=5)
    • Power supply | (EG: RAVPower 5V 1A)
    • SD card | (EG: SanDisk Ultra 16 GB)
    Additional logs:
    Ign:1 https://repo.ebusd.eu/apt/default/bookworm bookworm InRelease
    Get:2 https://packages.sury.org/php bookworm InRelease [6136 B]
    Hit:3 https://deb.debian.org/debian bookworm InRelease
    Hit:4 https://deb.debian.org/debian bookworm-updates InRelease
    Get:5 https://dl.yarnpkg.com/debian stable InRelease
    Hit:6 https://deb.debian.org/debian-security bookworm-security InRelease
    Hit:7 https://deb.debian.org/debian bookworm-backports InRelease
    Hit:8 https://dietpi.com/apt bookworm InRelease
    Err:2 https://packages.sury.org/php bookworm InRelease
    The following signatures were invalid: EXPKEYSIG B188E2B695BD4743 DEB.SURY.ORG Automatic Signing Key <deb@sury.org>
    Hit:9 https://dietpi.com/apt all InRelease
    Hit:10 https://archive.raspberrypi.com/debian bookworm InRelease
    Hit:11 https://pkg.cloudflare.com/cloudflared any InRelease
    Err:5 https://dl.yarnpkg.com/debian stable InRelease
    The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 62D54FD4003F6525
    Err:1 https://repo.ebusd.eu/apt/default/bookworm bookworm InRelease
    Something wicked happened resolving 'repo.ebusd.eu:https' (-5 - No address associated with hostname)
    Fetched 22.7 kB in 7s (3207 B/s)
    Reading package lists...
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.sury.org/php bookworm InRelease: The following signatures were invalid: EXPKEYSIG B188E2B695BD4743 DEB.SURY.ORG Automatic Signing Key <deb@sury.org >
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://dl.yarnpkg.com/debian stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 62D54FD4003F6525
    E: Failed to fetch https://repo.ebusd.eu/apt/default/bo...worm/InRelease Something wicked happened resolving 'repo.ebusd.eu:https' (-5 - No address associated with hostname)
    E: Failed to fetch https://packages.sury.org/php/dists/bookworm/InRelease The following signatures were invalid: EXPKEYSIG B188E2B695BD4743 DEB.SURY.OR G Automatic Signing Key <deb@sury.org>
    E: Failed to fetch https://dl.yarnpkg.com/debian/dists/stable/InRelease The following signatures couldn't be verified because the public key is not ava ilable: NO_PUBKEY 62D54FD4003F6525
    E: Some index files failed to download. They have been ignored, or old ones used instead.
    Hat jemand eine Idee? Ein Problem scheint das eBusd-Plugin zu sein.
    Hat schon jemand die neueste DietPi-Version mit Loxberry 4 laufen?
  • Hrogota
    • 22.07.2026
    • 23
    Ich hab das update hinbekommen.
    Die Lösung waren die folgenden Statements:
    Sury:
    cd /tmp
    wget 'https://packages.sury.org/debsuryorg-archive-keyring.deb'
    dpkg -i debsuryorg-archive-keyring.deb
    Yarn:
    curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
    ebusd-repo:
    rm /etc/apt/sources.list.d/*ebusd*
