Syslog Server
    Syslog Server
    Hi, I've just released Syslog Server plugin.
    The Syslog Server use the standard rsyslog package. It's possible to receive log entries from another system (e.g. Miniserver - instead of saving logs into Miniserver's SD card) and stored them in separate log file.
    For analyzing of log files is used Adiscon LogAnalyzer
    If somebody want to translate please send me final ini files.
    If you have any question or enhancement requirement you can write it here or on plugin wiki.
    Please keep English in this thread!
    I don't speak German.
    Thanks
    Zmata
  • Riesenschnabel
    • 04.11.2015
    • 106
    I did a quick translation into German, which might help some people. You find it in the attachment.
    Eine schnelle deutsche Übersetzung befindet sich im Anhang.
    Hope this helps
    Loxone-Installation mit mehreren Extensions, Dimmer-Extension, DMX, 1-Wire (alles aktuell noch im Auslieferungszustand);
    FritzBox, Netgear Plus Switch mit mehreren VLANs, Intel NUC mit VMWare ESXi 6.5 (pfSense, Loxberry, Kleinkram)
      v0.0.3 released with German translation by Riesenschnabel
      Thanks Riesenschnabel!
      Unfortunately if I switch to German ü is not displayed correctly. In github repo it's OK. Could anybody confirm, that you see it same?
      Thanks
      • Riesenschnabel
        • 04.11.2015
        • 106
        For a quick fix you can replace the Umlaut "ü" with "ue".
        Not pretty, but works.
        • crouser7
          • 06.06.2016
          • 113
          interesting plugin.
          Am i corrrect understanding the following?
          This server replaces the internal logging on the sd card. so all data is written to the server?
          Is this just for logs or also for statistics?
            Yes you understand well. Logs are in LoxBerry instead of the Miniserver's SD card.
            If you use LoxBerry on raspberry pi (so it's on SD card too), you can permanently mount remote dir (for example dir from your NAS) into Syslog Server's log dir.
            It's just for logs, not for statistics.
              v0.0.4 - Correction of the 'ü' in German
                • 5470
                Just for your information: LoxBerry supports now automatically mounting USB and Network Storages. There's already som LIB functions for that, but Christian Fenzl also plans to create some piece of HTML from the libs that can be included into your template.
                http://www.loxwiki.eu/x/QoO3AQ
                This way your Plugin may support storage on external devices or netshares, too.
                • Wörsty
                  • 06.11.2015
                  • 203
                  The file must be UTF8 encoded. Otherwise ü is not okay. You can use notepad++ , i will have a look later.
                  Loxone Miniserver (letzte Beta) in KNX Umfeld
                    I know, I've already corrected it yesterday in v0.0.4
                    I personally use debian linux and nano editor, but in this case I used files as I got them.
                    • mecsolutions
                      • 04.12.2019
                      • 30
                      Hi all
                      Is it possible that the plugin not work anymore with the newest Loxberry version 2.0.1.3?
                      I set all parameters like the manual but i dont get any data from my miniserver.
                      Zuletzt geändert von mecsolutions; 13.04.2020, 20:31.
                        Hi All
                        Just wondering why plugin is not working anymore, is there something related to Loxone's latest versions or so?
                        Thanks
