Hallo, bin ganz neu dabei, habe einen VM Loxberry auf meinem Qnap installéiert(ver 0.2.3) und wenn ich das Plugin Netamo installéieren will, erscheint folgendende Fehlermeldung. Hat jemand eine Idee? Vielen Dank im Voraus <INFO> Starte Skript POSTINSTALL <INFO> Command: /bin/sh "/tmp/uploads/d49ISsP3Ov/loxberry-plugin-netatmo-weather-master/postinstall.sh" "d49ISsP3Ov/loxberry-plugin-netatmo-weather-master" "netatmo-weather" "netatmo-weather" "0.14" "/opt/loxberry" /bin/sed: can't read /opt/loxberry/webfrontend/htmlauth/plugins/netatmo-weather/index.cgi: No such file or directory /bin/sed: can't read /opt/loxberry/webfrontend/htmlauth/plugins/netatmo-weather/index.cgi: No such file or directory /bin/sed: can't read /opt/loxberry/webfrontend/htmlauth/plugins/netatmo-weather/index.cgi: No such file or directory <OK> Skript ohne Fehler ausgeführt <INFO> Starte Skript POSTUPGRADE <INFO> Command: /bin/sh "/tmp/uploads/d49ISsP3Ov/loxberry-plugin-netatmo-weather-master/postupgrade.sh" "d49ISsP3Ov/loxberry-plugin-netatmo-weather-master" "netatmo-weather" "netatmo-weather" "0.14" "/opt/loxberry" <INFO> Copy back existing config files '/tmp/uploads/d49ISsP3Ov/loxberry-plugin-netatmo-weather-master_upgrade/config/netatmo-weather/netatmo.cfg' -> '/opt/loxberry/config/plugins/netatmo-weather/netatmo.cfg' <INFO> Adding new config parameters <INFO> Copy back existing log files cp: cannot stat '/tmp/uploads/d49ISsP3Ov/loxberry-plugin-netatmo-weather-master_upgrade/log/netatmo-weather/*': No such file or directory <INFO> Remove temporary folders /bin/sed: can't read /opt/loxberry/webfrontend/cgi/plugins/netatmo-weather/index.cgi: No such file or directory /bin/sed: can't read /opt/loxberry/webfrontend/cgi/plugins/netatmo-weather/index.cgi: No such file or directory /bin/sed: can't read /opt/loxberry/webfrontend/cgi/plugins/netatmo-weather/index.cgi: No such file or directory <OK> Skript ohne Fehler ausgeführt <INFO> Aktualisiere Systemmenüs <OK> Systemmenüs aktualisert <INFO> Räume auf und lösche temporäre Dateien
netatmo-weather Plugin
Hallo, bin ganz neu dabei, habe einen VM Loxberry auf meinem Qnap installéiert(ver 0.2.3) und wenn ich das Plugin Netamo installéieren will, erscheint folgendende Fehlermeldung. Hat jemand eine Idee? Vielen Dank im Voraus <INFO> Starte Skript POSTINSTALL <INFO> Command: /bin/sh "/tmp/uploads/d49ISsP3Ov/loxberry-plugin-netatmo-weather-master/postinstall.sh" "d49ISsP3Ov/loxberry-plugin-netatmo-weather-master" "netatmo-weather" "netatmo-weather" "0.14" "/opt/loxberry" /bin/sed: can't read /opt/loxberry/webfrontend/htmlauth/plugins/netatmo-weather/index.cgi: No such file or directory /bin/sed: can't read /opt/loxberry/webfrontend/htmlauth/plugins/netatmo-weather/index.cgi: No such file or directory /bin/sed: can't read /opt/loxberry/webfrontend/htmlauth/plugins/netatmo-weather/index.cgi: No such file or directory <OK> Skript ohne Fehler ausgeführt <INFO> Starte Skript POSTUPGRADE <INFO> Command: /bin/sh "/tmp/uploads/d49ISsP3Ov/loxberry-plugin-netatmo-weather-master/postupgrade.sh" "d49ISsP3Ov/loxberry-plugin-netatmo-weather-master" "netatmo-weather" "netatmo-weather" "0.14" "/opt/loxberry" <INFO> Copy back existing config files '/tmp/uploads/d49ISsP3Ov/loxberry-plugin-netatmo-weather-master_upgrade/config/netatmo-weather/netatmo.cfg' -> '/opt/loxberry/config/plugins/netatmo-weather/netatmo.cfg' <INFO> Adding new config parameters <INFO> Copy back existing log files cp: cannot stat '/tmp/uploads/d49ISsP3Ov/loxberry-plugin-netatmo-weather-master_upgrade/log/netatmo-weather/*': No such file or directory <INFO> Remove temporary folders /bin/sed: can't read /opt/loxberry/webfrontend/cgi/plugins/netatmo-weather/index.cgi: No such file or directory /bin/sed: can't read /opt/loxberry/webfrontend/cgi/plugins/netatmo-weather/index.cgi: No such file or directory /bin/sed: can't read /opt/loxberry/webfrontend/cgi/plugins/netatmo-weather/index.cgi: No such file or directory <OK> Skript ohne Fehler ausgeführt <INFO> Aktualisiere Systemmenüs <OK> Systemmenüs aktualisert <INFO> Räume auf und lösche temporäre DateienStichworte: - -
in welchem Pfad hast du den Loxberry auf deiner VM installiert? scheinbar gibt es den Pfad /opt/loxberry nicht?
